Engine Stumble on Acceleration TSB 18-031-07 - Page 6 - JeepForum.com
post #76 of 83 Old 04-11-2008, 03:46 AM
Jeepster55
Originally Posted by davep View Post
The TSB says the dealer is required by law to add a sticker with the indicated service next to the VECI label. If your build date is before April 21, 2007 and you don't have the sticker, it can be assumed you don't have this TSB.
My build date is on the inside of the driver's door, and my VECI label is on the inside lip of the hood... I'm assuming they stick 'em in the same spots on all compasses.
- Dave
if the sticker can't be found anywhere, any dealer can check Chrysler's DealerConnect with the VIN to see if that has already been done. just a phone call to check FIRST and if it's NOT been done, then make an appointment to 'git er dun'...........
Jeepster55 is offline
post #77 of 83 Old 04-15-2008, 09:49 PM
davep
2007 MK Compass
I just wanted to follow up; I had asked if this TSB fixed the coasting stumble that I was experiencing. Most of the information about this reprogram was related to only throttle response, not coasting.
I'm happy to report that my coasting stumble has been all but eliminated with this reprogram. On my drive home tonight I wasn't really paying attention to it, just to see if I'd notice it like I have noticed it every night... and I didn't. I just drove around the block a few times, trying to reproduce the problem, and I really can't.
Throttle response is MUCH better now, I'm no longer nervous about pulling into traffic from a stop... It is going from one extreme to the other though, I'll have to re-learn things a bit - I'm giving it way too much gas now; and boy... it really can push ya into your seat!
This might've been touched on in another thread, but the CVT2 seems to "emulate" a standard auto gear shift between 20-25mph .. This was barely noticable before this TSB reprogram, but it's much more apparent now. Not nearly as much of a problem as the coasting stumble, but it sure seems like the whole purpose of the CVT2 was to ditch the idea of shift points. Anyhoo.. If you have an older build CVT, you must get this reprogram - if anything for being able to safely pull into traffic! ... but be prepared to force yourself to drive with a light foot, this change makes you want to race around!
davep is offline
post #78 of 83 Old 04-22-2008, 10:30 AM
ancona46
2008 MK Compass
it shows it effects 2007 models i have a 08 would the flash improve my compass at all?
ancona46 is offline
post #79 of 83 Old 04-22-2008, 10:40 AM
Gramps
The Necessary Evil
Gramps's Avatar
2007 MK Compass
The '08's should have the latest programming but it may be worth having the dealer check it if your having a problem.
Bob
posts 68 & 69
Also visit me at
Gramps is offline
post #80 of 83 Old 04-23-2008, 05:32 AM
k2qo
Gang,
Does this issue rear its ugly head with 08 models? I am on the verge of rolling into the dealership with a wheelbarrow of cash for an 08 Pat/FD1 and I'd be damn mad if I bought a new ride KNOWING this would likely be a problem.
Best regards,
Mark
Clarence, NY
k2qo is offline
post #81 of 83 Old 04-23-2008, 05:53 AM
Gramps
The Necessary Evil
Gramps's Avatar
2007 MK Compass
No, no, no! This was an early programming change on those built on or before 4/07, just look for the build date on the Drivers Door Jam. Anything after that has the new programming.
Bob
posts 68 & 69
Also visit me at
Gramps is offline
post #82 of 83 Old 04-23-2008, 11:07 AM
k2qo
Thanks Gramps,
I was hoping the answer was simple. I'm going to do a long test drive this afternoon.
Mark
k2qo is offline
post #83 of 83 Old 09-26-2016, 09:10 AM
kmb1229
Hi all. I've read all the previous postings to get info on the problems I'm having with my 2008 Jeep Compass. I'm hoping that some of you are still out there and will respond and have advice for me. I'm having the hesitation with acceleration, too. I've taken it to a couple shops as well as a dealer and no one can seem to figure out what is happening. Just this morning on the way to work, I was on the highway and twice it hesitated and then jerked forward. I was going 50+ mph. It happens at slow and faster speeds. There was some after-market equipment installed prior to when I bought it a year ago. There was an after-market stereo, amp, lights (inside and underneath), and speakers. One shop thought that the wiring may have been effected when the new stereo was put in. Several months ago, I had a different stereo installed, but these problems started before the new install. I was told by one shop that the throttle position was ok. Does this mean that I need the TSB done or the ECU and TCM units flashed? Or could these problems be related to the after-market installs?
kmb1229 is offline
Engine coolant compass plunderisley Jeep Compass & Patriot Forum 5 02-26-2009 05:14 PM
Another acceleration issue... Elihawk Jeep Compass & Patriot Forum 9 06-10-2008 04:34 AM
Does the acceleration TSB Elihawk Jeep Compass & Patriot Forum 3 05-14-2008 04:48 PM
CRD blown engine merlinTec Jeep Compass & Patriot Forum 6 01-12-2008 04:11 PM
2.0 Engine jeepray Jeep Compass & Patriot Forum 7 08-21-2007 03:47 PM
