#1 | |
CVT2 Operation - Lurching
My Compass has the CVT2 Autostick. I've noticed that if you take your foot off the accelerator that the car slows down really fast ... almost like you have started putting the brakes on lightly. I find it annoying in traffic where you are speeding up a little and then foot off the accelerator because traffic slows down. When you start for feed accelerator again there is almost a jump to start picking up speed again... not a smooth transition. Is this normal operation for the CVT2? I had driven a Caliber before getting the Compass and I noticed it seemed to do that to.
LynnK 2007 Jeep Compass Limited CVT2 Autostick Remote Start RAQ Radio w/ Sirius |
#2 |
The Necessary Evil
![]() Join Date: Aug 2006
I had read that the CVT had those characteristic in many of the Caliber Road Tests. Going from memory, it has to do with the CVT shutting off the fuel more completely than a conventional automatic and that helps with engine braking and is part of the reason for improved gas mileage. By stepping back on the gas quickly the CVT will have a jerk to it getting to the right ratio. It was never said to be a mechanical problem, merely a quirk.
I have noticed this on the very few occasions during bumper to bumper traffic, too, but most of my driving is back roads with curves, turns and stops which are all anticipated. I do use it to my advantage but I drive it more like you would a go-kart, snow mobile or run a variable speed drill. The only time that I take my foot completely off the gas is when I intend to completely stop; otherwise I feather the throttle to give me the speed that I want. Since you have the Auto Stick you may want to experiment with just putting it in the right “gear” during heavy traffic that will let you run between 2 – 3K rpm and see if that helps. That way you may not have the jerk when starting back up. I’d be interest to hear if it helps or not. |
#3 |
Thanks for the feedback. I will try the Autostick suggestion. I assumed that this was just a quark of the CVT. I've also figured out that not taking your foot totally out of the throttle does help the problem... I assume with time I will learn to drive around the quarks. thanks again.
#4 |
need more lemon pledge
Have you ever driven a bus before? Just think of it as acting as a transmission retarder
![]() I wish I had a vehicle with a CVT. I might be buying a compass for my commuter vehicle when I graduate and comission in December.
Dash Mounted Video Camera |
#5 |
do all cvt2 have a "L" range?
#6 | |
The Necessary Evil
CVT2 - Caliber SE, SXT and Compass Sport (Drive only) CVT2L - Available on Patriot. Low range 4X4. No "L". "D" and 1-6 CVT2 w/Auto Stick - Caliber R/T and Compass Limited, optional on Compass Sport? (6 manually selectable electronic gear "ratios"). Lockable 4X4 High range on Jeep 4WD models. Last edited by Gramps; 03-03-2007 at 08:15 AM.. |
#7 |
Lurching when coasting...
I have an 08 Jeep Compass Sport 4x2 with the 2.4 L engine. When going between 25 MPH and 45 MPH, there is a slight but highly noticable lurching when I let up off of the accelerator.
What will happen is I will let my foot off the accelerator, it will coast for about 1 second and it will feel like the engine is downshifting. This only happens between the 25 and 45 MPH ranges. Is this normal? BTW, this forum is great! I'm glad to see other people and reading everyones experiences with this vehicle! |
#8 | |
#9 |
The Necessary Evil
I merged your thread with a real old one. This has been a concern but not a problem. I don't really know if it maybe has something to do with the CVT braking in or changing the way that you drive it. I believe that part of the trick is to not fully let up on the gas. It's second nature after a while and mine hasn't done it for a long time now. Maybe I finally learned how to drive.
![]() Another bit here: http://www.jeepforum.com/forum/3209512-post1.html
Bob Artificial intelligence is no substitute for natural stupidity MK Skid Plate fasteners for sale posts 68 & 69 Also visit me at Photobucket '06 WK Grand Cherokee Limited Quadra-Drive II, 5.7 '07 MK Compass Limited 4X4, AutoStick |
#10 |
Thanks Jockey and Gramps!
I appriciate the info. I might bring it up with my dealer and see what they say but other then that, I wont worry about it. |
#11 |
My wife had a 1999 Civic that had a CVT transmission....it also tended to lurch from time to time. We had nothing but problems with the tranny. It was in the shop 3 times in less than a year....it had a belt that would slide from gear to gear to make the shifting transaction "smooth"....what a piece of junk. The belt broke twice. I'm no mechanic....so i'm only telling you what they told me. The wife eventually crashed it up and we had to get a new car anyway(she wasn't hurt).
I was very reluctant to get a new car with a CVT when I was looking at the compass. So far so good...but i only have 2500 miles on it. The lurching is normal. You will get used to it. Anyone have any issues with the CVT yet? I haven't done a search yet but will now. And i do agree....this Forum is awesome!
2005 Wrangler Impact Orange 2005 Chrysler Crossfire 2006 Jeep Commander |
#12 |
The Necessary Evil
Just shy of my 21K oil change. No issues except what we've talked about here. I'm also in the Caliber forums a lot. There hasn't been anything that's gotten my attention.
Search may still be down, they are working on installing 2 new servers.
#13 |
I havent noticed any lurching with our 07 patriot with CVT2L but I did notice it tends to slow down quick when my foots off the gas, sorta like compression braking in a lower gear. guess Im just used to old school V8s and trannys that seemed to coast for miles when your foot was off the gas. Ill have to try leaving my foot in the gas slightly instead of off it and see how it goes.
I wonder if my tranny has slightly different programming being a patriot and the CVT2L. it has an aug 07 build date. maybe it tried to anticipate and "shifts" to a higher ratio so its ready for the gas again? wish there was a way to find out what software revisions we we all running.
[COLOR="DarkRed"]2000 Cherokee Sport 4.0L Selec Trac[/COLOR] - mine - for occasional wheeling [COLOR="DarkGreen"]2007 Patriot 2.4L FD I 4x4[/COLOR] - wifes - doomed to rarely leave the street |
#14 | |
The Necessary Evil
http://www.jeepforum.com/forum/f98/ratios-cvt2-vs-5-speed-395153/ CVT2L includes, among other things: - Hill-Descent Control, Off-Road Brake Traction Control (vs. standard Brake Traction Control), and calibration enhancements to meet off-road driving requirements. Both the engine and the transmission programming would need to be different and the CVT2L programming may include the standards but, it will have more to it for the off-road features. The engine programming should be different because at some points the engine speed increases for some conditions. Therefore, I don’t think that the versions would be comparable between the transmissions.
#15 |
I personally -love- the down-shift slow down of the CVT2.
When I am driving in stop-n-go traffic and see sudden brake lights, I just let off the Gas to slow down and so I completely avoid hitting the brakes. So I save wear/tear on the brakes. I don't care as much what happens to the CVT because its part of the life-time warranty. |
| Thread Tools | |
Previous Thread
Next Thread
| Suggested Threads |
