Check Engine light - JeepForum.com
Go Back JeepForum.com > Models > Compass & Patriot Forum > Check Engine light
All Bilstein shocks & struts - Lowest Prices Ever and Santa Kolak Announces: Kolak Exhaust 20% Off Sale!Introducing MONSTALINERô UV Permanent DIY Roll On Bed Line
Unread 10-16-2014, 09:06 PM   #1
normbrockway
2014 MK Patriot
Check Engine light
The gas cap was loose. The check engine light came on. Do I have to go to the dealer to turn off the light? Should he charge for this service? Do you think?
normbrockway is offline   Reply With Quote Quick reply to this message
Unread 10-16-2014, 09:14 PM   #2
festerw
No tighten the cap and drive a couple days and it should go out on it's own.
Hers - 2005 Jeep Grand Cherokee Laredo 3.7 4x4
Mine - 2003 Jeep Wrangler X
festerw is offline   Reply With Quote Quick reply to this message
Unread 10-23-2014, 10:01 PM   #3
BJohnson81
It worked for me too. Sounds crazy but after a day it went off.
BJohnson81 is offline   Reply With Quote Quick reply to this message
Unread 10-29-2014, 08:30 AM   #4
TimothyPilgrim
My CEL has been wonky since last year. Recently it went on, I gassed up, and it went out later that day. Great. But it's on again (usually happens in cooler temps) and even after checking the cap, it's still on. My ScanGauge II gives me random codes. I clear them, there's suddenly another in there. Clear it. Another. Is it my ScanGauge or a faulty CEL? I don't know. I'm not fond of visiting the dealership for a silly faulty light though. Any suggestions?
Deets: 2008 North Ed., 2.4L, FDII, 105k kms
TimothyPilgrim is offline   Reply With Quote Quick reply to this message
Unread 11-05-2014, 03:10 PM   #5
JKNanook
2010 JK Wrangler
First make sure your gas cap is clean and has a good seal. Right down your codes, if the same codes keep appearing they may not be so random.
JKNanook is offline   Reply With Quote Quick reply to this message
