-   Jeep Compass & Patriot Forum (http://www.jeepforum.com/forum/f98/)
-   -   Compass vs. Patriot (http://www.jeepforum.com/forum/f98/compass-vs-patriot-307388/)
Kev M 08-24-2006 08:00 AM
Compass vs. Patriot
Anyone have a good grip on the differences between the Compass and Patriot yet?
They share a platform. - Wheelbase, track, overall length are identical. But with styling differences come small differences in the interior, headroom here or there. Though they are split and all advatanges (even as tiny as they are) do not go just to the Patriot.
They share the same basic drivetrains. 2.4L I-4 Mitsubishi derived motor. Though it's not obvious, do they both have Variable Valve Timing?
And the Patriot has a 4wd system with locking lo range available and the Compass does not. Though the Compass does offer a center locking diff.
Prices and options are pretty similar too.
The Patriot has 16" or 17" wheels, while the Compass has 17" or 18" (personally that's advantage Patriot for me, cause I don't need huge wheels on a pavement queen).
Unfortunately the info on the Patriot at the Jeep website is still very incomplete and I have no mileage figures or tow capacity to compare, but I SUSPECT they are also going to be very similar.
I equipped a Patriot on the Jeep website with the same trim and options as I had a Compass and the price was within $70 of each other.
So here's my question.
Am I missing any differences?
Other than styling or IF you want the Lo range 4wd, what is the reason to buy one or the other?
Kev
JeepFreak91 08-24-2006 11:18 AM
wouldnt want any of them. maybe I would want the patriot if they actually made it look like the concept and had all the options
Kev M 08-24-2006 12:32 PM
Thanks, your insight was compelling. I think I'll scrub my plans to buy either now and keep my XJ in order to make it an off-roading god. :p
:PopCorn:
:D
JeepFreak91 08-24-2006 12:53 PM
:PopCorn:
:D
good choice :thumbsup:
Kev M 08-24-2006 01:18 PM
:rofl: :rofl: :rofl:
pdxbubba 08-24-2006 01:55 PM
We are looking at the Patriot (only with the FDII package) as it is "Trail Rated" and is said to be "...Most Capable Vehicle in its Class."
It also has a little more cargo capacity than the Compass (62.7 cu. ft. vs. 61.8 cu. feet)
We both prefer the overall look of the Patriot over the round Compass.
...This all-new Jeep technology includes the CVT2Lís best-in-class 19:1 low ratio, which is ideal for crawling over obstacles. Off-road Brake Traction Control maintains forward mobility during heavy articulation or on split-friction surfaces where one wheel loses traction. Hill-Descent Control modulates brake hydraulic pressure without driver intervention for downhill assistance at a safe and controlled rate of speed. Three-mode ESP and off-road anti-lock brakes (ABS) also add to the Patriotís off-road capability.
The Trail Rated Jeep Patriot sits 1 inch higher than non-Trail Rated versions and meets Jeep off-road capability requirements for traction, water fording, articulation, maneuverability and ground clearance, including 9 inches of ground clearance, a 29-degree approach angle, a 33-degree departure angle and a 23-degree breakover angle. This version of the Patriot also has additional body sealing and high-mounted drivetrain vents to support 19-inch water fording capability. In fact, the Jeep Patriotís body and chassis were developed and tested over numerous rugged off-road terrains to meet the requirements of the enthusiast Jeep customer.
We plan on actually putting it to the test during our normal use, which is why we are mostly looking to the Jeep line for our next vehicle. The Patriot is not a heavy-duty rock crawler... but that's not what we want it to do. We are looking for a daily commuter vehicle with good gas mileage that can take the family of 5 back up the mountain trails to get away from pavement and people for a relaxing campout on the weekends. There are a few trails we won't be able to go down, sure. Most we should make it without issue in the Patriot.
Compass: 8-inches of ground clearance, 21.1-degree approach angle, 32-degree departure angle and 21-degree breakover angle.
Patriot: 9-inches of ground clearance, 29-degree approach angle, 33-degree departure angle and 23-degree breakover angle... with 19-inch water fording ability! (that's a plus in the Pacific Northwest.)
Kev M 08-24-2006 02:16 PM
Good info bubba.
It's funny, I guess it's only the "trail rated" versions of the Patriot with the FDII package that have that additional clearance because I noted on the Jeep website today that in stock form the Compass was listed with 8.4 in. of ground clearance (on the 17 in wheels) while the Patriot was listed as only 8.0 in of ground clearance (again on the 17 in. wheels). Plus the limited Compasses all come with 18 in. wheels, for whatever additional clearance that might add.
For me, we're really just looking at pavement queens to do snow/rain duty, so it's not as critical. However, I'm sure the occassional dirt trail shouldn't prove a problem for either.
Kev
JeepFreak91 08-24-2006 06:25 PM
on a serious note i wouldnt get anything the first year they come out because of all the bugs the first new model years are prone to. like our 06 commander stalling :brickwall
Gramps 08-24-2006 06:44 PM
And like a '70 Hemi Challenger is something you wouldn't want either.
JeepFreak91 08-24-2006 06:46 PM
all i was saying is that just be aware of the possible problems. i never said that they were guaranteed to happen.
Gramps 08-24-2006 06:55 PM
Hopefully the computer age has brought us improvements to the first year designs. DC has some of the best engineering studios any where and if it was a first year Hyundai I wouldn't consider it. In many cases, I agree with you, but you have to consider the source. Whether anybody likes the Compass/Patriot or not I don't think that Jeep would like to blow it's reputation on making junque. Sure I took a gamble, or as I prefer to call it, a calculated risk. Life is like that.
JeepFreak91 08-24-2006 07:00 PM
we took a risk on buying the 2006 commander as i have stated before and it has a terrible stalling problems that could cause a major problem. this vehicle is not even a year old. I hope they improved their methods from then to now
Gramps 08-24-2006 07:07 PM
I am curious as to what the dealer says about it. Has this been a problem on other Commanders? I do sympathize for you. There are lemon laws in all states (I think).
JeepFreak91 08-24-2006 07:11 PM
yea just go to the commander forum and there atleast 3 or 4 threads for stalling. dealer doesnt know what to do. its too dangerous to drive around with it stalling at unexpected times so we are trading it in for a jetta.
XJ2Timer 08-24-2006 07:19 PM
I admit to being split down the middle on which I prefer. Having bought new tow Cherokee's you would think I would hands down go for the Patriot but for what the vehicle platform provides the more rounded Compass fits better to me. I still would have to have a much better looking front end before I personally would buy one and I really prefer the regular door handles that the Patriot has. I guess I'm saying I want a mix of the two. Compass with the FD II package of the Patriot but with some cosmetic work. Till then I'll keep my Cherokee. Ultimately I want a diesel powered, 5 speed automatic, full time/part time transfer case soft top with half doors 4 door Wrangler. Sorry for going off topic.
The time now is 12:35 PM.
