Early Change Oile Message - JeepForum.com
post #1 of 11 Old 11-02-2009, 06:37 AM Thread Starter
wesleyd
2009 MK Compass
Early Change Oil Message
Just curious as to how often other peoples change oil light comes on. Mine came on after 4200 kms and then again the other day at 8400 km. I changed the oil both times but was wondering if most people just reset it and change the oil at the recommended mileage intervals. Also would using synthetic oil allow the message to come on less often.
Thanks
Wes
wesleyd is offline
post #2 of 11 Old 11-02-2009, 08:46 AM
Deezelweazel
It depends on driving habits and oil specs. The computer has no lab inside- so it calculates on standby, driving and driving time, and and oil spec settings.
Do you do a lot of short distance driving?
Go hard, go Diesel! - Turbocooled and Intercharged...
Deezelweazel is offline
post #3 of 11 Old 11-02-2009, 11:16 AM Thread Starter
wesleyd
2009 MK Compass
Mostly city driving trips under 20km
wesleyd is offline
post #4 of 11 Old 11-02-2009, 11:49 AM
miketmx
2015 MK Patriot
I live in Canada and I use synthetic oil and change oil religiously at 8k KM or 5k miles (mix of highway and city driving). I reset the oil change indicator myself by following the simple procedure in the owner's manual.
miketmx is offline
post #5 of 11 Old 11-03-2009, 06:55 AM
schoat333
2008 MK Patriot
I get the change oil message every 2500 miles. I just reset it, and change it every 2nd time (5000 miles) using mobile 1.
schoat333 is offline
post #6 of 11 Old 11-03-2009, 07:16 AM Thread Starter
wesleyd
2009 MK Compass
I think that is the method I will use. Just wanted to see if anyone else was doing this. Every 5000 miles is fine (about 8000km). I will use synthetic as well to see if this lengthens the frequency the message comes on.
Thanks
wesleyd is offline
post #7 of 11 Old 11-03-2009, 08:38 AM
rktmanfj
At 4000 miles, I have yet to see an oil change light.
Randy T
Indy
rktmanfj is offline
post #8 of 11 Old 11-04-2009, 04:39 PM
howdy246
2008 MK Compass
Its set to come on for the first time around the 10,000km mark and then aprrox. every 10,000km after its been reset. Just because you changed the oil doesn't automatically reset the counter.
howdy246 is offline
post #9 of 11 Old 11-05-2009, 01:31 PM
vulcanbmk2
The UK spec Patriot doesnt have an oil change Indicator---We just go by the book & use Recommended synthetic every 7500 miles or 9000 miles for the Diesel.
THE PAST IS ANOTHER PLACE !! THEY DO THINGS DIFFERENTLY THERE .
vulcanbmk2 is offline
post #10 of 11 Old 11-05-2009, 04:23 PM
miketmx
2015 MK Patriot
I thought the UK was metric same as Canada ?? My owner's manual says Never go past 10,000 km or 6,000 miles for an oil change for the gasoline engine.
miketmx is offline
post #11 of 11 Old 11-05-2009, 06:32 PM Thread Starter
wesleyd
2009 MK Compass
The manual states every 10000km to change the oil or when the indicator comes on, there is a change oil message that comes on whenever the oil gets dirty. Here in Canada conventional motor oil is recommended. In UK and Europe for some reason the grade of oil we use here in the same engine is not recommended over there. I will be switching to synthetic next change for sure.
wesleyd is offline
Oil change indicator Trek620 Jeep Compass & Patriot Forum 25 11-24-2009 03:14 PM
Oil Change pshingle Jeep Compass & Patriot Forum 13 07-02-2009 01:15 PM
Help: Check TPM system message plunderisley Jeep Compass & Patriot Forum 7 06-08-2009 05:57 PM
Early Oil Change and Related Issues 90XJ02TJ Jeep Compass & Patriot Forum 159 05-28-2008 09:20 AM
Early Production Compass with black muffler? phil8400 Jeep Compass & Patriot Forum 13 03-17-2008 05:53 PM
