Changing Plugs in Compass? - Page 2 - JeepForum.com
post #16 of 23 Old 07-22-2008, 11:16 AM
Zappy
2007 MK Compass
The only things that I noticed that were reset, were the radio settings. The EVIC did not appear to have been touched by the power outage.
Again, I can't be certain that the drop in efficiency I reported was due to my not disconnecting the battery before doing the plugs. All I am going by is the timing. That was the last thing that I did to the Compass before I noticed the drop in mileage. Disconnecting the battery this past Sunday may have reset something else that could have been the culprit. I'm waiting until I fill up this coming Thursday and run that tank of gas through to see what kind of mileage I get then.
Zappy is offline
post #17 of 23 Old 07-22-2008, 01:00 PM
Argent33
2014 JK Wrangler
anyone upgrade their plugs from the OEM's to platinums or iridiums?
if so did you notice any performance differences? and what plugs did you go with
~Paul
-[O l l l l l l l O]- 2014 Freedom Edition JKU - Hydro Blue 6-Spd
Argent33 is offline
post #18 of 23 Old 07-22-2008, 01:09 PM
Zappy
2007 MK Compass
I did the swap over to the Iridiums. Still waiting to see the overall effect, though initially I seem to see better fuel economy when I drive. No real difference in any power to me, but then I'm more concerned with mpg then rpm at the moment...
Zappy is offline
post #19 of 23 Old 07-22-2008, 02:50 PM
Argent33
2014 JK Wrangler
Which Iridiums did you use? NGK's?
*thinks maybe he just needs to wander off to Zappy's post about changing plugs*
~Paul
Argent33 is offline
post #20 of 23 Old 07-22-2008, 08:14 PM
Gramps
The Necessary Evil
Gramps's Avatar
2007 MK Compass
Another thread on NGK Iridium plugs. http://www.jeepforum.com/forum/f98/ngk-iridium-plugs-567229/
Bob
posts 68 & 69
Also visit me at
Gramps is offline
post #21 of 23 Old 07-22-2008, 08:39 PM Thread Starter
ups4
2008 KK Liberty
Argent33,
I just used Autolite Double Platinums.
Everything I've read and been told is that the iridiums aren't worth the difference they afford. I can't say if this is true first hand or not....just what I've heard.
Paul
08 KK Sport, Red Rock for me
07 Compass LTD, Steel Blue for wifey.
08 Patriot Sport, Jeep Green for son.
ups4 is offline
post #22 of 23 Old 07-23-2008, 06:20 AM
Zappy
2007 MK Compass
Argent33, Yes they were the NGK Iridiums. I can't say for sure if any increase in performance is directly related to them however since at the same time I switched the plugs, I also switched the oil to full synthetic Amsoil along with changing the air filter over to a K&N lifetime filter and topped out my tire pressure in all 4 tires at 40psi. For having done all of that, I have only noticed an average of maybe 1.5 - 1.75 mpg difference compared to where I was before I did all of that. With the price of gas I know that every little bit of mileage gain helps, but I can see where maybe a less expensive plug could provide that same nominal boost so far.
Regarding radio stations after disconnecting the battery. This morning I noticed that the Sirius channels seemed to have stayed set, it was only the normal am/fm band stations that I needed to reset as well as the time.
Zappy is offline
post #23 of 23 Old 07-23-2008, 06:38 AM
Argent33
2014 JK Wrangler
Hmm - I've always been a fan of the Bosch plugs (ran the Platinum +4's in my Neon) and I see they have something called Platinum Ir Fusion plugs that are supposed to be better than OEM iridium plugs. Maybe I'll try those....
~Paul
Argent33 is offline
Compass gps monox Jeep Compass & Patriot Forum 0 05-16-2008 02:35 AM
What do you think Of your Compass?? ve3oky Jeep Compass & Patriot Forum 4 12-30-2007 03:21 PM
Compass Reviews - solutions to common Compass "problems" eighteenwheeler Jeep Compass & Patriot Forum 8 06-08-2007 07:32 PM
Anyone own a 07 Compass jameson06 Jeep Compass & Patriot Forum 13 01-17-2007 05:22 PM
Compass as a DD Gi Joe2 Jeep Compass & Patriot Forum 1 08-18-2006 06:48 AM
