FYI - Service Bulletin 26-004-12 - 2011-2012 Fluid Flushing Requirements - JeepForum.com
post #1 of 1 Old 06-06-2012, 09:57 AM Thread Starter
JeepCares
FCA Customer Care
JeepCares's Avatar
Ignore post if not interested.
BULLETIN NUMBER: 26-004-12
DATE: June 06, 2012
SUBJECT:
MODELS:
2011 - 2012 (JK) Wrangler
2011 - 2012 (KK) Liberty
2011 - 2012 (MK) Compass/Patriot
2011 - 2012 (WK) Grand Cherokee
DISCUSSION:
Chrysler Group vehicle fluid systems do NOT require regular flushing. These systems include: engine oil, transmission oil, axle lube, brake fluid, power steering fluid, and refrigerant. The only exceptions to this requirement are published in the vehicle maintenance schedules, e.g. engine coolant.
Exceptions to this recommendation include only those instances where a malfunction has occurred and/or the system has become compromised, contaminated or overheated beyond the normal operating range.
Chrysler Group does NOT recommend aftermarket chemicals to flush the engine, transmission, brake or steering systems. Chemicals contained in these products can damage the system elastomeric components, and contaminate the component fluid, leading to loss of system/component durability and service life. When necessary, only the original approved system fluid should be used to flush these components using teamPSEŽ approved equipment.
If the engine coolant contains a considerable amount of sediment, clean and flush with Mopar Cooling System Flush, p/n 04856977, or equivalent. Follow with a thorough rinsing to remove all deposits and chemicals. Refill with a minimum of a 50% mixture of the specified coolant and distilled water.
JeepCares is offline
FYI - Service Bulletin 08-037-12 - Certain Switches intermittent/don't work JeepCares Jeep Compass & Patriot Forum 10 07-13-2012 09:44 AM
FYI - Service Bulletin 18-017-12 - Long Crank Times 0-50 degrees F JeepCares Jeep Compass & Patriot Forum 0 06-04-2012 08:17 AM
2012 CVT Program Upgrade to 2011 CVT gbridge Jeep Compass & Patriot Forum 32 02-02-2012 05:27 PM
Recommended Options for 2011 or 2012 Patriot Mike5 Jeep Compass & Patriot Forum 4 10-07-2011 04:21 PM
09 Jeep Compass CVT Fluid Service coke2430 Jeep Compass & Patriot Forum 2 04-14-2010 06:59 PM
