Quantcast Engine Block Heater... Where is the plug? - JeepForum.com
Go Back JeepForum.com > Models > Compass & Patriot Forum > Engine Block Heater... Where is the plug?
DISCOUNT - Chromoly Front Axle Shaft Kits, 87-95 YJ's, 97-GR8TOPS Introduces the Exogate HD Tire CarrierTruck-Lite's New LED Headlamp Series
Old 12-30-2009, 03:05 AM   #1
cj3bandtj
My jeep patriot came with an engine block heater. I've never really looked to see where I plug it in. Any one know?
Thanks!
cj3bandtj is offline   Reply With Quote
Old 12-30-2009, 07:08 AM   #2
Gramps
The Necessary Evil
Gramps's Avatar
2007 MK Compass
The cartridge type block heater is mounted in a bore at the rear of the block (drivers side) under the coolant adapter. The block heater does not directly contact coolant. It heats the aluminum block.
The heater is powered by 110 Volt AC through a power cord and connector. You may have to remove the engine cover (I don't think so) and the Air Cleaner Inlet/Battery Cover and there should be a 110v plug somewhere around there.
Why do you need an engine block heater in AZ? Are you in Flagstaff or the White Mountains?
Bob
MK Skid Plate fasteners for sale posts 68 & 69
Also visit me at Photobucket
Gramps is offline   Reply With Quote
Old 12-30-2009, 08:50 AM   #3
cj3bandtj
Found it, thanks. It ended up being on top of the front driver side wheel well.
I was in AZ where I bought the jeep, but now I'm back in upstate NY and its getting cold. I still don't know why I transfered away from the sunshine, right into a NY winter.
The jeep was a custom order that someone canceled on. For some reason they wanted a engine block heater, FDII, and no power locks or doors.
Old 12-30-2009, 10:39 AM   #4
Gramps
The Necessary Evil
Gramps's Avatar
2007 MK Compass
Sounds like a nice rig that will do you well up there. I left AZ the summer it hit 117 in Tucson but my bones are older now and get cold easily. I'm thinking about becoming a snowbird.
Bob
Glock Forum
