High,
recently I have recognized that its hard to switch gear to third or not sure if to fourth if I keep my foot on the pedal! unless I release it a bit then press again, so it switches.
and even if I push to full power still not change, thought speed is ingreasing but I see the rpm is higher than normal for instance i drive 60 and rpm on 3 or a bit less than 3, unless I release a bit the pedal then press so i feel the car rests!
any advice?
is that normal? I unplugged the battery for 10 min though does it make any computer reset to the gear? air filter is dirty? or does this kind of sport semi-auto trans has a gasket needs to be changed? should I change oil with filter or only oil? please help.
any advice?
