Exhaust system from scratch - JeepForum.com
post #1 of 13 Old 10-25-2011, 02:09 PM Thread Starter
armystrong68w
2008 MK Patriot
Instead of buying an $800 exhaust system, could someone handy with welding make their own from tubing? and where would be a good place to get the tubing, can you buy it at NAPA or some place similar?
****Before i had a jeep I didnt know why you guys parked in snow banks and made sure to hit puddles and mud but now i understand....It really is a Jeep thing!!!!!****
armystrong68w is offline
post #2 of 13 Old 10-25-2011, 06:18 PM
w4rh4wk
2011 MK Compass
mine wasnt $800 it was $400 (off of ebay) ... you could... someone a while back basically bought his own muffler and had it swapped it out for the stock muffler... you figure muffler ~$100-$150 + materials + labor.... get some prices and take a look at some universal mufflers... i almost did a custom exhaust on mine.
11 Compass 2.4 4x4, Eonon GA2162, K&N Intake, Magnaflow #16777, Mopar:Chrome Fuel Door/Splash Guards
w4rh4wk is offline
post #3 of 13 Old 10-25-2011, 06:29 PM
tjkj2002
2002 KJ Liberty
The OEM exhaust and most aftermarket cat-back systems are mandrel bent and that pipe bought at parts stores is not.Big difference in flow rate between mandrel bends and non-mandrel bends,reduction can be as much as 25% for non-mandrel bent pipe.Plus the aftermarket systems are designed to still work with your engine to keep the exhaust pulses the same or improve them(free's up some HP,not much though).
tjkj2002 is offline
post #4 of 13 Old 10-25-2011, 06:40 PM Thread Starter
armystrong68w
2008 MK Patriot
Cant i use the same pipe? and just replace that huge mother F**ker of a pillow we have as muffler? or is there no gain in HP/MPG from that?
post #5 of 13 Old 10-25-2011, 06:47 PM
tjkj2002
2002 KJ Liberty
Sure you can just replace the muffler.You will not gain any HP from it,just more noise depending on muffler used.You may "feel" more power but it is just the noise and the PCM will "learn" back to prior performance shortly anyways unless you reprogram the PCM to the increased flow.Then you got to free up the incoming air and internal working to get any lasting and measurable effect.
tjkj2002 is offline
post #6 of 13 Old 10-25-2011, 07:08 PM Thread Starter
armystrong68w
2008 MK Patriot
ahh so useless unless i want to sound like a civic. which i don't. Basically i will have to get a "CAI" and have a shop work on custom headers and a have to buy a magnaflow cat back system and then have the computer updated if i want to see any difference?
post #7 of 13 Old 10-25-2011, 07:15 PM
tjkj2002
2002 KJ Liberty
Yep and then you have to add some different grind cam(s) and head work(porting and such),may get 25-50hp and loose most of the low end power as the gain will all be at the high rpm range.
tjkj2002 is offline
post #8 of 13 Old 10-25-2011, 07:38 PM Thread Starter
armystrong68w
2008 MK Patriot
stupid POS car... they should have used a more efficient I6 instead of the I4
post #9 of 13 Old 10-25-2011, 10:45 PM
FujativeOCR
2011 MK Patriot
Agreed. Or perhaps an automatic.
FujativeOCR is offline
post #10 of 13 Old 10-26-2011, 08:19 AM
Gramps
The Necessary Evil
Gramps's Avatar
2007 MK Compass
You get what you pay for: a new computerized vehicle that meets the standards imposed by the g'ment that has VERY limited modification capability so that it maintains those standards. That's the way it is these days. You knew what you were buying and if you wanted an I6 then that's what you should have bought. It is what it is but I don't consider it a POS just because you can't turn it in to something else.
Bob
posts 68 & 69
Also visit me at
Gramps is offline
post #11 of 13 Old 10-26-2011, 08:52 AM
lidhead
2009 MK Compass
So... how do you reprogram the PCM after the exhaust and intake has been replaced? Do you have to take it to the dealer? Or does AutoZone have one of those programmers you can rent? Just curious.
I am thinking of replacing my exhaust with pipe and an aftermarket muffler from autozone, and I just want to be prepared. There's no way in hell I'm paying $400 for something I can do myself.
2009 Compass Rallye
"Free lovin' don't cost a dime"
lidhead is offline
post #12 of 13 Old 10-26-2011, 01:26 PM
w4rh4wk
2011 MK Compass
autozone isnt going to know how to performance tune your PCM. you need to find a dyno tuner in your area that does mopar. FYI dyno tuning can cost up too $400 because they might require you to buy PCM programer. Why do you need a dyno tune when doing PCM performance upgrade? Because you DO NOT want your car running too rich or too lean. This is why i never liked cookie cutter programming kits for any car's computer.... every car is different!
w4rh4wk is offline
post #13 of 13 Old 10-26-2011, 07:11 PM
tjkj2002
2002 KJ Liberty
You send your PCM to a place like in the link below.....
http://www.bgperformancepcm.com/
And yes expect to pay about $400 for the tune and kiss any warranty good bye.
tjkj2002 is offline
Need advice on exhaust system armystrong68w Jeep Compass & Patriot Forum 7 03-24-2011 01:02 PM
tell me a bit about the patriot 4wd system zippome Jeep Compass & Patriot Forum 9 02-28-2010 06:35 PM
new system last monday victory red Jeep Compass & Patriot Forum 3 09-07-2008 01:01 PM
Noobish question about Patriot 4WD system/ESP System zxjockey Jeep Compass & Patriot Forum 23 04-13-2008 01:41 PM
Patriot Interior Scratch Easy? 79bigmack Jeep Compass & Patriot Forum 6 10-12-2007 11:40 PM
