CrankShaft Position Sensor - Check Engine Light - JeepForum.com
post #1 of 10 Old 09-26-2012, 12:13 PM Thread Starter
hp2point0
I have a 2007 Jeep Compass. The past few months I have had a few issues with it. When accelerating the car seems sluggish. It would jerk and then it would ride pretty smooth once reaching around 30 mph. The check engine light also came on. This seems to happen more when the air-conditioning is on. Yesterday I was accelerating and around 15-20 mph there was a big jerk and the car would not go above 20 mph without the RPM's going into the red. The Check engine light started to blink. I turned the car off for about 3 min then started it again. Check engine light still blinking. I started to acceleration very gently and it seemed fine but I know there still must be a problem. Plugged in and got Codes for a missfire and Crank Shaft Position Senor. Reading other pages it looks like this sensor is fairly easy to replace but some sights say for the (4WD) AWD 2.4 engines that the Power Transfer Unit has the be taken out. Not to sure if that is something intense or not. Has anyone done this replacement on a 2.4 Engine?
hp2point0 is offline
post #2 of 10 Old 09-27-2012, 07:54 AM
Gramps
The Necessary Evil
Gramps's Avatar
2007 MK Compass
We've only had one other thread on this issue and the OP didn't come back with any further info.
http://www.jeepforum.com/forum/f98/c...ensor-1333085/
Bob
posts 68 & 69
Also visit me at
Gramps is offline
post #3 of 10 Old 01-26-2015, 04:24 PM
chetzar
Is it Friday yet?
1994 ZJ
Because I LOVE reviving super dead threads, my sisters Compass at 104k just started having this issue. I'm gonna replace the sensor and will report back, and try to snap a few pics as I go.
chetzar is offline
post #4 of 10 Old 02-10-2015, 11:49 PM
chetzar
Is it Friday yet?
1994 ZJ
Sorry for the delayed response, replaced the sensor (with a MOPAR sensor); its not to difficult, the problem lies in clearing the code, the relearn procedure I have found for the CPS is as follows:
1. Clear the Code
2. Accelerate the vehicle to 70 mph, then coast to 40 mph.
3. CPS should have learned the position of the crank, code should not come back.
The problem I have is, I clear the code and it comes right back, even after the relearn procedure.
chetzar is offline
post #5 of 10 Old 02-12-2015, 05:04 PM
Hondatrix
Check wiring to sensor..
Hondatrix is offline
post #6 of 10 Old 02-12-2015, 07:16 PM
kadetklapp
1997 XJ Cherokee
How bad was the actual replacement procedure? What all had to come out? The 4wd model is hell I hear.
As far as clearing the code, I'm sure you did, but to be sure, did you disconnect the battery for a while? That should reset in my experience.
**1997 Jeep Cherokee SE**
Former Police Car assigned to 54-26, RIP.
kadetklapp is offline
post #7 of 10 Old 02-12-2015, 10:42 PM
chetzar
Is it Friday yet?
1994 ZJ
The model I did it on was a 4wd, it only took about an hour; you need to take off the heat shield (3 bolts), air box (taking the air box off helps a TON), blindly find the hole to put the crank sensor back in, then put it all back together. I did disconnect the battery, but I'm going to try disconnecting the battery and doing the re-learn procedure again this weekend.
chetzar is offline
post #8 of 10 Old 02-13-2015, 11:45 AM
kadetklapp
1997 XJ Cherokee
So the rumor about having to pull the PTU and the front right CV shaft is a myth then.. Gotta love the dealer.
post #9 of 10 Old 02-23-2015, 04:00 PM
chetzar
Is it Friday yet?
1994 ZJ
Disconnected the battery, did the relearn process again, no more engine code for the Crank Position Sensor.
chetzar is offline
post #10 of 10 Old 10-01-2015, 10:15 PM
jeffabaker2
on the 2007 2.4 L jeep patriot AWD I took the drive axle out of the hub to make it easier to reach the 2 bottom bolts on the heat shield to be removed. they are 10mm and 13mm. I reached the top heat shield bolt from top and I reached the crankshaft position sensor bolt from the top with a 10 inch extension for the 10mm socket.
jeffabaker2 is offline
Check Engine Light 2007 Jeep Compass jandyrodax Jeep Compass & Patriot Forum 19 09-05-2015 06:47 AM
Crankshaft Position Sensor aberg12012 Jeep Compass & Patriot Forum 5 04-26-2015 12:09 PM
07' Patriot Engine Light Problem kairosdreaming Jeep Compass & Patriot Forum 2 02-10-2012 10:23 AM
FYI - Plugged in Block Heater can trip the Check Engine Light Knightfallzx2 Jeep Compass & Patriot Forum 2 01-19-2010 10:26 AM
Check Engine Light/Other Issues Mistyfate Jeep Compass & Patriot Forum 4 03-21-2008 08:52 PM
