Changing Power Steering Fluid? - JeepForum.com
post #1 of 10 Old 07-06-2010, 11:55 AM Thread Starter
PurpleHayes
2008 MK Compass
The QuickieLube place says I need my power steering fluid changed, and they want about $70 for the job. Is this something I can do myself? Does anyone know how to go about it? Any help at all is appreciated.
PurpleHayes is offline
post #2 of 10 Old 07-06-2010, 12:01 PM
Mino
Bump. I'd also like to know how do this. Thanks.
'05 Jeep Wrangler X
Rocky Mountain Edition
3" suspension lift, K&N cold air intake, Pro Comp MX6 shocks, JKS Quicker Disconnects & Front Track Bar, Dynomax Cat-Back system, SYE kit, Pro Comp Rock Crawler Wheels, 33" BF Goodrich A/T, Aussie Locker, and Warn XD9000i winch
Mino is offline
post #3 of 10 Old 07-06-2010, 12:13 PM
tknarr
Why do you need to change your power steering fluid?
Sounds like the Lube Shop needs your hard earned money!!!
Check your owners manual for change intervals (if there is one), otherwise if it aint broke, don't fix it>
tknarr is offline
post #4 of 10 Old 07-06-2010, 04:25 PM
Gramps
The Necessary Evil
Gramps's Avatar
2007 MK Compass
The recommended fluid for the power steering system is MoparŽ Power Steering fluid + 4 or MoparŽ ATF+4 Automatic Transmission Fluid. Both fluids have the same material standard specifications (MS-9602).
MoparŽ ATF+4 (and MoparŽ Power Steering fluid + 4), when new, is red in color. ATF+4 is dyed red so it can be identified from other fluids used in the vehicle such as engine oil or antifreeze. The red color is not permanent and is not an indicator of fluid condition. As the vehicle is driven, ATF+4 will begin to look darker in color and may eventually become brown. THIS IS NORMAL. ATF+4 also has a unique odor that may change with age. Consequently, odor and color cannot be used to indicate the fluid condition or the need for a fluid change.
NOTE: Although not required at specific intervals, the fluid level may be checked periodically. Check the fluid level anytime there is a system noise or fluid leak suspected.
There is no scheduled maintenance for changing the fluid.
The wife had her oil changed at one of the quick lube places, came home and they had told her that she needed to have her injectors cleaned for $90. RIGHT! A Hemi that's getting 19 mpg doesn't need any injector work performed other than, maybe, a can of injector cleaner in the tank once in awhile.
Bob
posts 68 & 69
Also visit me at
Gramps is offline
post #5 of 10 Old 07-06-2010, 06:13 PM Thread Starter
PurpleHayes
2008 MK Compass
Ok, well glad I asked! They told me the fluid was "dirty" and that the recommended interval was 30k miles; my Compass Has 37k. RTFM indeed. Thanks, tknarr and Gramps!
post #6 of 10 Old 07-09-2010, 07:31 AM
Steiner
2007 MK Compass
Hi M8s! I changed my PS fluide in June 10, at 75K for the first time, and this even if the fluid was looking normal. The easiest way to do it for a none mechanic like me (us):
First, locate the PS reservoir, just behing the coolant and windsheild washer reservoir. Open it, and using a suction device such as a cyringe (big one), I used one with a 6" clear tube a the end to reach all the way in the reservoire. Empty the reservoir, refill it with new ATF-4 PS fluid, specifications (MS-9602). Put the cap back on, then start the engine, turn the stering completely to the left, than completely to the right and return to center, kill the engine and re do the first step again.
Do this until the Qts is empty. The PS fluid capacity is about 1.1 qts, here in Canada we have litres, so I have more than anough. This ensure a complete turn around in the system, and I don't get stuck with left overs.
This is a crude methode, but it does not involve breaking any lines or requiring any special tools and so on, and you keep your $ in your pockets. The process takes about 30 min to complete and the cost is only the PS fluid. Please ensure to properly dispose of your used lubricants.
General rule of thum, change your fluids every 2 Yrs, brakes, PS, and Coolant, the 2 Yrs rule does not apply for the engine oil naturaly.
Steiner
Steiner is offline
post #7 of 10 Old 07-09-2010, 02:03 PM Thread Starter
PurpleHayes
2008 MK Compass
Thanks, Steiner--I had considered a similar method wondering if it would work. I have a manual pump that I use for removing gasoline from my lawnmower and snow blower at the end of their respective seasons. Should save me quite a few bucks.
post #8 of 10 Old 07-14-2010, 08:54 PM
howdy246
2008 MK Compass
I've owed a lot of vehicles and have never changed the power steering fluid nor have heard of it being changed. It won't hurt but I don't know if it will help either.
howdy246 is offline
post #9 of 10 Old 07-14-2010, 10:36 PM
tjkj2002
2002 KJ Liberty
The 2 most neglected fluids in any vehicle is the brake fluid and PS fluid.
I won't get into brake fluid................
As far as the PS fluid,it's a high pressure hydraulic system without a cooler(in your case) with a capacity or about 2 qts(or less).Your PS system takes the same fluid as the auto trans(non-CVT) and is toasted after reaching 200+ degrees and needs to be changed,oh looky that is the normal operating temps of your PS system.Might want to price out a R&P steering gear and it's labor,changing your PS fluid every 30k will seem like a bargain.
Oh and Gramps might want to actually research what a fuel induction cleaning does and what a "dry intake" is and why it needs a induction cleaning often.Just throwing cleaner in the gas tank does nothing in a "dry intake".
tjkj2002 is offline
post #10 of 10 Old 07-18-2010, 08:14 AM
Gramps
The Necessary Evil
Gramps's Avatar
2007 MK Compass
It's always nice to supply links if you're trying to be helpful.
Fuel and Induction System Cleaning
Best Way - Air Fuel Induction Cleaning | eHow.com
Bob
posts 68 & 69
Also visit me at
Gramps is offline
compass , patriot , power steering , power steering fluid
PTU and RDA fluid change blacksunshine Jeep Compass & Patriot Forum 54 02-03-2014 06:53 PM
Windshield Fluid? jandyrodax Jeep Compass & Patriot Forum 2 04-18-2010 10:41 AM
Changing Plugs in Compass? ups4 Jeep Compass & Patriot Forum 22 07-23-2008 05:38 AM
Anyone Else with Headlight Issues after changing them? pillzny Jeep Compass & Patriot Forum 9 12-07-2007 05:48 PM
Changing Odometer to display Kilometers thom44130 Jeep Compass & Patriot Forum 0 11-06-2006 10:29 AM
