Crossmember and Subframe rot - JeepForum.com
post #1 of 13 Old 05-28-2015, 08:01 AM Thread Starter
Sdsjeep2008
2008 MK Compass
Service Bulletin NUMBER: 23-012-14
GROUP: Body
DATE: May 19, 2014
This bulletin is supplied as technical information only and is not an authorization for repair. No part of this publication may be reproduced, stored in a retrieval system, or transmitted, in any form or by any means, electronic, mechanical, photocopying, or otherwise, without written permission of Chrysler Group LLC.
NOTE: This only applies to vehicles in the Canadian Market and in salt belt states which include Connecticut, Delaware, Illinois, Indiana, Iowa, Maine, Maryland, Massachusetts, Michigan, Minnesota, Missouri, New Hampshire, New Jersey, New York, Ohio, Pennsylvania, Rhode Island, Vermont, Washington, D.C., West Virginia and Wisconsin.
SUBJECT:
Front And Rear Crossmember Corrosion (X58 10 Years Unlimited Mileage)
OVERVIEW:
This bulletin involves inspecting the front and rear crossmembers for perforation / rust through and if necessary, replace the crossmember(s).
MODELS:
2007 PM Caliber
2007 MK Compass, Patriot
NOTE: This bulletin applies to vehicles built on or after August 26, 2005 (MDH
0826XX) and on or before July 23, 2007 (MDH 0723XX).
SYMPTOM/CONDITION:
The customer may describe a vibration at the steering wheel or may have been informed by a technician or state vehicle inspection that the front and / or rear crossmember is severely corroded.
POLICY:
Warranty period for crossmember perforation / rust through is extended to 10 years.
Reimbursable within the provisions of the warranty.[/QUOTE]
My 2008 Compass seems to have the same issue. It was manufactured in October, 2007 so it would apparently not be covered under this bulletin. Has anyone else had this same issue with their 2008?
Sdsjeep2008 is offline
post #2 of 13 Old 05-30-2015, 07:22 AM
Chriztofor
2007 MK Compass
Chriztofor is offline
post #3 of 13 Old 04-24-2016, 06:29 PM
croacha
2009 MK Compass
We have a 2009 Jeep Compass with a rotted Rear and Front Cross-member. Not covered under our Lifetime Maxcare warranty so I called Jeep and they indicated that they noted our concerns, however, there wasn't anything they could do about it. $3000 repair at the dealership. Vehicle still there now, unsure what to do....
croacha is offline
post #4 of 13 Old 05-25-2016, 11:57 AM
3Jeepguy
I have a 2009 Patriot. Last summer I had to replace the front cross member. The dealer wanted $700 for the part and about the same to install. I got a good used one at the recyclers and my local mechanic installed it for about $375. Also had to replace ball joints and tie rod ends. mileage at that time was 85,000 miles.
3Jeepguy is offline
post #5 of 13 Old 09-07-2016, 08:08 AM
Mooncat
2009 MK Patriot
2009 Jeep Patriot Front and Rear Crossmembers Rusted Out
My 2009 Jeep Patriot has rusted out front and rear crossmembers as well. Brought it into the shop because I was hearing knocking noises coming from the driver side front end. Thought maybe it was a broken sway bar link, but no. Just crazy perforations caused by rust and leading to creaking as things break. Contacted Chrysler about it and pointed out that the 2007 Patriot was given an extended warranty (10 year) for this exact same problem. Chrysler offered no help or guidance. Filed a formal safety complaint with NHTSA as this rust means that the crossmember could crack apart at any time, leading to my engine dropping out, among other things. It's an accident waiting to happen. Shouldn't be an issue on a 7-8 year old and well cared for vehicle. Chrysler Jeep needs to step up and make this right.
Mooncat is offline
post #6 of 13 Old 09-08-2016, 08:16 AM
JeepCares
FCA Customer Care
JeepCares's Avatar
Hi Mooncat--PM your VIN and I'll look into this for you.
Kori
Jeep Social Care Specialist
JeepCares is online now
post #7 of 13 Old 01-31-2017, 12:30 PM
Chris1962
Hey I was going through the forums and found that others have had the same issue with their 2009 Jeep Patriots. I just purchased one and put it in to be certified only to find the front sub frame was toasted. I called the local Jeep dealer and gave him the VIN and he said nothing can be done. It seems a bit much that this is such a common issue and Jeep doesn't cover it.
I tried PMing JeepCares my VIN but since I have not made 15 posts it told me I couldn't. Any advice you can give would be very appreciated, Chris
Chris1962 is offline
post #8 of 13 Old 02-01-2017, 09:45 AM
JeepCACares
Hello Chris1962,
Are you based in Canada or the USA. If you are in Canada I will send you a PM request, if you are in the USA I will let our JeepCare US know to contact you.
Thanks
Top Care Specialist
FCA Canada
JeepCACares is offline
post #9 of 13 Old 02-01-2017, 04:10 PM
Chris1962
I'm in Canada
post #10 of 13 Old 02-01-2017, 04:47 PM
ZA09
I have the exact same problem! Mines a 2008 Compass and the K frame is completely rusted on it with gaping holes. I was hoping to find a recall from Jeep but I haven't found any so far. Mine was also built in 2007 so I wonder if they used the same K cross member and subframe from the 2007 model.
ZA09 is offline
post #11 of 13 Old 02-01-2017, 06:16 PM
Chris1962
I paid $3500.00 for the Jeep. The dealer subframe cost me $800 and remove/install was $594 with tax totaling $1575.22. In total it cost me $2288.36 to get it certified. There were other issues some of which were caused by the weakened subframe. I had it appraised before the work was done. The appraiser said he'd give me $500.00 for it. Still I paid $3500.00 and guess which the Government made me pay tax on? The amount I paid for it!? That was another $487.00. Now that it is in proper shape I'll be keeping it because despite the hurdles this thing drives like a dream!
post #12 of 13 Old 02-02-2017, 04:20 PM
Chris1962
JeepCACares I hope my reply to your pm went through but I'm having my doubts as I got the following after I sent it.
post #13 of 13 Old 02-03-2017, 10:12 AM
JeepCACares
Hello Chris,
The PM did not go through. Please call the 1-800-465-2001 and ask to speak to Lyne, you can let them know I am expecting your call. I am sorry that the PM did not work as I would have thought that you should have been able to reply to my PM.
Looking forward to hearing back from you.
Thanks.
Top Care Specialist
FCA Canada
