Gas mileage has fallen off since tranny rebuild - JeepForum.com
post #1 of 9 Old 09-19-2009, 10:53 PM Thread Starter
fortuneer
fortuneer's Avatar
2007 MK Compass
Hey, fellow MK owners. My '07 Compass fell prey to the bad batch of hydrolic actuators and had to have the clutch replaced and the tranny rebuilt. This was in January of this year and ever sense I've had it back my gas mileage has bottomed out. I keep up with my regular maintainance and fuel up at the same stations as before, yet my economy has fallen from 23 mpg to less than 20 on most tanks. I've added no new weight since last year nor have I changed my tires to a larger size (yet). Still, my mileage has degraded despite the use of fuel injector cleaner every oil change. I will admit that most stations in Florida have switched to the (nasty) "10% or less" ethenol crap gas. Has anyone else experienced such a mileage fall off since the beginning of the year? Sorry for such a long post but this is costing me more each fill up - even as gas prices fall some what. Thanx for any input.
"There's gold in them hills" (and I'm still stuck in Florida!) ...well, in south Miss now, lol
Black '07 Compass Sport 5-speed 4X4 ("Fortuneer"), K&N filter, cat-back exhaust; RR lift, sunroof, trailer tow group, Boston Acoustic audio, sport bars, rear taillight guards, more to come... Finally got it back from the wife so I can let my Neon R/T rest for a rebuild.
fortuneer is offline
post #2 of 9 Old 09-20-2009, 06:36 AM
Gramps
The Necessary Evil
Gramps's Avatar
2007 MK Compass
I had the same thing start happening right before my 30K tune-up. I did the tune up and no change. Then I started doing the "disconnect the battery" thing and it would start all over reading 26+ mpg and very slowly fall off to about 18 mpg or so at the rate of .1 mpg/50 miles. We took it on a trip down to the Worlds Longest Yard Sale and stayed in Jamestown TN 750 miles from home. I filled up probably at 10 different stations going and coming and still the same thing, mileage would drop off after disconnecting the battery. I told the dealer about it when I got back, there were no codes, and their only explanation was bad gas. RIGHT! Bad gas at every station on a 1500 mile trip. About the 4th or 5th time I did the battery thing it finally went back up and has stayed there ever since (with in reason, it always drops when the temp gets down below 20 degrees).
Just to add another possibility is low battery voltage/amp output. During this last winter mine wouldn't hold enough of a charge to listen to the radio for 1/2 hour. It wouldn't turn over at all. I replaced the battery and everything has worked fine since then including getting about 1 - 2 mpg more than before. With all of the electronics having a good battery is critical.
I do realize that the 5 speed doesn't take to reprogamming like the CVT does, these are just shots in the dark because nothing else makes any since either.
Bob
posts 68 & 69
Also visit me at
Gramps is offline
post #3 of 9 Old 09-24-2009, 08:18 PM Thread Starter
fortuneer
fortuneer's Avatar
2007 MK Compass
Thanks for the imput, Gramps. The disconnect trick I already tried and makes no difference. My mileage is starting to get as bad as the any of the three minivans (shudder) I once owned. With moderate city driving, I can burn through thirteen gallons of gas in about 200 miles. My dealer has no idea why this happens. Before the tranny rebuild, I could get at least 300 miles per tank. If I'd wanted a Jeep with this kinda mileage I'd have bought a Liberty.
post #4 of 9 Old 09-24-2009, 08:20 PM Thread Starter
fortuneer
fortuneer's Avatar
2007 MK Compass
Oh! No troubles with my battery. I can sit on my lunch break and blast my 458 watt system for a half hour with no problems. Fortuneer starts strong every time.
post #5 of 9 Old 09-25-2009, 03:54 AM
Gramps
The Necessary Evil
Gramps's Avatar
2007 MK Compass
I hear you on that! I've been thinking about a Libby or a Wrangler myself but I'm not sure how fast gas prices are going to go up again.
Not a clue as to what else to look for but I'm curious, did the mpg come back up temporarily after the battery disconnect and then drop slowly back down? "Slowly" being a relative term.
Bob
posts 68 & 69
Also visit me at
Gramps is offline
post #6 of 9 Old 09-25-2009, 05:55 PM Thread Starter
fortuneer
fortuneer's Avatar
2007 MK Compass
There was no serious rise in mileage. I can burn through two tanks with HORRIBLE numbers then suddenly bounce up a couple mpg's on a random tank, then drop once more. Never has my mileage either risen or dropped after a computer reset. Very puzzling. I had all my mods (CIA, high-flow exhaust, etc, including weight added by lift and such) in 2008. This crappy fuel consumption only manifested itself after the clutch and tranny were replaced and rebuilt in early 2009.
post #7 of 9 Old 09-25-2009, 05:57 PM Thread Starter
fortuneer
fortuneer's Avatar
2007 MK Compass
Also, my acceleration curve remains the same as well. Performance is the same, just poor fuel economy.
post #8 of 9 Old 09-26-2009, 08:00 AM
Gramps
The Necessary Evil
Gramps's Avatar
2007 MK Compass
I think that the dealer should be contacting the Engineering field rep for you. It's not right and they need to find a solution.
Bob
posts 68 & 69
Also visit me at
Gramps is offline
post #9 of 9 Old 09-26-2009, 11:22 PM Thread Starter
fortuneer
fortuneer's Avatar
2007 MK Compass
Copy that, Gramps. Got a line on one that helped secure parts for my Jeep when Chrysler was having supplier difficulties. Will advise when events progress.
Gas Mileage Question reduno Jeep Compass & Patriot Forum 16 09-15-2009 01:42 PM
tire mileage Elihawk Jeep Compass & Patriot Forum 5 09-04-2009 07:00 PM
Gas Mileage on 4x4 w Off Road safaribabe Jeep Compass & Patriot Forum 19 03-18-2008 09:01 AM
Gas Mileage/Break-in NoNamesLeft Jeep Compass & Patriot Forum 3 01-11-2008 05:17 PM
Mileage Problem Paser00 Jeep Compass & Patriot Forum 29 12-09-2007 01:49 PM
