Factory Trailer Wiring Harness Installation - JeepForum.com
post #1 of 21 Old 05-01-2008, 10:56 AM Thread Starter
coachwillb
2007 MK Compass
install a trailer tow wiring kit to a jeep compass? I would like to add a hitch and kit. When I called the dealer they gave me a quote of all but $400for a class I hitch, and kit installed. I found a after marked class III hitch for $107, and wire kit for $48. I know the hitch is only 4 bolts. How hard is it to install the kit and will it effect my warranty. Thanks for the help
coachwillb is offline
post #2 of 21 Old 05-01-2008, 12:48 PM
Gramps
The Necessary Evil
Gramps's Avatar
2007 MK Compass
Here are the "How to's":
Hitch Installation
Engine Oil Cooler and Trailer Wiring Harness
The harness installation is a little incomplete because we don't have pictures of an actual installation but it should give you some ideas. You also may not need the Engine Oil Cooler, depending on what you want to tow.
Is it difficult? A geezer can do it, right?
Bob
posts 68 & 69
Also visit me at
Gramps is offline
post #3 of 21 Old 05-01-2008, 03:14 PM
Laloggia
2010 JK Wrangler
Make sure you get the wire harness kit specifically for the Compass. The one for the Patriot will not work. I know this by experience. There are two different part numbers. Also, do not use a universal wire harness that you splice into the taillights. This will not work properly....trust me...i tried taking the cheap way out and the computer doesn't like it. The mopar kit designed for the Compass has relays built into the harness that it needs to work correctly. Easy install with the correct parts.
2010 Wrangler Islander
2005 Chrysler Crossfire
2010 Honda Crosstour
2007 Honda Civic Coupe
Laloggia is offline
post #4 of 21 Old 05-04-2008, 06:38 AM Thread Starter
coachwillb
2007 MK Compass
Gramps
Do I need a oil cooler if i have a manual transmission? Sorry for my ignorance, but I never needed one for me wrangler. I also wanted to know what is the top weight you would tow with your compass. The dealer told me no more than 1000lbs. Thanks again Will
post #5 of 21 Old 05-04-2008, 07:12 AM
Gramps
The Necessary Evil
Gramps's Avatar
2007 MK Compass
1000 lbs without the cooler, 1500 with. Most vehicles take a trans oil cooler on the Automatic (the CVT already has one of those) but this is an engine oil cooler that taps off of the radiator hoses and goes between the block and oil filter.
Bob
posts 68 & 69
Also visit me at
Gramps is offline
post #6 of 21 Old 05-05-2008, 08:32 AM Thread Starter
coachwillb
2007 MK Compass
Gramps
Thanks again for your help. When I went to order the engine oil cooler for my compass, the dealer told me my car already has one and I don't have to order one. Do they all have one and I have to upgrade to a better one, is he wrong, or am I just lucky? He did take my VIN# to confirm.
post #7 of 21 Old 05-05-2008, 09:04 AM
Gramps
The Necessary Evil
Gramps's Avatar
2007 MK Compass
If you ordered it with the Trailer Tow Package it will alredy have the engine oil cooler. There is only one. Do you already have yours or is it coming from another dealer?
Bob
posts 68 & 69
Also visit me at
Gramps is offline
post #8 of 21 Old 05-05-2008, 09:39 AM Thread Starter
coachwillb
2007 MK Compass
I don't have a tow package. My jeep dealer told me i could not order a engine oil cooler b/c my car came with one. I am not sure... I guess I should take it in and have him check it / have him show me it.
post #9 of 21 Old 05-05-2008, 10:01 AM
Gramps
The Necessary Evil
Gramps's Avatar
2007 MK Compass
Look under the front end at the Oil Filter. The first pic is without the cooler the second pic is with the Oil Cooler.
Bob
posts 68 & 69
Also visit me at
Gramps is offline
post #10 of 21 Old 07-02-2008, 08:05 AM
TAS121
2008 MK Compass
I just got my harness last week. Going to be a bit of a pain since you have to run a wire from the back up to the battery. I thought it would just plug into the back.
TAS121 is offline
post #11 of 21 Old 07-02-2008, 01:00 PM
OnRoad
2008 MK Compass
The Mopar one? That does not make any sense. I would suggest that you verify the part number just in case.....
2008 Jeep Compass Limited 4x4 CVT
Brilliant Black Crystal Pearl Coat
OnRoad is offline
post #12 of 21 Old 07-02-2008, 01:12 PM
TAS121
2008 MK Compass
Yes, it's from the dealer. I will double check the part #. It said on the bag for Compass.
TAS121 is offline
post #13 of 21 Old 07-02-2008, 03:44 PM
Gentleman
2008 MK Compass
The one all the way to the front is the one I installed, if you installed the hitch before the harness you may have to drop the hitch or have some very tiny fingers, you need to drill a 1/2" hole in the metal plug under the tire and run the entire harness minus the relays through the hole
Bob
2008 Compass Sport Jeep Green 2.4 L CVT
2005 Liberty Limited Black 3.7 L
Gentleman is offline
post #14 of 21 Old 07-02-2008, 04:34 PM
TAS121
2008 MK Compass
I checked the part #, its right. The part that sucks is I paid around $125(cdn). The aftermarket one is only $55. I wen't with the OEM one because I thought it just pluged in at the back like someone showed in a pic. No big deal, will just be a bit longer to install than I thought.
2008 Compass 4 x 2, 5 speed
TAS121 is offline
post #15 of 21 Old 07-02-2008, 04:46 PM
Gramps
The Necessary Evil
Gramps's Avatar
2007 MK Compass
Be careful on the aftermarket ones. If you get the correct one, depending if you have 2 ('08) or 3 ('07) bulbs in your tail light housing you'll be fine (so I hear). The wrong one screws with your computer.
Still lazy, haven't bought my harness yet let alone install it.
Bob
posts 68 & 69
Also visit me at
Gramps is offline
MK Lift Kit Installation RRO 2 1/8" Kit hvac59 Jeep Compass & Patriot Forum 12 02-17-2009 02:25 PM
Uconnect For A Factory No Factory Install 229bonehead Jeep Compass & Patriot Forum 1 08-10-2008 09:46 PM
Patriot Factory Tow Harness Install Hinterlander Jeep Compass & Patriot Forum 2 05-12-2008 12:30 PM
Stereo Wiring Harness! earlage Jeep Compass & Patriot Forum 1 12-27-2007 08:25 PM
MK OIL COOLER INSTALLATION/Tow Wiring Diagram/Hitch stoge Jeep Compass & Patriot Forum 28 09-29-2007 08:23 PM
