Quantcast Compass vs. Patriot - Page 8 - JeepForum.com
Truck-Lite 7" Round Headlamp Giveaway! - Drive OffRoad Gift Certificate Contest!
Go Back JeepForum.com > Models > Compass & Patriot Forum > Compass vs. Patriot
Introducing MONSTALINER™ UV Permanent DIY Roll On Bed LineSwag Off Road BIG-HIT TJ-YJ Rear BumperNEW Fawkes modular recovery & bull bar mounts for WJs.
Unread 05-11-2007, 09:33 PM   #106
Gramps
The Necessary Evil
Gramps's Avatar
2007 MK Compass
Just FYI:
The predicted demographics for the Compass and Patriot have changed from the original 60%/40% split for the Compass going to the ladies to an actual 51/49. The Patriot had the same split going to the gents and as of the end of April gets a 57/43 split. The original age target was 20-40 for both and ends up with an average of 42 and 39 respectively. 61% of all Jeep buyers are male.
Bob
MK Skid Plate fasteners for sale posts 68 & 69
Also visit me at Photobucket
Gramps is offline   Reply With Quote
Unread 03-04-2008, 05:41 AM   #107
Urr
Originally Posted by pdxbubba View Post
Compass: 8-inches of ground clearance, 21.1-degree approach angle, 32-degree departure angle and 21-degree breakover angle.
Patriot: 9-inches of ground clearance, 29-degree approach angle, 33-degree departure angle and 23-degree breakover angle
Is "not-trail-rated" Patriot (Patriot with FDI) with the same angles as Compass?
Happiness is not a goal, but a lifestyle
Ex 2007 Jeep Compass Sport 4x4 CRD in action :)
DD 2011 Mitsubishi ASX Invite 4WD DiD
In bright and happy future: Jeep Wrangler
Urr is offline   Reply With Quote
Unread 03-04-2008, 06:31 AM   #108
Gramps
The Necessary Evil
Gramps's Avatar
2007 MK Compass
Not quite. The front fascia on the Compass makes for a more shallow approach angle. But you're right we should be comparing FD I versions of both and my Compass Limited FD I was 8.4" gc stock. The Limiteds do have different springs than the Sports possibly causing the extra height.
Bob
Unread 03-04-2008, 06:54 AM   #109
Urr
But what are the angles for Patriot FDI, do you know?
Compass'es angles are, as I understand from prevoius discussion:
32-degree departure angle,
How much is Patriot FDI different?
PS. And what are your Compass's angles after lift?
Unread 03-04-2008, 07:29 AM   #110
Gramps
The Necessary Evil
Gramps's Avatar
2007 MK Compass
I have all of the specs at home but managed to steal this from http://www.allpar.com/model/jeep/patriot.html
I was only able to do a crude measurement with the lift installed an it didn't seem that much different at the time. Comparing apples to apples it looks like the angle should have improved by at least 1.6 degrees on both ends. 22.7, 33.6, and an additional 2.4 on break over for 23.4. These are the changes between a standard Patriot and the Trail Rated version.
EDIT: We may get to use a 2.125 multiplier since the lift is 2 1/8" That would come out to 3.4 degrees on the front/rear or 24.5/35.4 and 5.1 increase on the break over or 26.1. That could be wishful thinking though.
Bob
Unread 03-04-2008, 10:39 AM   #111
Urr
So there are three methods to determine, how much better are these degrees on lifted Compass:
1) calculating it mathematically
2) searching from internet (pretty hopeless, I think, there aint many lifted Compasses out there )
3) taking two-three big pieces of carton and scissors,
and going to the garage and measuring it
Unread 03-04-2008, 11:40 AM   #112
Gramps
The Necessary Evil
Gramps's Avatar
2007 MK Compass
I have a cheap angle gauge (the emphasis is on CHEAP!) that will get me down to 1 degree depending on how well you can see it. It's also tricky setting it up to read between the tires and the lowest part of the fascia, too.
Bob
Unread 03-04-2008, 01:09 PM   #113
Urr
To be honest, that is not so important, that you should go and measure it.
The bumpers are quite elastic, I've tested them against sand and snow ,
couple degrees in angles wouldn't save much, just postpone a bit these kind of tests
PS. Have you already got the skid plate, that you mentioned?
Unread 03-04-2008, 02:23 PM   #114
Gramps
The Necessary Evil
Gramps's Avatar
2007 MK Compass
No not yet. I'm not even sure if we had the right numbers. I obtained a new set of numbers and I'm going to check on those as well. It's almost warm enough to start working on mine again.
Bob
Unread 03-04-2008, 04:54 PM   #115
Gramps
The Necessary Evil
Gramps's Avatar
2007 MK Compass
UPDATE: The skid plates for the gas tanks are in and hopefully the Engine/Trans Skid plate will be here by Saturday and I'll pick all of them up.
Bob
Unread 03-04-2008, 05:13 PM   #116
Coasty161
Coasty161's Avatar
2008 WK
sweet!
Coasty161 is offline   Reply With Quote
Unread 03-05-2008, 02:25 PM   #117
Urr
Gramps, I'm just teasing you while your skid plate is not arrived yet...
You know, that front skid plate can be used for sledging in winter?
http://s240.photobucket.com/albums/ff102/FE700/JC/?action=view&current=IMG_9043.jpg
More here: http://s240.photobucket.com/albums/ff102/FE700/JC/
Unread 03-05-2008, 04:09 PM   #118
Gramps
The Necessary Evil
Gramps's Avatar
2007 MK Compass
Oh, I thought that you meant to take it off and sled. Since it weighs about 32 lbs sure would get the little kids out of the way.
I've linked your post in the MK's Off-Road thread. Thanks for the great shots!
Bob
Unread 03-05-2008, 05:34 PM   #119
Jeepster55
....i guess one could go sledding with it!
Jeepster55 is offline   Reply With Quote
