Creaking noise from rear suspension after lift - JeepForum.com
post #1 of 5 Old 06-30-2008, 06:55 AM Thread Starter
AussiePat
Hi Guy's,
I have installed the RRO lift on the Pat.
The front end is quiet as but the rear end makes some noises.
Symptoms are as follows:
1. While reversing out of the drive way or pulling into a drive way and when one wheel is higher than the other the back end creaks.
2. Going over larger bumps in the road the back end makes noises.
If at a stand still I open the tail gate and push the end up and down all is quiet.
3. When I go over changes in road and go over a crease in the road it feels as if the back skips over the bump instead of rolling over the crease in the road.
Man it really echoes from the back to the front.
I have lubed all joints at the back a few times now and its still there.
I'm wondering if the springs need to settle now a bit after things being lifted and that the Pat needs a few k's to settle down.
The front end is all fine.
I've called ARB who installed the lift for me have booked it in after lunch on Fri for them to look at.
Just wondering is anyone else had any probs after install such as this and then it settled down some what?
AussiePat is offline
post #2 of 5 Old 06-30-2008, 07:46 AM
Gramps
The Necessary Evil
Gramps's Avatar
2007 MK Compass
Same thing here for about 2-3 weeks after install, then it went away. I think it's because the rear shocks are not centered in the springs and they have to kind of re-seat or re-position themselves.
Bob
posts 68 & 69
Also visit me at
Gramps is offline
post #3 of 5 Old 06-30-2008, 04:39 PM
Coasty161
x2 as well
Coasty161 is offline
post #4 of 5 Old 06-30-2008, 05:05 PM Thread Starter
AussiePat
Many thanks Jeepers for your feed back.
post #5 of 5 Old 07-04-2008, 04:03 AM Thread Starter
AussiePat
Hi Guy's,
I just wanted to give you an update.
Well after a week I thought it was getting better. Day after day.
But still there. So I took the Pat back into ARB and explained to them what the deal was.
They gresed up the bushings on the new control arms which they did not the 1st time and boy presto. The result was immediate. Drove home approx 30km's and whisper quiet. Here and there you get a slight creak but 100% improvement from before. So I'll keep an eye on it and let things settle down now.
But I thought I'd share the info incase someone else has the same prob and can see where maybe to investgate 1st.
Jeep Green Crd Limited, RRO Lifted, TX3400 & Coopers.
It's a Patriot thing, you wouldn't understand.
Still having rear wheel noise! udmover Jeep Compass & Patriot Forum 2 07-19-2009 05:13 PM
Thrumming noise from rear udmover Jeep Compass & Patriot Forum 3 06-17-2009 05:22 PM
noise from rear suspension... burrell9 Jeep Compass & Patriot Forum 2 03-10-2009 12:05 AM
I heard a suspension clunk Laloggia Jeep Compass & Patriot Forum 19 04-11-2008 10:15 AM
Dashboard creaking noise on Patriot? mich99TJ Jeep Compass & Patriot Forum 0 04-06-2008 02:10 PM
