Early Oil Change and Related Issues - Page 7 - JeepForum.com
post #91 of 160 Old 08-18-2007, 01:04 PM
snood
snood's Avatar
2007 MK Compass
Oil Filter
What are you guys using for oil filter?
'07 Compass -> I apologize to the next owner.
snood is offline
post #92 of 160 Old 08-18-2007, 01:27 PM
CoriolisSTORM
WHAT?!
CoriolisSTORM's Avatar
2010 JK Wrangler
I think next time I'll try to find the official Mopar one, haven't gotten to 12k yet on mine.
1998 TJ Wrangler SE - Stone White, 2.5Ls of screaming lifter clacking power, AX5, 31" BFGoodrich All Terrain T/A KOs
2010 Wrangler Unlimited Sahara - Deep Water Blue, 3.8Ls of oil consuming fury, NSG-370, BFGoodrich Rugged Terrain T/A 265/70/R18s
CoriolisSTORM is offline
post #93 of 160 Old 08-18-2007, 04:42 PM
steel5blue
2007 MK Compass
Could find only Fram for first change, now using Purolator L12222 w/ Mobil1 5w30.
Rav-who? CR-what? Arizona-where?
2007 Compass Sport Steel-5speed-Blue 4X4
steel5blue is offline
post #94 of 160 Old 08-26-2007, 07:12 PM
snood
snood's Avatar
2007 MK Compass
I found a Mobil1 Filter @ Advance Auto Parts
snood is offline
post #95 of 160 Old 08-26-2007, 07:37 PM
Gramps
The Necessary Evil
Gramps's Avatar
2007 MK Compass
The NAPA filters are available now, 7073, same as WIX 57073. I had the local store get one for me from the warehouse, next day service. Chrysler still uses the recommended oil change s as stated in the maintenance schedules, regardless of what oil you are using.
Bob
posts 68 & 69
Also visit me at
Gramps is offline
post #96 of 160 Old 11-01-2007, 05:27 AM
Gav'spurplez
Oil change.....................
So my g/f has the 2.4L Patriot sport and I'm planning on an oil change. how many quarts does the engine take "WITH" changing the filter ???
i asked her to check her manual, but i'm not too sure she'll look in the right place. I want to buy the oil and filter ahead of time.
thanks
1998 Camaro Z/28
1 of 95 in Bright Purple Met.
Basic bolt-ons and 17in DRs.
1999 Wrangler Sport - SOLD
2009 Nissan Frontier Pro-4X
Gav'spurplez is offline
post #97 of 160 Old 11-01-2007, 05:34 AM
Gramps
The Necessary Evil
Gramps's Avatar
2007 MK Compass
Go back to the beginning of this thread. I think that you'll find all of you answers.
Bob
posts 68 & 69
Also visit me at
Gramps is offline
post #98 of 160 Old 11-02-2007, 07:55 AM
LibertyLimited
An interesting thread. I never knew an oil change could be so complicated. I have used the 5000 mile oil change interval on all of my vehicles regardless of brand and engine for the past 45 years. I have never had an engine problem with any of them including those that ended up with over a 100K miles on them when I traded them off. I have always used a good quality oil and oil filter in all my vehicles and I guess that really works.
LibertyLimited is offline
post #99 of 160 Old 11-02-2007, 05:11 PM
Gav'spurplez
replying to a post found on page 3-5
i change my oil every 3K miles or 3 months, even when my camaro sits over winter. it gets started and possibly driven here and there. so even with a mobil 1 oil change, if it is 3 months later and it has 200 miles on it,
it is getting changed
changing the oil in my g/f's patriot tonight,
her filter is like a mini wrangler filter
1998 Camaro Z/28
post #100 of 160 Old 11-03-2007, 10:57 AM
Gav'spurplez
that manufacturer installed filter was a MF'er
but the 1st oil change went well. 5w-20 mobil 1 and a mopar filter.
manual states 4.5 qts with a filter change,
but this thread states 5
not to mention is seemed like only 3-4 came out. no leaks, weird ??
1998 Camaro Z/28
post #101 of 160 Old 11-03-2007, 11:48 AM
Gramps
The Necessary Evil
Gramps's Avatar
2007 MK Compass
I haven't changed my own oil yet. My first oil change was in Albuquerque and when asked they said that it took a full 5 qts.
That is strange. Did you check to see if was low before the drain? I only added the oil cooler recently and it could add a cup or too also. It may be best to add 4.5 qts and check it before adding the rest.
Bob
posts 68 & 69
Also visit me at
Gramps is offline
post #102 of 160 Old 11-11-2007, 06:08 PM
snikr
Oil changes on our Compass took 5 qts.
Tom
2010 Subaru Forester
2004 Dodge Dakota 4 X 4
So many roads.......So little vacation time
snikr is offline
post #103 of 160 Old 11-14-2007, 09:41 AM
sheriffav8r
Oil Reminder Light and Change Intervals
My '08 Patriot 4x2 manual says that 6K miles are fine for oil changes and that sounds good to me. I use 7,500 miles between changes for my '01 Ram 2500 Diesel and it has 165,000 miles on it with no problems.
The manual says that there is an Oil Reminder message after a certain number of cycles. Does anyone know what that number is? My '05 Honda Odyssey had an oil remaining percentage on it and I assume it worked on the same prinicple of engine cycles.
sheriffav8r is offline
post #104 of 160 Old 12-04-2007, 06:15 AM
indianrefining
Havoline 5W-20 and a Purolator PureOne filter!
indianrefining is offline
post #105 of 160 Old 12-09-2007, 01:22 PM
Jeepster55
Question:
why do so many of you use something 'other' than the OEM Mopar Oil Filter? Price? Availability? Doesn't come in the right color?
just curious....i've ALWAYS used factory filters, regardless if it were a Mopar, Toyota, Honda, Gm or Ford....
Jeepster55 is offline
Oil change indicator Trek620 Jeep Compass & Patriot Forum 25 11-24-2009 02:14 PM
Early Change Oile Message wesleyd Jeep Compass & Patriot Forum 10 11-05-2009 05:32 PM
Oil Change pshingle Jeep Compass & Patriot Forum 13 07-02-2009 12:15 PM
Early Production Compass with black muffler? phil8400 Jeep Compass & Patriot Forum 13 03-17-2008 04:53 PM
How to change out the radio?? lynnk Jeep Compass & Patriot Forum 10 11-01-2006 05:50 PM
