DVD NAV Display Problems - JeepForum.com
post #1 of 3 Old 09-08-2008, 01:09 PM Thread Starter
ryotito
The display for my DVD NAV does not automatically dim when I turn on my headlights. The dealer says this is normal. In order for me to dim the display I have to come to a complete stop, put the car in park and manually reconfigure the system. Does everybody have to do this or is my system not correctly installed.
Thanks for your replies.
Ryotito
ryotito is offline
post #2 of 3 Old 09-08-2008, 03:56 PM
RGTrain
What you have to do is, on your left stalk with your light switch on it you have to turn the dimmer switch down from the highest setting. I had the same problem, when I turned it down from the highest click, the Nav dimms with the headlights.
RGTrain is offline
post #3 of 3 Old 09-08-2008, 05:45 PM
Gentleman
2008 MK Compass
If your nav is the REC system, go into the menu option and see if the brightness is set to automatic, there is an option to set the brightness and if I remember correctly you can set it to a particular brightness or automatic which will dim when the headlights are turned on, at least that's the way mine works
Bob
2008 Compass Sport Jeep Green 2.4 L CVT
2005 Liberty Limited Black 3.7 L
Gentleman is offline
key-ignition problems? mashnost Jeep Compass & Patriot Forum 14 06-27-2017 11:13 AM
Starting problems zing43 Jeep Compass & Patriot Forum 7 01-10-2010 08:11 AM
Not display the correct outside temperture (+/-10 degree) on the dashboard display thecat Jeep Compass & Patriot Forum 11 01-16-2009 03:47 PM
alternator problems umopp Jeep Compass & Patriot Forum 0 12-17-2008 03:02 AM
Changing Odometer to display Kilometers thom44130 Jeep Compass & Patriot Forum 0 11-06-2006 10:29 AM
