Electronic Throttle Control (ETC) - JeepForum.com
post #1 of 8 Old 04-27-2009, 10:59 AM Thread Starter
the mad hatter
After doing a 6 hour drive, the ETC light as well as the ESP light came on a few seconds after I pulled into the garage and was about the shut the patriot off.
The next day I drove it and there was no light and no noticeable difference in performance. Drove it again this morning and again no light.
Has anyone else ran into this?
I'm wondering if I should still have it checked out even though the light hasn't come back?
My rig: 2007 Patriot Limited, Auto, 4x4, FDI, CVTII, 13k miles.
'05 Jeep Wrangler X
'07 Jeep Patriot Limited
the mad hatter is offline
post #2 of 8 Old 04-27-2009, 02:23 PM
Gramps
The Necessary Evil
Gramps's Avatar
2007 MK Compass
Are you able to pull any codes? That's the first thing that the dealer will look for.
http://www.wjjeeps.com/faultcodes.htm
Bob
posts 68 & 69
Also visit me at
Gramps is offline
post #3 of 8 Old 04-27-2009, 03:15 PM Thread Starter
the mad hatter
I haven't tried to check that yet. But there is no check engine light or anything. The ETC light only came on that one time at the end of our trip and I haven't seen it again. Just for good measure yesterday I did the relearn procedure for the accelerator.
It may just be a fluke. We'd driven 6 hours, mostley on cruise control in high winds so my RPMs were abnormally high most of the trip to compensate. And when we got home I was about 30 miles from an empty tank.
'05 Jeep Wrangler X
post #4 of 8 Old 01-08-2010, 12:10 PM
Rculv
Electronic throttle control
This is exactly what just happened to me for the second time after a four hour drive in my 2007 Compass. Ever figure out what it is?
Rculv is offline
post #5 of 8 Old 01-08-2010, 12:40 PM
Gramps
The Necessary Evil
Gramps's Avatar
2007 MK Compass
We would need the "P" code to really break it down and trouble shoot it. Unfortunately the key on/off method doesn't appear to work on the MK's so a trip to a parts store or dealer to run the codes wound be necessary.
HOWEVER! We have found that, for whatever reason, the sensor are lost in trying to find the minimum and maximum positions. In several cases this has been do to the TPS freezing up during an extended trip in very cold weather.
This is written concerning the CVT operation but is also used to reset the TPS in some cases. It's worth a try if it continues to act up. http://www.jeepforum.com/forum/f98/i...sponse-564386/
Bob
posts 68 & 69
Also visit me at
Gramps is offline
post #6 of 8 Old 04-15-2011, 10:57 AM
dommy92
I had this problem last Sat night. I just took my Patriot in just this morning. I am hoping that it isn't going to be anything too big. From the sounds of everyones comments, no one had a major issue. Fingers crossed Mad hatter....I have the same exact car as you.
dommy92 is offline
post #7 of 8 Old 04-15-2011, 03:07 PM
Gramps
The Necessary Evil
Gramps's Avatar
2007 MK Compass
If people would leave some feedback ... I haven't heard of a solution except I do remember reports of the TPS freezing up on long trips in the winter but you're in San Diego, I just don't think that's your problem.
Bob
posts 68 & 69
Also visit me at
Gramps is offline
post #8 of 8 Old 04-19-2011, 03:56 PM
Nabis
Mine has frozen up on a long trip. Stuck the throttle body open. Dealer replaced the throttle body, even though I don't think it was actually defective. However, this hasn't happened since, and this was years ago.
Nabis is offline
P2100 code - Electronic Throttle Control and ESP Lights ninjaneer83 Jeep Compass & Patriot Forum 52 11-18-2016 12:46 PM
Electronic Throttle Control (ETC) & Power Loss Tuksonrider Jeep Compass & Patriot Forum 2 12-21-2013 11:09 AM
Bad Throttle response lidhead Jeep Compass & Patriot Forum 4 01-09-2010 09:39 AM
Part-Throttle Whistling, Beep? b1llyw Jeep Compass & Patriot Forum 3 09-21-2009 04:45 PM
Carbon Build-up Throttle Body Mistyfate Jeep Compass & Patriot Forum 13 02-03-2008 05:13 PM
