Front door panel rattling - JeepForum.com
post #1 of 7 Old 02-14-2014, 02:32 PM Thread Starter
zflux
2012 MK Compass
Just got a 2012 Jeep Compass with the Boston audio system in it. The system sounds great but my front door panels rattle just enough to make it really annoying. When I hold them it stops. Any suggestions on what to add or tighten up to make it stop?
Much appreciated
zflux is offline
post #2 of 7 Old 02-16-2014, 10:46 AM
Fredjweb
2007 MK Compass
Much appreciated
For me it turned out to be more of the lock pull at the top of the door. I put a tiny bit of electrical tape around it and 99% of my rattling is solved. Hope that helps!
Fredjweb is offline
post #3 of 7 Old 02-16-2014, 04:22 PM Thread Starter
zflux
2012 MK Compass
When you put the tape on did you put it on the outside, or open the door panel up and tape around the unit?
zflux is offline
post #4 of 7 Old 02-17-2014, 06:36 AM
Fredjweb
2007 MK Compass
I just wrapped the plastic piece with everything together. When the door auto lock the piece drops down and that's what rattles the most against the door panel. Long as your interior is black no one will ever see it. Hope that's helpful! It was a much easier fix than taking everything apart!
Fredjweb is offline
post #5 of 7 Old 02-17-2014, 08:51 AM
jacko15
2014 WK
I had the same problem with my '08 Compass. The silver lock button that was vibrating and making the noise is screwed on to a threaded shaft. I went to the auto parts store and found some buttons that had a more rubbery finish, and replaced the stock buttons. No more noise.
Mine: 2014 Jeep Grand Cherokee Overland V/6
ORA II
Hers: 2017 Jeep Compass Latitude 4x4
jacko15 is offline
post #6 of 7 Old 02-17-2014, 10:13 AM
Fredjweb
2007 MK Compass
Ha! Much more elegant fix than mine. I'm gonna hit the parts store on the way home!
Fredjweb is offline
post #7 of 7 Old 02-17-2014, 02:55 PM Thread Starter
zflux
2012 MK Compass
Ill have to try this out Thanks
zflux is offline
audio , boston , compass , rattle
