Gas mileage & Oil Consumption 2012 Jeep Patriot - Page 2 - JeepForum.com
post #16 of 39 Old 06-06-2012, 06:41 PM
tjkj2002
2002 KJ Liberty
Originally Posted by mdavisson View Post
I just bought a 2012 Jeep Patriot where I expected a minimum of 19 mpg city and having filled it 5 times am getting an average of 14.1 . The dealership and Chrystler both say too bad, that is the government rating not ours. So now I not only have a payment, but I get no better mileage than the jeep Grand Cherokee that was paid for and traded in.
Anyone at all have any suggestions?
The vehicle has 450 miles on it and every half tank I only get 80 miles. This sucks.
Yeah I can tell you exactly how to get better mpg's but you'd look at me crazy so I'll keep to myself.Anyways your only at 450 miles,you don't get to complain yet till you hit at least 10,000miles and still get the same.
tjkj2002 is offline
post #17 of 39 Old 06-06-2012, 07:38 PM
NHPATRIOT
2014 KL Cherokee
Originally Posted by tjkj2002 View Post
You may not have a oil comsumption issue,to properly check the oil level you must be on a level surface and wait at least 30mins after shutting the engine off before getting a accurate reading the dipstick.
As for the mpg's don't expect anywhere close to advertized ratings till you hit at least 10,000 miles and your driving habits and gas quality comes into play after that.
While I completely agree with you on your oil checking comments I have to say I completely disagree with you on the comments that you need 10K for MPG to come close to advertised MPG #'s. While I do agree that the MPG will usually go up a little when the engine/drivetrain fully breaks in( does not take 10K though )I disagree that you can't see the advertised MPG #'s or even exceed them. It is all about how you drive really.
A vehicle should still get the advertised MPG even if brand new as long as you drive conservatively which mirrors the rating test proceedures. Also, remember that the ratings are not just the 2 bold numbers but rather, as another member pointed out, the small print will state they can vary by a few MPG either way depending on driving style. So the bold city MPG rating may be 22 but the fine print can state as low as say 18 and as high as say 24 or 25. The bold number is just the average MPG and not a guarantee.
I meet and usually exceed the EPA ratings on my vehicles and I don't need 10K to do so. Pretty much from day one or within the 1st couple tanks. Currently I have a 2011 Patriot Latitude( 2.4L, CVT, 4WD, FD1 ). The EPA rating is 21/26. I have easily exceeded those numbers since day 1 with the vehicle( hand calculated so accurate #'s ).
The 21 MPG rating for all city is about right if it is 100% city. I see 21-22 all city. If I have some highway thrown in I see 23-26 MPG depending on the mix ratio of city to highway. If my trip is all highway( 90-100% ) I have seen the following MPG returns...
28.9( had 370 miles on OD )
34.7( had 1400 miles on OD - *highest to date )
28.7( had 3200 miles on OD )
30.6( had 4050 miles on OD )
30.5( had 5100 miles on OD )
31.8( had 5650 miles on OD )
32.2( had 6200 miles on OD )
So far and away above the 26 average rating for me on higwhay driving and I only have approx 6500 on the vehicle( 1 year old in Aug ). The best MPG I have seen to date came with just 1400 kmiles on the vehicle. The absolute worst MPG I have seen is high 19's. That is when I have towed my duck boat. Not only is it towing( 1700lbs +/- )but it is during winter so cold temps and winter gas which hurt MPG.
IMO if the OP drives conseravtively then the MPG being seen is low.
2014 Jeep Cherokee
Latitude
3.2L Pentastar V6
Active Drive I
NHPATRIOT is offline
post #18 of 39 Old 06-14-2012, 08:28 AM
1986pacecar
My wife's 2012 Patriot get 24 MPG and she's got a lead foot.
1986pacecar is offline
post #19 of 39 Old 06-14-2012, 03:13 PM
dirkdiggler106
2012 MK Patriot
Good post!
I just filled my patriot for the first time and calculated 26mpg with 25% highway driving and 75% side roads & city. Since my jeep came with a full tank of gas and a reset odometer I don't even think it was reset when it was filled up so that would equate to me getting more miles per gallon then I calculated on my first tank of gas.
Mine is a 2.4 5spd 4x4.
RIP MY JEEPS... 1998-TJ 1992-XJ 1999-TJ 1994-XJ 1998-ZJ... All were lifted and locked...
dirkdiggler106 is offline
post #20 of 39 Old 06-24-2012, 08:12 AM
PatriotSportLPi
Hi All,
even i own a 2008 Patriot Sport (4x4, 5speed, 40,000 miles) the consumption in summer using summer tires is about 26 mpg.
In winter using winter tires about 24.7 mpg.
I drive every day 9.3 miles for work (25% city 31mph, 50% highway 75 mph, 25% country road 62 mph). So a very short way and in winter the engine just reaches working temperature.
The oil comsumption is less than 0.5 quarts for 7,500 miles.
The MPG is going down the last years. At the beginning it was 28 - 27 mpg in summer and 26 mpg in winter.
PatriotSportLPi is offline
post #21 of 39 Old 06-26-2012, 04:18 PM
dirkdiggler106
2012 MK Patriot
my first 3 tanks of gas are as follows:
26mpg
24mpg
27mpg
On my second tank of gas where I got 24mpg I drove it a little harder. I backed off quite a bit for my third tank of gas and it made a big difference. I kept it under 70mph on the highway and under 60mph on regular roads, and didn't stand on the gas from stop light to stop light... I didn't drive super slow but I made an effort to drive conservatively.
post #22 of 39 Old 06-27-2012, 08:57 AM
JeepCares
FCA Customer Care
JeepCares's Avatar
I just posted this about oil consumption: http://www.jeepforum.com/forum/f98/s...013-a-1386228/
JeepCares is online now
post #23 of 39 Old 07-08-2012, 01:28 PM
TheSiltSurfer
2012 WK
Originally Posted by FujativeOCR
Yeah my 2011 only gets about 180 per tank of city driving. My fiance has been driving it the last month and she's averaged 16.4. Window sticker says 20. I hypermile it and get about 18 city keeping it under 2,000 rpm. For highway driving my mileage is screwed if the speed limit is over 60. Mine has 11,000 miles on it now and no noticeable improvement over new.
This thread is a bit discouraging, anyone with a 2011-2012 actually getting 23mpg or better? Looking into a altitude for the fiancÚ but might look into wrangler . & 180 miles per tank is depressing. Whats the size of the tank? Thanks guys
Infinite Patience Produces Immediate Results
TheSiltSurfer is offline
post #24 of 39 Old 07-08-2012, 02:42 PM
marvin02
2012 MK Patriot
The tank on a 2012 is 13.6 gallons.
Here are the Patriots that are tracked at fuelly.com.
marvin02 is offline
post #25 of 39 Old 07-08-2012, 02:58 PM
FujativeOCR
2011 MK Patriot
If you get one without the off road Freedom Drive 2 package the mileage should be better than mine. I finally figured this out a couple days ago, but with FD2, the engine/tranny is going to be spinning about 30% faster at all speeds than without it. Because of the final drive ratio (differential gears I guess), mine runs at 3200 rpm at 75 mph, whereas the regular FD1 CVT should be about 2400, thus better mpg.
FujativeOCR is offline
post #26 of 39 Old 07-08-2012, 03:17 PM
TheSiltSurfer
2012 WK
this is right from the Horses mouth, but it appears that FD2 is not offered on the Altitude? Can anyone else confirm this? Were interested in some offroad capability for it might have to consider latitude with altitude feature? Suggestions? thanks
post #27 of 39 Old 07-08-2012, 03:21 PM
TheSiltSurfer
2012 WK
ok just tried building a Latitude but no feature to add Altitude styling...The plot thickens is the FD1 Pretty capable of sand and snow? Perhaps they haven't updated their site? the Altitude does have the CVT2 so doesn't that mean it has FD2? Thanks again
post #28 of 39 Old 07-08-2012, 03:32 PM
marvin02
2012 MK Patriot
The CVT2 is NOT the FDII.
marvin02 is offline
post #29 of 39 Old 07-08-2012, 03:39 PM
FujativeOCR
2011 MK Patriot
Should say...CVT2"L" that comes with FD2. At least thats how I recall it being packaged?
post #30 of 39 Old 07-08-2012, 03:53 PM
TheSiltSurfer
2012 WK
Ok thanks something to consider if it doesn't have FD2, surprised they don't offer it, I anyone else knows better speak up thanks
Recall on 2012 Compass and Patriot for fire srtdodge05 Jeep Compass & Patriot Forum 9 04-10-2012 08:38 AM
Considering a 2012 Patriot... audiodrive Jeep Compass & Patriot Forum 13 03-30-2012 09:05 AM
2012 jeep patriot rfslonski Jeep Compass & Patriot Forum 1 12-19-2011 04:45 PM
2012 Compass/Patriot changes IRSmart Jeep Compass & Patriot Forum 0 06-06-2011 03:31 PM
Patriot and Compass to be 1 vehicle by 2012 unclejjg Jeep Compass & Patriot Forum 15 03-14-2009 06:27 AM
