FYI - Plugged in Block Heater can trip the Check Engine Light - JeepForum.com
post #1 of 3 Old 01-12-2010, 11:29 AM Thread Starter
Knightfallzx2
2008 MK Compass
We've had that annoying little Check Engine light come on a few times last year during winter, and now once again this year.
We brought it by the stealership and apparently, if you happen to start the car while your car is still plugged in, it can upset the Jeep's computer. It's been a known problem with the '08s. They ended up flashing the computer to update the firmware.
I admit, I normally start the car, and then go unplug it. Sometimes I do it the other way around. I've never known it to be an issue before. Although now that the computer is flashed, it's supposed to be alright now.
Just thought I would share the experience to fellow MK owners - especially those with the block heater.
2008 Jeep Compass North 4x4
Black Crystal Pearlcoat, 5-speed
Knightfallzx2 is offline
post #2 of 3 Old 01-19-2010, 01:05 AM
rpiereck
Mine must be flashed already, none of that problem here. I start mine with the autostart everyday and no issues so far.
JKS Adjustable control arms - JKS 1.25" Body Lift - JKS 1" Engine Mount Lift
Old Man Emu 4" coils - Rancho 5000 shocks - Teraflex front adj trackbar - RE rear track bar bracket
33/12.5x15 Wrangler Duratracs - Tabor 12k Winch - Hella 500F Foglights
Hella Supertone Horns - Uniden CB radio
rpiereck is offline
post #3 of 3 Old 01-19-2010, 09:26 AM
miketmx
2015 MK Patriot
When we first got our Patriot I didn't think the block heater was working because it was so quiet compared to our Cherokee which makes a noise as soon as you plug it in. I took the Patriot to the dealer and they tested the block heater and said it was working just fine. I also use synthetic oil which makes starting in the winter a little easier. The only time I have ever seen the MIL light was during mid-summer in Illinois and I think it was a bad tank of gas. The light went away on our next fill up.
miketmx is offline
Engine Block Heater... Where is the plug? cj3bandtj Jeep Compass & Patriot Forum 3 12-30-2009 09:39 AM
Engine Light Staying On - Owners Manual Useless!! ChillyWillys Jeep Compass & Patriot Forum 13 09-13-2009 02:12 PM
A Great Jeep Road Trip ChillyWillys Jeep Compass & Patriot Forum 6 09-07-2009 05:47 PM
Location of engine block heater of Patriot 08 Pravsta Jeep Compass & Patriot Forum 1 01-07-2009 11:11 AM
Check Engine Light/Other Issues Mistyfate Jeep Compass & Patriot Forum 4 03-21-2008 07:52 PM
