Euro models - which CRD engine? - JeepForum.com
post #1 of 9 Old 07-04-2010, 06:10 PM Thread Starter
tfmr
2010 JK Wrangler
hello!!
i was reading about de VW engines, and there are 3 versions of the 2.0 tdi 140hp engine:
2.0 TDI PD, 47-103kW 8 valves (PD = Pump duse)
2.0 TDI PD, 103-125kW 16 valves
2.0 TDI CR, 81-132kW 16 valves (CR = Common Rail)
i know that my 2008 patriot has 103kw, doesn't have DPF and... which engine version?
tfmr is offline
post #2 of 9 Old 07-05-2010, 02:55 PM
merlinTec
merlinTec's Avatar
Hi
it's the PD engine 16valve
UK Chrysler Jeep Master Tec.
merlinTec is offline
post #3 of 9 Old 07-06-2010, 06:39 AM Thread Starter
tfmr
2010 JK Wrangler
Originally Posted by merlinTec View Post
Hi
nice to know
so far, so good, 33k km and fuel consuption at 7,0l/100km; (33.6 mpg)
oil = +/-1 litre for 10k km (621miles)
tfmr is offline
post #4 of 9 Old 11-07-2010, 03:35 PM Thread Starter
tfmr
2010 JK Wrangler
engine problems
Hi there!!
This week, my Patriot started to misfire and gets "lumpy" in cruise speed's, and in acceleration, but only sometimes! When it does, it takes about 0,5 seconds, and more common in 5th or 6th gear... i'm thinking... hmmm maybe fuel injection problems?
Another thing, when it starts(only) in the morning, makes a lot of smoke...
Warranty is over... Any suggestions?
where can i see the engine code?
tfmr is offline
post #5 of 9 Old 11-07-2010, 06:25 PM
bumzo1
2005 WK
Originally Posted by tfmr View Post
nice to know
I really wish they'd let us have diesel engines in the US. My gas V6 grand is lucky to get 15mpg
'05 WK 3.7L | OME MD lift | 255/75/17 BFG M/Ts | 20" LED Light Bar
Khaki WK Club Member #1
bumzo1 is offline
post #6 of 9 Old 11-08-2010, 12:19 PM Thread Starter
tfmr
2010 JK Wrangler
bumzo1, here the cherokee of your avatar has a 3.1 turbo diesel (CRD) V6 engine, with 216hp but, too much money... about 90.000 usd
oh well... and about my "lumpy" patriot? any suggestion?
tfmr is offline
post #7 of 9 Old 11-08-2010, 12:46 PM
merlinTec
merlinTec's Avatar
Hi
You need to get the fuel pressure checked. Has the fuel filter been changed? The filters from factory some were incorrectly routed so have a look at the arrows on the filter make sure the arrows on the filter point the correct way the fuel should flow.
post #8 of 9 Old 11-08-2010, 01:51 PM Thread Starter
tfmr
2010 JK Wrangler
hi!
Didnt check the fuel filter yet, i'll take a look tomorrow
He has 23.000 miles, and made the Jeep Service at 18.500miles. They changed the oil, air and pollen filter, but no fuel filter. At the 9500 miles service didn't changed the fuel filter either, so it's the same one since 0 miles!
At how many miles is suposed to change the fuel filter in the CRD engine?
Hopefully is just the filter because if it's the injection system... its going to be bad $$$$$
Just 1 thing i dont understand.... why this "lumpy" thing only happens sometimes?
tfmr is offline
post #9 of 9 Old 11-08-2010, 03:21 PM
merlinTec
merlinTec's Avatar
Hi
The fuel filter is at 27 miles in the UK (3rd service) service every 9.000 miles. Lumpy could be because the fuel filter is blocked due to incorrect routing of the pipes.
compass , crd , diesel , engine id , export , patriot
Chrysler announces Dodge Caliber, Jeep Compass recall 2007 models w4rh4wk Jeep Compass & Patriot Forum 8 06-29-2010 05:32 PM
TPMS on a euro pat keithark Jeep Compass & Patriot Forum 1 06-30-2008 04:11 AM
Chrysler's Project Genisis: Cutting models and consolidating unclejjg Jeep Compass & Patriot Forum 19 02-18-2008 12:06 PM
2007 Patriot Models... Dealer Deals? safaribabe Jeep Compass & Patriot Forum 7 09-12-2007 12:07 PM
Mopar Radios patroit Models vs Dodge Mopar? belezeeubub Jeep Compass & Patriot Forum 0 08-20-2007 11:02 AM
