Is this dumb? Spare tire question? - Page 2 - JeepForum.com
post #16 of 30 Old 03-07-2008, 03:27 AM
Jeepster55
on the other hand, i DID find this when i 'googled' "Moab"
**MOAB - Massive Ordnance Air-Blast Bomb** (also referred to as the "Mother Of All Bombs")
Jeepster55 is offline
post #17 of 30 Old 03-07-2008, 04:06 AM
Urr
Originally Posted by JLink View Post
...the 30 additional pounds of the tire and wheel.
I think you are too optimistic. 30 pounds = 13,6 kg.
When I changed my original 17-inch cast-aluminum wheels with summer tires (215/60R17)
to 16'' steel wheels with winter tyres (215/65R16), then I did some practical research
17'' aluminium was 21 kg (46,3 pounds)*
16'' steel was 22 kg (48,5 pounds).
* This is not 100% accurate, I weighted myself with the wheel and without it, using my bathroom scale
PS. This practical research was done, because I had a discussion with my workmates on subject "How much lighter are actually the Light alloy wheels?". About the same results gave Seat Leon Cupra
Happiness is not a goal, but a lifestyle
Ex 2007 Jeep Compass Sport 4x4 CRD
DD 2011 Mitsubishi ASX Invite 4WD DiD
In bright and happy future: Jeep Wrangler
Urr is offline
post #18 of 30 Old 03-07-2008, 05:00 AM
Gramps
The Necessary Evil
Gramps's Avatar
2007 MK Compass
Some kind of swing out bumper mount would be the only way to go off of the back end and I've seem many license plates mounted to the spare when done like that.
OR if you did it from the trailer hitch you could always throw the spare in the trailer but that eliminates a bike rack but you could do that from the roof rack.
Bob
posts 68 & 69
Also visit me at
Gramps is offline
post #19 of 30 Old 03-07-2008, 09:02 AM
JLink
2007 MK Patriot
your right the tire itself weighs nearly 30 pounds... I was not sure how much the wheel weighed and decided to just use rough numbers to give you an idea but your right 45-50 pounds is closer to the truth and sounds much heavier.
--JLink (aka. JeepJim)
"Patriot Revolution" - 2007 Silver Patriot Sport 5 speed 4x4.
Mods: K&N AirCharger, RRO 2.125" Lift, Fuzion XTI 245/65R17's, a Blacked out muffler,
a Scan Gauge II and a Garmin GPSMap 60CSX
JLink is offline
post #20 of 30 Old 03-07-2008, 10:01 AM Thread Starter
rob_rector
2007 MK Compass
Fixa-a-flat and AAA ... hella light
'07 Compass Limited 4X4: K&N Air charger, Borla cat back exhaust, Rocky Road Lift kit, Firestone Destination A/T 245/65/17's, Red painted brake calipers, Pioneer AVIC Z2, Sirius, iPod interface, Polk Audio 6X9s (all 4 doors), Polk Audio Tweeters (dash), Polk Audio 6.5s (rear hatch), 2 Kicker CVR 10" Sub woofers in custom enclosure (hidden), Eclipse XA4000 4 channel & XA1000 1 channel amplifiers.
Peep my ride:
rob_rector is offline
post #21 of 30 Old 03-07-2008, 01:14 PM
JLink
2007 MK Patriot
fix a flat will ruin a tire... not to mention the TPMS.
JLink is offline
post #22 of 30 Old 03-07-2008, 03:50 PM Thread Starter
rob_rector
2007 MK Compass
I have heard that before too. Maybe the rack on top is not a bad idea
Peep my ride:
post #23 of 30 Old 03-07-2008, 05:38 PM
Jeepster55
the 215/65R17 Goodyear Wrangler SR-A's weight in at 28lbs each and the 17" alloys weigh 12lbs, for a total of 40lbs.
of course, you still have the weight of the wheel weights, valve stem, center cap and of course, AIR to consider.......
post #24 of 30 Old 03-07-2008, 05:40 PM
Jeepster55
.....or maybe a side mount spare tire, at the rear of the right quarter panel, where it wouldn't interfere with the gas door, license plate or tail lamp?
post #25 of 30 Old 03-07-2008, 06:23 PM
Argent33
2014 JK Wrangler
hmm 40 pounds - that may be a bit much to try and haul down out of the roof basket when you need it (without bouncing it off the side of the Compass on the way down)
~Paul
-[O l l l l l l l O]- 2014 Freedom Edition JKU - Hydro Blue 6-Spd
Argent33 is offline
post #26 of 30 Old 03-07-2008, 06:34 PM
Gramps
The Necessary Evil
Gramps's Avatar
2007 MK Compass
Maybe a 2 rail slider that you can pull back and then lower with the tire on it?
Bob
posts 68 & 69
Also visit me at
Gramps is offline
post #27 of 30 Old 03-07-2008, 07:14 PM
Jeepster55
OR get a 6 months membership to Golds Gym and work out!
just think.....in no time you'll be able to not only remove the 40lb spare from the roof basket, but change your MK's flat without the use of the JACK!!!!
post #28 of 30 Old 03-29-2008, 05:36 PM
fuzzyweis
2008 MK Compass
I'd like to find a nice way to mount the tire to the rear, most likely not on the hatch itself, possibly using a rear hitch assembly like a bike rack. This could also provide some extra rear protection in case of accidents, as it wouldn't be directly on the hatch.
The issue is needing to raise the rear hatch. Maybe have the wheel swing sideways to the ground fairly easy so the hatch can swing open, and non Gold's members can raise and lower the wheel on the side of the road. Possibly using struts and leverage similar to what the hatch has
What'd be really sweet is to get a rear fascia mod and hard cover for the tire so it could resemble the concept.
-Jim
'08 Compass Sport 4X4 CVT
fuzzyweis is offline
post #29 of 30 Old 04-02-2008, 05:34 AM
BrandoAZ
So back to the idea of a fuel cell.......
Can you actually buy one that is the size and shape of a spare tire? Seems like a good idea..... I honestly think I'd mount my spare on the back or top if it meant a tire's worth of gas extra...
So you all talked about the tires weight, but how many gallons are in a tire?
BrandoAZ is offline
post #30 of 30 Old 04-02-2008, 06:28 AM
CharBroiled
gallon of gas = 231 cubic inches.
volume of a cylinder = pi times the radius squared times the height.
so a tire shaped hole about the size of a 30 inch tire 7 inches deep (guessing - cant be bothered to actually measure the patriots spare tire well at the moment) holds about 21 gallons
2000 Cherokee Sport 4.0L Selec Trac - mine - for occasional wheeling
2007 Patriot 2.4L FD I 4x4 - wifes - doomed to rarely leave the street
CharBroiled is offline
Spare tire storage, larger than stock sizes Tony1911 Jeep Compass & Patriot Forum 4 06-22-2009 03:24 AM
Tire Pressure Monitoring System Question Kev M Jeep Compass & Patriot Forum 37 11-20-2008 08:08 PM
TPMS on Compact Spare? CoriolisSTORM Jeep Compass & Patriot Forum 15 06-06-2008 03:50 PM
Wheel and tire question on a 08 Patriot 90SaharaJeep Jeep Compass & Patriot Forum 7 04-30-2008 03:59 PM
Full Size Spare snood Jeep Compass & Patriot Forum 8 10-30-2007 02:05 PM
