Fuel Filter question - JeepForum.com
post #1 of 9 Old 01-06-2009, 09:20 AM Thread Starter
PirateKatz
Thanks.
I also went through the manual and I noticed that there is no mention of replacing the fuel filter. Did I read that correctly or did I just miss that? My previous car (a Ford) required a new one every 30k if I recall correctly.
Also, what is an autotension drive belt?
I've got so much to learn! :-)
PirateKatz is offline
post #2 of 9 Old 01-06-2009, 04:59 PM
Gramps
The Necessary Evil
Gramps's Avatar
2007 MK Compass
The fuel filter mounts inside the fuel pump module and is a non-serviceable part. The Fuel Pump Module is located inside the fuel tank.
The serpentine belt has an auto tensioner. Its a spring loaded flat pulley that the back side of the belt rides on. Pretty common on serpentine belts.
Bob
posts 68 & 69
Also visit me at
Gramps is offline
post #3 of 9 Old 01-20-2009, 10:37 PM
borispeed
2007 MK Compass
What!!!? Then, How the fuel gets clean? Is there another "cleaner" that cleans it?
borispeed is offline
post #4 of 9 Old 01-21-2009, 03:43 AM
Gramps
The Necessary Evil
Gramps's Avatar
2007 MK Compass
To change the fuel filter you have to change the fuel pump. It's all one unit.
Bob
posts 68 & 69
Also visit me at
Gramps is offline
post #5 of 9 Old 01-21-2009, 07:50 PM
borispeed
2007 MK Compass
So, when it is recomended to change the fuel filter? Do you need to remove the fuel tank to do it?
post #6 of 9 Old 01-22-2009, 04:05 AM
Gramps
The Necessary Evil
Gramps's Avatar
2007 MK Compass
Just like a water pump, oil pump, starter and many other items that are not on "Maintenance Schedules" A or B that list up to the first 120,000 miles you replace as necessary, i.e. when it breaks or quits working.
Yes you will need to drain the fuel tank and drop it when the time comes.
Bob
posts 68 & 69
Also visit me at
Gramps is offline
post #7 of 9 Old 01-25-2009, 06:06 PM
borispeed
2007 MK Compass
Oh, I see. Good info gramps, thanks.
post #8 of 9 Old 01-26-2009, 10:42 AM
cuemark8
2007 MK Compass
Sparkplugs at 30,000Mi
Oh and the fuel pump questions should be in another thread. FYI. the fuel pump and filter is inside the tank and is accessed by removing the rear seat and removing a plate from the top of the fueltank opening the fuel tank and exposing the guts.
cuemark8 is offline
post #9 of 9 Old 01-26-2009, 05:23 PM
Gramps
The Necessary Evil
Gramps's Avatar
2007 MK Compass
Good info on the accessibility!
Bob
posts 68 & 69
Also visit me at
Gramps is offline
Engine Air Filter replacement in 2.4 MomofCandS Jeep Compass & Patriot Forum 10 05-29-2009 07:31 PM
Where is the Cabin Air Filter? UTAH Jeep Compass & Patriot Forum 19 12-16-2008 07:25 AM
Oil amount w/ filter, how much? Tuksonrider Jeep Compass & Patriot Forum 3 10-08-2008 12:01 PM
Oil Filter Access the mad hatter Jeep Compass & Patriot Forum 7 07-23-2008 02:59 PM
K&N Air Filter - Compass CRD mdls4 Jeep Compass & Patriot Forum 7 01-30-2008 03:05 PM
