Covering gas tank - suggestions? - Page 2 - JeepForum.com
post #16 of 21 Old 12-22-2006, 09:31 AM
Kev M
2012 WK
Originally Posted by BuzzDog
Thanks, guys! I've only had my Compass for less than two weeks, but I've already noticed the heat shield behind the rear bumper. Since my Compass is black, it REALLY sticks out!
Wonder how difficult it would be to remove it, so that I can paint it without worrying about masking everything from the overspray?
Some painters tape and some drop cloths would probably be just as easy...
Kev M is offline
post #17 of 21 Old 12-22-2006, 09:44 AM
phil8400
phil8400's Avatar
Take it to the dealer and have them look at it 'cause it's not normal.
phil8400 is offline
post #18 of 21 Old 12-22-2006, 10:40 AM
compassjeep
maybe it is it not painted black now the muffler?
compassjeep is offline
post #19 of 21 Old 12-24-2006, 09:19 PM
Kozmotoo
That's the muffler!
The muffler is what you see below the rear bumper. Rear impact caused all Chrysler vehicles to put the fuel tanks in front of the rear axle (Mandatory for all *new* programs after round about 2000???).
I understand that the muffler is not painted because it would significantly drive up the cost of the supplied exhaust system. The exhaust supplier would need a paint shop (expensive), resulting in a higher piece cost.
You can spray it with any paint in a spray bomb, but I'd expect to re-spray it several times in the vehicle's life span. It's a galvanized part, so it should never get too unsightly if left as-is.
Kozmotoo is offline
post #20 of 21 Old 12-26-2006, 10:54 AM
madrabbitt
madrabbitt's Avatar
someone mentioned bbq paint.
thats what i'd use.
either flat (or if you'd like glossy) high temp enamel paint should do the trick.
if you're going to the store tell them you need enamel oven or bbq grill paint and they should know what you're looking for.
Installing HID's in stock housings is bad.
"When you see someone who needs help, help them. When you see someone who needs a hug, hug them... Help those who can't help themselves." -Sgt Andrew Tingwall, NMSP. End of watch 6-10-2009
madrabbitt is offline
post #21 of 21 Old 12-27-2006, 08:05 AM
compassjeep
my muffler was painted flat black, odd the way they do and do not do certain things, my limited does not have the silver dash trim around the gauge cluster? brochure shows it, website shows it! the dealer and jeep can not explain why some do & some don't?! great quality control, a least all 4 of tires match! lol
Gas tank issue-When pumping it shuts off before full greencompass Jeep Compass & Patriot Forum 3 08-13-2009 06:03 PM
I'm impressed...29mpg on first tank...lifetime warranty... awd...for $15,999 2broke2smoke Jeep Compass & Patriot Forum 3 05-21-2008 04:17 PM
Seriously only 255 miles on a full tank....? rightsmanaged Jeep Compass & Patriot Forum 10 01-29-2008 06:17 AM
Click in Steering/TPMS/Sirius/Gas Tank blockisle9 Jeep Compass & Patriot Forum 6 11-25-2007 09:15 AM
Gas tank echocat22 Jeep Compass & Patriot Forum 7 02-04-2007 08:55 AM
