Change oil light - JeepForum.com
post #1 of 5 Old 10-03-2013, 11:51 AM Thread Starter
skip11and1
2013 MK Patriot
Change oil light
I changed my oil at 3737 the light never came on now at 6314 it finally came on but its early for my next oil change. Is there a reset button or does it come on depending on oil life?
2013 Jeep Patriot 4x4 FD1 5spd
2004 R6 lowered, stretched, full exhaust, HIDs etc
2004 TJ Columbia package long armed w/ 33's (Sold)
2005 WK, v6 QT1 (girlfriends)
skip11and1 is offline
post #2 of 5 Old 10-03-2013, 12:33 PM
jacko15
2014 WK
Our '08 Compass has a procedure to reset the oil light that's explained in the manual. You should check there.
Mine: 2014 Jeep Grand Cherokee Overland V/6
ORA II
Hers: 2017 Jeep Compass Latitude 4x4
jacko15 is offline
post #3 of 5 Old 10-03-2013, 04:35 PM Thread Starter
skip11and1
2013 MK Patriot
ya i found it thanks
post #4 of 5 Old 10-03-2013, 04:37 PM
NHPATRIOT
2014 KL Cherokee
You have to reset the OLM when you do an oil change. The OLM does not actually monitor the oil so it doesn't know when you change it. The procedure is listed in your owner's manual and is very simple...
2013 Jeep Patriot
Owner's Manual
Page 231
1. Turn the ignition switch to the ON position. Do not start the engine.
2. Fully depress the accelerator pedal, slowly, three times within 10 seconds.
3. Turn the ignition switch to the OFF/LOCK position.
NOTE: If the indicator message illuminates when you start the vehicle, the oil change indicator system did not reset. If necessary repeat this procedure.
2014 Jeep Cherokee
Latitude
3.2L Pentastar V6
Active Drive I
NHPATRIOT is offline
post #5 of 5 Old 10-11-2013, 02:40 PM Thread Starter
skip11and1
2013 MK Patriot
yea i figured it out thanks, this jeep is so weird you have to enter cheat codes for everything. Turning hill start control off was different.
