Compass Brake Job - JeepForum.com
post #1 of 3 Old 09-10-2009, 02:37 PM Thread Starter
lastid123
Compass Brake Job
2007 Compass needs new brakes. Do I need to replace rotors or is it just a good idea? On other vehicles usually wait to replace rotors on 2nd brake job. Had a previous Jeep where mechanic told me that rotors could not be resurfaced because that were not made to be re-used again. Didn't know now if that was true or if Jeep had changed the type of rotors that it uses.
Thanks,
John
lastid123 is offline
post #2 of 3 Old 09-10-2009, 05:15 PM
Gramps
The Necessary Evil
Gramps's Avatar
2007 MK Compass
Unless the rotors are warped too much or just won't clean up with turning they can be turned down. The minimum is stamped on the rotor. Even NAPA has them for $35 - $51 if you need some.
Bob
posts 68 & 69
Also visit me at
Gramps is offline
post #3 of 3 Old 09-10-2009, 05:26 PM
xxxflhrci
xxxflhrci's Avatar
Unless they are out of round, gouged badly or under minimum thickness. Just replace the pads. If it makes you feel, good sand the surface of the rotor a bit to clean 'em up. All of my vehicles have the original rotors. The highest mileage one is 155k.
xxxflhrci is offline
Another Mod done - red brake calipers on Compass Limited rob_rector Jeep Compass & Patriot Forum 11 03-09-2008 05:32 PM
What do you think Of your Compass?? ve3oky Jeep Compass & Patriot Forum 4 12-30-2007 03:21 PM
Considering a Compass r.71 Jeep Compass & Patriot Forum 7 09-17-2007 07:52 PM
compass 4wd? and other ?'s BeerMonkeY Jeep Compass & Patriot Forum 1 09-02-2007 05:31 PM
Compass Reviews - solutions to common Compass "problems" eighteenwheeler Jeep Compass & Patriot Forum 8 06-08-2007 07:32 PM
