Quantcast Compass auto stick question. - JeepForum.com
Go Back JeepForum.com > Models > Compass & Patriot Forum > Compass auto stick question.
Spartan Lockers FREE SHIPPING Excellent PricesBlack Magic Brakes - 5% Off, No Minimum Purchase RequiredDISCOUNT - Chromoly Front Axle Shaft Kits, 87-95 YJ's, 97-
Old 12-24-2009, 12:00 AM   #1
horsepower
2008 MK Compass
I don't use the auto stick much at all, but I was wondering if I could use the 6th auto stick drive to cruise the freeway at 70+ mph?
I was driving home one night on the freeway when I bumped my auto stick to the right and it went to the 6th gear and it may be my imagination but the compass felt like it drove better.
I would like to use it while on the freeway but if regular drive is better I'll stick with that.
Thanks for any answers I receive.
horsepower is offline   Reply With Quote
Old 12-24-2009, 07:07 AM   #2
Gramps
The Necessary Evil
Gramps's Avatar
2007 MK Compass
Leaving it in "D" lets it vary on the ratios, putting it in "6" locks it to the single ratio. If the terrain is level and your holding a constant speed I don't see what harm it could do. It sounds like an interesting experiment!
Bob
MK Skid Plate fasteners for sale posts 68 & 69
Also visit me at Photobucket
Gramps is online now   Reply With Quote
Old 12-24-2009, 07:11 AM   #3
schoat333
2008 MK Patriot
I bump it into 6 anytime I'm on a flat road going above 40 mph. It helps gas mileage.
It doesn't really seem to help on the highway tho since the torque converter locks up anyways. Usually the rpm rise a little bit if I bump it to 6 at 65.
schoat333 is offline   Reply With Quote
Old 12-24-2009, 02:51 PM   #4
horsepower
2008 MK Compass
so at 70-75 it's better in drive but is still fine in 6 as long as it's a constant speed?
Thanks gramps and schoat333
Old 12-24-2009, 09:02 PM   #5
schoat333
2008 MK Patriot
Your safe. If you want to pass or speed up you can always bump it down to 5th manually.
Old 12-25-2009, 01:13 PM   #6
miketmx
2008 MK Patriot
I have the 5 speed manual and I admit that I don't understand how Autostick compares. I use 5th gear whenever I'm at speeds over 45-50 mph. When I want to pass or climb a hill, I shift into 4 but I have never been close to the red line on rpm when in 4 on normal highway speeds.
miketmx is offline   Reply With Quote
Old 12-25-2009, 08:32 PM   #7
DJMurphy
2008 MK Compass
Hi. First post from me. If you use 6th above 50 mph the revs will be higher than if you leave it in auto. This will increase engine response but also increase fuel consumption as well.
DJMurphy is offline   Reply With Quote
Old 12-26-2009, 10:26 AM   #8
Gramps
The Necessary Evil
Gramps's Avatar
2007 MK Compass
Hi and
I have never been able to find what the exact ratios are in each "gear" but because people are used to gear changes the CVT is programed to simulate those changes. Also the programming may be changed by software as determined by the factory.
These "ratios" are purely fictitious (and the reverse of what they should be) but may help you to understand the different way to use the AutoStick.
In "D" the transmission will vary from:
1.00 - 1.98 in 1st
2.00 - 2.98 in 2nd
3.00 - 3.98 in 3rd
4.00 - 4.98 in 4th
5.00 - 5.98 in 5th
6.00 - 6.98 in 6th
The .02 difference in the shifts is the "simulated shift" that you can actually feel.
If you choose to "dial your own gear" you will not have the varying ratio, you will be locked in to the lowest ratio for that gear, i.e. 1.00, 2.00, threw 6.00 etc. until you reach max rpm and force a change determined by the fail safes built in.
Bob
Glock Forum
