Dealer Reflashed our PCM - JeepForum.com
post #1 of 6 Old 02-24-2007, 02:53 PM Thread Starter
hvac5777
Hi there, I am new here so I am not sure if this has been discussed yet, but I did look around and didn't see it. On 02/07/07 our check engine light came on and there was a lot of what I describe as valve noise coming from the top end. We took it the dealer immediately and the next day they called and said the PCM needed to be flashed. They did the work and I asked for a copy of the Technical Service Bulletin. Here it is...
SERVICE BULLETIN NUMBER: 18-020-06 REV. A
GROUP: VEHICLE PERFORMANCE
DATE: SEPTEMBER 16, 2006
SUBJECT:
FLASH: Warm Weather Spark Knock and/or DTC P2173 **and/or P0452**
OVERVIEW:
This bulletin involves selectively erasing and reprogramming the Powertrain Control Module (PCM) ** and if necessary, the Transmission Control Module (TCM)** with new software and performing a memory reset to clear the adaptive memory of the PCM.
MODELS:
2007 (PM) Caliber
**2007 (MK49) Compass**
Note: This bulletin applies to models equipped with a 2.0l or 2.4l gasoline engine and CVT transmission (sales code ECN or ED3 with DAV) built on or after May 11, 2006 (MDH 0511XX) through and including August 16, 2006 (MDH 0816XX)
SYMPTOM/CONDITION:
Some cutomers may experience Spark Knock in warm ambient conditions (16 C (60 F) or higher).
The technician may find one or more of the following DTC's
P2173 - High Airflow/Vacuum Leak Detected (Slow Accumualtion) may be found in the PCM. This DTC may occur when a vehicle is driven from a higher altitude to a lower altitude (1372 meter (4500 foot) change).
**P0452 - Evap Pressure Switch Stuck Closed**
It goes on to describe the repair procedure.
Anyway, they flashed the PCM and told me that essentially the engines timing was off. This may be why experienced only 18 - 20 MPG. However, that may be due to my extremely heavy right foot.
Hope this helps someone.
hvac5777 is offline
post #2 of 6 Old 02-24-2007, 03:59 PM
Gramps
The Necessary Evil
Gramps's Avatar
2007 MK Compass
Interesting! I'm watching for a recurrence of the engine light coming on with mine. Certainly NOT a warm temperature issue though. They have gotten the parts in at the dealership to replace the intake manifold, actuator and wiring harness but I am avoiding the "major surgery" because the problem appears to have gone away and I have yet to get a confirmation that this was definitely the issue or just suspected to be the issue.
Thanks for the post!
Bob
posts 68 & 69
Also visit me at
Gramps is offline
post #3 of 6 Old 02-24-2007, 04:21 PM Thread Starter
hvac5777
Yeah, ours didn't seem to be a warm weather issue either.... I don't know. My wife just came home and said come drive the car it's making a noise. I drove it, I think its the brakes, severe shuddering and a grinding noise. I am going to re- read the brake recall post and go to the dealer monday morning.
hvac5777 is offline
post #4 of 6 Old 02-24-2007, 04:26 PM
Gramps
The Necessary Evil
Gramps's Avatar
2007 MK Compass
Before the Compass was released, there were many Calibers with PCM problems and they had to replaced them not just flash them. It appeared that was all over and done with by the time the Compass came out. Good luck!!
Bob
posts 68 & 69
Also visit me at
Gramps is offline
post #5 of 6 Old 02-24-2007, 04:38 PM Thread Starter
hvac5777
Hmm thanks for the info, I just checked the Jeep recall site and I too found none waiting to be done. I forgot to mention I am waiting on a rear brake kit to come in. It has been on back order for months now. At first they whined in reverse on cold days. Now they are grinding and shuddering through the whole vehicle. I will post as soon as I learn something new.
hvac5777 is offline
post #6 of 6 Old 02-25-2007, 04:56 PM Thread Starter
hvac5777
Upon further inspection I noticed that there was some sheet metal hanging down from the undercarriage. This turned out to be some sort of heat shield/ noise dampener that is located directly over the rear u joint. I think a couple of weeks ago when we went off roading, we may have caught an edge of this shield and tweaked it slightly. Then a couple of days ago we hit a large pool of water, which we always like to do when it rains and it bent it further. It was actually making contact with the u joint and drive shaft. I bent back for now and I plan to remove it all together in the near future. We are still waiting for our rear brake kit from the dealer.
hvac5777 is offline
Local Dealer- no new cars Elihawk Jeep Compass & Patriot Forum 3 10-09-2009 07:30 AM
want to buy compass. good/bad and dealer invoice bringbackphish Jeep Compass & Patriot Forum 2 04-23-2009 08:48 AM
Letter from dealer states that first oil change is at 3k? 2broke2smoke Jeep Compass & Patriot Forum 7 06-22-2008 12:41 PM
Latest dealer visit snood Jeep Compass & Patriot Forum 16 05-25-2008 10:07 PM
Compass at the Dealer Today Jason31 Jeep Compass & Patriot Forum 22 04-25-2008 05:42 PM
