ERROR CODE P0700 help if you can - JeepForum.com
post #1 of 5 Old 04-05-2014, 06:51 PM Thread Starter
ericgormley713
Driving home from work, my 2007 jeep compass began to redline and wouldn't shift out of 1st gear (automatic transmission). The check engine light came on and I had to drive it home in limp mode. I'm hoping it's something simple, so please help if you have experienced this or know what is going on. The error code i received from autozone is "transaxle control system fault." Let me know what you think and thanks for your help
ericgormley713 is offline
post #2 of 5 Old 04-06-2014, 06:12 AM
festerw
festerw's Avatar
Unfortunately that's just a generic code you'll need to have a garage with a proper scanner read the fault codes from the transmission control module.
Hers - 2011 Dodge Durango Crew
Mine - 2003 Jeep Wrangler X
1998 Jeep Cherokee Classic
festerw is online now
post #3 of 5 Old 04-30-2014, 09:27 AM
RHartfiel
My wife's 2007 Compass did pretty much the same thing this past weekend. She was able to override the "limp home" mode by turning off the engine and restarting it but it would eventually do it again. I thought it was a CVT+4 fluid issue as we had not serviced the CVT Transmission yet, so I topped it up with a couple of litres last night but that didn't help. It will not exceed 40kms per hour but it seems to run smoothly with no noises or clunking at all. She has around 122000 Kms on it to date. Any assistance would be appreciated.
RHartfiel is offline
post #4 of 5 Old 05-09-2014, 01:40 PM
RHartfiel
Turned out to be a wiring issue. The wiring harness that runs along the drivers side fender was rubbing at one of the cut outs and wore though the sheathing of three wires. One to a point of a single strand of wire (this was the main communication wire between the CVT and the Computer that caused the Communications error and the engine light to come on and engaged the Limp Home mode). Replaced the wires and communication was restored and the error cleared. Had the Fluids and Filter changed while it was being serviced as well $600.00 later, it runs like a charm again with no more issues.
post #5 of 5 Old 06-11-2014, 07:52 PM
musichog
2010 MK Compass
I also had the P0700 code and further inspection received translates to code P161b
My problem had a simple fix.
The negative battery cable was loose. I guess after the recall they didn't tighten cable back. No more problem in 9 months
musichog is offline
compass , error code , transmission
