Early Oil Change and Related Issues - Page 11 - JeepForum.com
post #151 of 160 Old 05-21-2008, 06:23 AM
Ridin' Around
Originally Posted by deepnite10 View Post
i took the test at the mobil1 site and they recommended
10-30W..
http://www.mobiloil.com/USA-English/...leChooser.aspx
has anyone heard what harm may will result to oil seal s when used over a long period of time?
If someone has lead you to believe that seal damage may come from synthetics, that is not the case. All synthetics that I know of are using an additive package that actually helps seals stay "soft" or plyable, helping them seal better. The oil seal leak thing is a old wives tail, decades ago the early attempts at Synthetics did have some issues but they have long since been resolved. I know this to be a fact with Amsoil's products.
Ridin' Around is offline
post #152 of 160 Old 05-21-2008, 08:42 AM
acadian
2008 MK Patriot
I have always changed the oil in my vehicles. 5-6 quarts of oil, a filter, socket wrench and a beer... always thought that was a nice combination on a Sunday afternoon. But I actually have this plan with my Jeep dealer that says if I let them do all my oil changes and tune-ups, they will buy me a brand new set of tires after 30k miles. I did the math and figured that the money I'd be spending on changing the oil myself (minus the beer), spark plugs, etc... I'm basically getting a free set of tires when I need them.
acadian is offline
post #153 of 160 Old 05-21-2008, 08:58 AM
Zappy
2007 MK Compass
Just last night I switched my wife's Hyundai over to the full synthetic Amsoil with the recommended AEO filter after running the engine flush through it for 20 minutes as instructed. I noticed immediately after the change that the car idled much smoother and quieter then it was. I was using Valvoline MaxLife and it was just changed last month, the car is a 99 with just a hair under 140K miles and the engine hasnt sounded this smooth in a while and it seemed to have more pep or perhaps I should say not as sluggish and the only thing that was changed is the oil.
I'm planning on switching my Compass over before the heat of the summer, but as someone previously mentioned, I dont see an AEO filter for the Compass in the online product application guide, just a WIX filter listed. If the pure synthetic is used but no AEO filter, would you just change out the WIX filter every 3000 miles and then the full oil at 25000 (or most likely 24000 to make it easy) make the difference? If amsoil doesnt have the breakdown problems of the other oils usually used, how often should a normal filter need to be replaced? Every 3000? 5K or even 7K?
Just curious as I see this as being the only issue currently with switching the Compass over.
Zappy is offline
post #154 of 160 Old 05-21-2008, 04:14 PM
Gramps
The Necessary Evil
Gramps's Avatar
2007 MK Compass
Ditto, I've got the same question. I was going to use the NAPA Gold (same as WIX) until they start making the AEO, but how often should it be changed?
Bob
posts 68 & 69
Also visit me at
Gramps is offline
post #155 of 160 Old 05-22-2008, 05:08 PM
deepnite10
thank s Ridin..the dealer said the same thing yesterday..
as i said i would..i did talk to the service manager out here..they do use and recommend
the 5-20W..addtionally if you use ur Patriot s on off road condition s you should
change the oil every 3k..otherwise change the oil every 6k..
at one point they recommended changing oil every 3k or 3mos. whatever come s first..
now it s 6k/6mos..
deepnite10 is offline
post #156 of 160 Old 05-25-2008, 08:46 AM
Gramps
The Necessary Evil
Gramps's Avatar
2007 MK Compass
I found this on the Amsoil site about WIX Filters.
The highlight of this in what we've been talking about on non- EA filters is WIX filters are supplemental to AMSOIL Ea filters, but now AMSOIL will offer WIX filtration products that cross to an Ea filter. With the exception of WIX lube filters, all WIX filters should be changed in accordance with original equipment manufacturer’s (OEM) recommendations. WIX lube filter change intervals are extended OEM recommendations to match the drain intervals of AMSOIL XL Motor oil. To find the correct filter for your application, consult the Online Product Application Guide.
Ridin' Around's site with links to AMSOIL Online Store and some good reading material.
Bob
posts 68 & 69
Also visit me at
Gramps is offline
post #157 of 160 Old 05-26-2008, 05:34 PM
Zappy
2007 MK Compass
So the WIX filters would be used at a 7500 mile drainage interval as if being used with the XL oil. So if the full sythentic was being used with the 1 yr /25K mile drainage interval, the filter should be changed roughly every 7.5K miles during the year and retop off the oil then from what is lost from the filter change?
Zappy is offline
post #158 of 160 Old 05-27-2008, 09:06 PM
Ridin' Around
7000 views on this thread, Awesome. Thanks for your support Patriot and Compass owners! Gramps Kudos!
post #159 of 160 Old 05-28-2008, 04:43 AM
Gramps
The Necessary Evil
Gramps's Avatar
2007 MK Compass
That's what I'm planing on doing until the EA filter is available. The tiny filter that we have can't hold anymore than 1/2 a qt at the most.
I'll be getting the ASL 5W30 to cover the 3 rigs that I'll be doing. All of my oil changes will be a once a year thing (not in the Winter) at (about) $50 a shot. Less $$ and less labor. Sounds good to me.
Bob
posts 68 & 69
Also visit me at
Gramps is offline
post #160 of 160 Old 05-28-2008, 08:20 AM
Zappy
2007 MK Compass
I asked the dealer that I got the oil for the the Hyundai through and he basically confirmed what you say Gramps.
"Hi Joe, thank you for the detailed update. Your business is much appreciated and that is great you noticed a difference with the 10W-30. Since we do not have an EAO filter for your Jeep, what I recommend is to run the ATM and change the Wix filter at Wix recommendations, generally 6 months/7500 miles. The filter is easy to change and then you just do a top off of the oil. I am sure that there will be an EAO at some point."
So at least we'll all be on the same page as far as filter change/maintenance schedules going at 6 months/7500 miles with the WIX filters. I see another order going in on payday this week.
Zappy is offline
Oil change indicator Trek620 Jeep Compass & Patriot Forum 25 11-24-2009 02:14 PM
Early Change Oile Message wesleyd Jeep Compass & Patriot Forum 10 11-05-2009 05:32 PM
Oil Change pshingle Jeep Compass & Patriot Forum 13 07-02-2009 12:15 PM
Early Production Compass with black muffler? phil8400 Jeep Compass & Patriot Forum 13 03-17-2008 04:53 PM
How to change out the radio?? lynnk Jeep Compass & Patriot Forum 10 11-01-2006 05:50 PM
