CRD: Clicking noise under bonnet after stopped. - JeepForum.com
post #1 of 6 Old 09-28-2010, 05:33 PM Thread Starter
spencernj
When I switch the engine off and turn the ignition off for about 20 seconds there is a tapping noise like a solenoid quickly engaging and disengaging which then stops if I turn the ignition back on but do not start. When I turn the ignition off again it will start again. If I leave the car it stops after about 20 seconds. Sounds like it comming from near the front of the engine bay.
Is this normal? Any ideas?
Current: 1998 XJ 4.0 Ltd Grey/Blue, 2008
Past: 1998 XJ 4.0 Ltd Green, 2005 Grand Cherokee Ltd Black, Patriot 2.0 CRD Ltd Silver
spencernj is offline
post #2 of 6 Old 09-29-2010, 12:59 PM
merlinTec
merlinTec's Avatar
Hi
No not normal, Can you be more pacific could be EGR valve
UK Chrysler Jeep Master Tec.
merlinTec is offline
post #3 of 6 Old 09-29-2010, 05:08 PM Thread Starter
spencernj
Its difficult to locate the exact source especially when I am not dressed to crawl around the engine. I will stick my head under the bonnet with a large screwdriver as a stethescope and see exactly where it comes from.
post #4 of 6 Old 10-01-2010, 01:48 AM
zbee
its the turbo etc cooling down etc, my other halfs does the same...no biggy
zbee is offline
post #5 of 6 Old 10-13-2010, 05:03 PM Thread Starter
spencernj
I am now sure its not the turbo - suspect it is the EGR but why should it bedoing this after the engine is off. I also noticed it only happens when hot not cold or after a short run. A sound file of the noise is here http://www.rhiannonspencerjones.com/MyRecording.caf and the photo is the component I reckon the noise comes from. If this is the EGR it doesn't look too easily accesible (in fact it looks a nightmare) and then the question is the fault with the valve or the ECU that operates it, but I suspect the valve may just need a clean. The car drives fine, no power problems, no smoke and good fuel consumption but has done 73k miles in 2.5 years. It would seem from a quick google that many VW owners disable these.
post #6 of 6 Old 10-21-2010, 01:17 PM
merlinTec
merlinTec's Avatar
HI
Sounds like the EGR throttle valve. Not the EGR valve that you can see with the vacuum pipe on it and the metal pipe bolted on the other side. It's the bit below that, you can just see the bolt on the front there are two more behind and an electrical plug. You can just see the motor under the metal pipe.
clicking noise , crd
ticking noise... burrell9 Jeep Compass & Patriot Forum 4 01-15-2011 06:44 AM
Cabin Noise trmor8103 Jeep Compass & Patriot Forum 1 08-02-2010 04:58 PM
Road Noise parajeep Jeep Compass & Patriot Forum 5 04-25-2008 01:22 AM
A/C noise thudson331 Jeep Compass & Patriot Forum 3 04-11-2008 09:06 PM
Ticking noise...from radio??? karfana Jeep Compass & Patriot Forum 2 03-19-2008 02:23 PM
