Compass in the shop for ETC - JeepForum.com
post #1 of 7 Old 01-21-2008, 02:15 PM Thread Starter
Nabis
I'm on the way to Michigan from Minnesota last night (~700 miles), and at a routine stop on the expressway for fuel, I get to the light off of the off-ramp, and my dash goes crazy with warning lamps. ETC (Electronic Throttle Control) sensor (the "lightning-bolt"), and the ESP (Electronic Stability Program) lights start flashing at me. The jeep starts bucking, brakes are about at half power, and steering is heavy. I make it to the fuel pump, and shut the car down. Fuel it up, and start it back up - It drives completely normal with no warning lamps. Nothing until I finally make it to my destination exit, and the same thing happens. This time I limp it to the driveway, and park it for the night. This morning took it into the Jeep dealership, and explain the problem. I haven't received a call back from them, but researching this problem, it seems like the Wrangler guys have it the worst with these ETC problems. Some say that their car is in the shop for WEEKS!... and some of the time, it seems as if the service dept never really fixes the problem. I hope that isn't the case with my Compass, but I still wanted to see if anybody has had a similar problem with their Compass/Patriot. I'll keep this thread posted with anything that I hear from the dealership.
Nabis is offline
post #2 of 7 Old 01-21-2008, 02:52 PM
Gramps
The Necessary Evil
Gramps's Avatar
2007 MK Compass
It sounds like you’re having problems with the Powertrain Control Module and it may need to be flashed. Just guessing with the help of these related TSB’s
http://www.wkjeeps.com/misc/Caliber/...er_1803407.pdf
http://www.wkjeeps.com/misc/Caliber/...r_1801807a.pdf
You can browse all of the TSB’s here, somewhere in this batch is something about seating a fuse that is unseated for shipping and may not be inserted correctly that may also be the cause.
http://www.caliberforums.com/forums/...light=bulletin
Please keep us updated.
Bob
posts 68 & 69
Also visit me at
Gramps is offline
post #3 of 7 Old 01-21-2008, 03:13 PM
merlinTec
merlinTec's Avatar
Hi
Can you try and get the list of the codes it flags up so we could be more help and will be more help to others.
Regards,
Merlin
UK Chrysler Jeep Master Tec.
merlinTec is offline
post #4 of 7 Old 01-21-2008, 03:27 PM Thread Starter
Nabis
Dealership called - They are replacing the entire throttle body. I didn't ask any questions beyond, "when will it be done", so I don't have any more information than that. I'll see if I can get a list of any codes it logged from the dealership when I pick it up. If anybody else has any questions that they would like me to ask when I pick it up, feel free to jot them down here.
I was going to bet that it was something with the PCM, and something went haywire in the extreme cold of Minnesota (It was about -18F each morning) - Guess I was wrong.
Nabis is offline
post #5 of 7 Old 01-21-2008, 06:53 PM
Gramps
The Necessary Evil
Gramps's Avatar
2007 MK Compass
I've been down to -22 with a wind chill of about -45. No problems I'm happy to say!!
Bob
posts 68 & 69
Also visit me at
Gramps is offline
post #6 of 7 Old 01-22-2008, 01:23 PM Thread Starter
Nabis
The Diagnostic stored a High Air Flow Vac Leak, therefore they deducted that it must be a sticking throttlebody, which they replaced.
I'm convinced that leaving the throttle open in subzero temperatures for hours on end is what caused it to stick, if that is in fact the issue - So I'm not too sure that the throttlebody that was replaced had anything "wrong" with it. The front of the jeep was also coated in about a half inch of ice.
Hopefully, I won't run into this again.
Nabis is offline
post #7 of 7 Old 01-22-2008, 02:05 PM
Gramps
The Necessary Evil
Gramps's Avatar
2007 MK Compass
Sounds pretty nasty! I guess if my doors can freeze shut so can your throttle body. Hope that all goes well from here on.
Bob
posts 68 & 69
Also visit me at
Gramps is offline
bye bye Compass snikr Jeep Compass & Patriot Forum 4 11-08-2009 08:22 AM
Got my new Compass!! What next? MomofCandS Jeep Compass & Patriot Forum 7 12-16-2008 04:22 PM
Anyone have a tow bar for their compass? blovingier Jeep Compass & Patriot Forum 3 11-09-2008 09:35 PM
What do you think Of your Compass?? ve3oky Jeep Compass & Patriot Forum 4 12-30-2007 02:21 PM
Compass Reviews - solutions to common Compass "problems" eighteenwheeler Jeep Compass & Patriot Forum 8 06-08-2007 06:32 PM
