FYI - Service Bulletin 18-017-12 - Long Crank Times 0-50 degrees F - JeepForum.com
post #1 of 1 Old 06-04-2012, 07:17 AM Thread Starter
JeepCares
FCA Customer Care
JeepCares's Avatar
Ignore if not interested.
NUMBER: 18-017-12
GROUP: Vehicle Performance
DATE: June 01, 2012
SUBJECT:
Flash: Long Crank Times When Temperatures Between 0 Degrees F and 50 Degrees F
OVERVIEW:
This bulletin involves selectively erasing and reprogramming the Powertrain Control Module (PCM) with new software.
MODELS:
2011 - 2012 (MK) Compass /Patriot
NOTE: This bulletin applies to vehicle equipped with a 2.0L engine (sales code ECN) and a automatic transmission (sales code DAW or DAV) built before May 17, 2012 (MDH 0517XX).
SYMPTOM/CONDITION:
The customer may experience a long crank time when temperatures are between 0 F (-17 C) and 50 F (10 C) after and 8 hour soak time.
In order to correct this condition the PCM calibration has been changed to add cranking spark and reduce the start fueling.
Updating the software will correct the conditions listed above.
JeepCares is online now
FYI - Service Bulletin 08-037-12 - Certain Switches intermittent/don't work JeepCares Jeep Compass & Patriot Forum 10 07-13-2012 08:44 AM
Problem With Acceleration in cold temperatures below -1 degrees Englishriot Jeep Compass & Patriot Forum 3 04-16-2012 04:02 AM
Service Manual Available lynnk Jeep Compass & Patriot Forum 23 09-02-2011 01:40 PM
Ambient temp sensor stuck on 76 degrees. horsepower Jeep Compass & Patriot Forum 7 08-31-2010 04:02 PM
CRD 20.000 service or 2 years? OMG merlinTec Jeep Compass & Patriot Forum 3 08-03-2009 11:43 AM
