Compass AC Power Limits - JeepForum.com
post #1 of 5 Old 03-18-2013, 03:44 PM Thread Starter
mhwilliams5382
2005 WK
We are looking to have a tailgate at this weeks USMNT World Cup Qualifier, and would like to run a small LCD TV off the outlet in a Compass. Has anyone tried this before? How long can it run on battery? Would we need to have the jeep running the whole time?
Thanks in advance!
mhwilliams5382 is offline
post #2 of 5 Old 03-18-2013, 09:47 PM
FujativeOCR
2011 MK Patriot
Isnt there an Amp limit on that outlet? Like not designed for a vacuum cleaner. Check the manual for the max amp limit, and then check the tv for its current draw.
FujativeOCR is offline
post #3 of 5 Old 03-19-2013, 07:52 AM
jacko15
2014 WK
According to manual it's 115 Volt (150 Watts Maximum), no mention of amperage. Probably would run your battery down like leaving your headlights on. Also "NOTE: Due to overload protection the inverter will shut down if the power rating is exceeded."
Mine: 2014 Jeep Grand Cherokee Overland V/6
ORA II
Hers: 2017 Jeep Compass Latitude 4x4
jacko15 is offline
post #4 of 5 Old 03-19-2013, 12:30 PM
JeepCares
FCA Customer Care
JeepCares's Avatar
Not sure if this has any of the information you are looking for:
STAR Case
Case Number: S1108000106
Release Date: 06-16-2011
Symptom/Vehicle Issue:
Power Inverter Load Ratings
Discussion:
The inverter ratings are 150W / 120V = 1.25 Amps
The DC/AC Inverter and wiring terminals load rating.
Output Power:
POWER
150 W
VOLTAGE RMS
120 V
AMPS RMS
2.0 A
FREQUENCY
60 Hz
MAIN CONCERN: The mini-van inverter has a modified sine wave. Sensitive devices typically work with full sine wave.
Modified sine wave is different because it does not move smoothly between the positive and negative voltages.
This modified wave usually provokes devices a poor efficiency.
Using any outlet at its max rating is usually ok for a short period but can heat the inverter up and cause a reset.
JeepCares is online now
post #5 of 5 Old 03-19-2013, 01:14 PM
FujativeOCR
2011 MK Patriot
Im pretty sure a tv will require more than 2 amps.
