Compass clutch help!!! - JeepForum.com
post #1 of 3 Old 11-21-2008, 06:59 AM Thread Starter
96cherokeeclass
A lady up here at work had the slave cylinder go out on her compass. I've replaced slave cylinders before, what would I be looking at on the compass, never worked on one before, hell I've never really looked under one.
- 07 WK - CRD
96cherokeeclass is offline
post #2 of 3 Old 11-21-2008, 04:34 PM
Gramps
The Necessary Evil
Gramps's Avatar
2007 MK Compass
Not good news.
The clutch release system utilizes a slave cylinder of a concentric design, having all components fixed about the same axis. The concentric slave cylinder (CSC) is mounted to the inside of the clutch bellhousing and is serviced only as an assembly.
1. Remove transaxle from vehicle (Refer to TRANSMISSION/TRANSAXLE/MANUAL - REMOVAL).
2. Remove bolts to slave cylinder-to-clutch bellhousing bolts and remove slave cylinder (1) from transaxle.
The sorta good news :
NOTE: The clutch master cylinder/hydraulic release system does not have its own reservoir. This system is supplied fluid from the brake master cylinder reservoir.
So first off, check the brake Fluid.
It looks like it's under the Brake Master. This is a very brief description of how to remove it and just one picture (ignore the numbers in the picture for now). I can do a better write tomorrow. Let me know what you need
1. Remove the engine cover.
2. Remove air cleaner assembly.
3. Disconnect battery negative cable.
4. Remove lower instrument panel bezel.
Bob
posts 68 & 69
Also visit me at
Gramps is offline
post #3 of 3 Old 11-24-2008, 09:35 AM Thread Starter
96cherokeeclass
thanks you've been a great help. After doing some research online it looks like this is not the first incident like this for a compass. There was even a report of a similar proble on lemon busters. I think shes just gonna take it to the stealership and hope a recall comes out later.
After reading what you said I basically flip floped from "oh yea I can do it during lunch" to "I aint touching that"
- 07 WK - CRD
bye bye Compass snikr Jeep Compass & Patriot Forum 4 11-08-2009 08:22 AM
What do you think Of your Compass?? ve3oky Jeep Compass & Patriot Forum 4 12-30-2007 02:21 PM
compass 4wd? and other ?'s BeerMonkeY Jeep Compass & Patriot Forum 1 09-02-2007 04:31 PM
Compass Reviews - solutions to common Compass "problems" eighteenwheeler Jeep Compass & Patriot Forum 8 06-08-2007 06:32 PM
Anyone own a 07 Compass jameson06 Jeep Compass & Patriot Forum 13 01-17-2007 04:22 PM
