Bus Speed? - JeepForum.com
post #1 of 7 Old 10-31-2008, 01:07 PM Thread Starter
Argent33
2014 JK Wrangler
Bus Speed?
Ok so I have an 07 Compass
do I have a high speed or low speed BUS?
Trying to piece together a MyGIG system and want to make sure I get the right unit
~Paul
-[O l l l l l l l O]- 2014 Freedom Edition JKU - Hydro Blue 6-Spd
Argent33 is offline
post #2 of 7 Old 10-31-2008, 03:28 PM
Gramps
The Necessary Evil
Gramps's Avatar
2007 MK Compass
Tell me if this helps and if you need wiring diagrams.
DESCRIPTION
The primary on-board communication network between microprocessor-based electronic control modules in this vehicle is the Controller Area Network (CAN) data bus system. A data bus network minimizes redundant wiring connections; and, at the same time, reduces wire harness complexity, sensor current loads and controller hardware by allowing each sensing device to be connected to only one module (also referred to as a node). Each node reads, then broadcasts its sensor data over the bus for use by all other nodes requiring that data. Each node ignores the messages on the bus that it cannot use.
The CAN bus is a two-wire multiplex system. Multiplexing is any system that enables the transmission of multiple messages over a single channel or circuit. The CAN bus is used for communication between most vehicle nodes. However, in addition to the CAN bus network, certain nodes may also be equipped with a Local Interface Network (LIN) data bus. The LIN data bus is a single wire low-speed system used to provide direct communication between a master module and certain switch or sensor inputs.
There are actually three separate CAN bus systems used in the vehicle. They are designated: the CAN-B, the CAN-C and the Diagnostic CAN-C. The CAN-B and CAN-C systems provide on-board communication between all nodes in the vehicle. The CAN-C is the faster of the two systems providing near real-time communication (500 Kbps), but is less fault tolerant than the CAN-B system. The CAN-C is used exclusively for communications between critical powertrain and chassis nodes. The slower (83.3 Kbps), but more fault tolerant CAN-B system is used for communications between body and interior nodes. The CAN-B fault tolerance comes from its ability to revert to a single wire communication mode if there is a fault in the bus wiring.
The added speed of the CAN data bus is many times faster than previous data bus systems. This added speed facilitates the addition of more electronic control modules or nodes and the incorporation of many new electrical and electronic features in the vehicle. The Diagnostic CAN-C bus is also capable of 500 Kbps communication, and is sometimes informally referred to as the CAN-D system to differentiate it from the other high speed CAN-C bus. The Diagnostic CAN-C is used exclusively for the transmission of diagnostic information between the Totally Integrated Power Module/Central GateWay (TIPM or TIPMCGW) and a diagnostic scan tool connected to the industry-standard 16-way Data Link Connector (DLC) located beneath the instrument panel on the driver side of the vehicle.
The TIPM is located in the engine compartment near the battery. The central CAN gateway or hub module integral to the TIPM is connected to all three CAN buses. This gateway physically and electrically isolates the CAN buses from each other and coordinates the bi-directional transfer of messages between them.
Bob
posts 68 & 69
Also visit me at
Gramps is offline
post #3 of 7 Old 11-03-2008, 05:47 AM Thread Starter
Argent33
2014 JK Wrangler
nope didn't understand a word of that
thanks though Gramps!
~Paul
Argent33 is offline
post #4 of 7 Old 11-06-2008, 02:12 PM
merlinTec
merlinTec's Avatar
Hi
I don't believe you can have my gig anyway see here www.wkjeeps.com/wk_nav_2.htm
Regards,
Merlin
UK Chrysler Jeep Master Tec.
merlinTec is offline
post #5 of 7 Old 11-07-2008, 04:35 AM Thread Starter
Argent33
2014 JK Wrangler
http://www.coastaletech.com/MYGIG.htm
A guy in my car club has an 07 Caliber and he just installed a MyGIG system in it - he used the low speed bus one (he originally bought a high speed one - that didn't work so he sold it and bought a low speed one) guess I just didn't want to end up doing the same thing if it could be avoided...
~Paul
Argent33 is offline
post #6 of 7 Old 11-07-2008, 04:10 PM
merlinTec
merlinTec's Avatar
Hi
Cool can you post more info all the info I can find say not till 2009 on the MK and not listed as an option on accessories web site. I was told it could turn on but you get no sound.
Regards,
Merlin
post #7 of 7 Old 11-09-2008, 05:07 PM Thread Starter
Argent33
2014 JK Wrangler
http://www.caliberforums.com/forums/...ead.php?t=8971
~Paul
Argent33 is offline
Gas Mileage with a 5 speed Thelt Jeep Compass & Patriot Forum 6 08-24-2010 07:24 AM
Patriot-5 speed 4x4 vs CVT 4x4...?? DaveJKJ Jeep Compass & Patriot Forum 8 08-10-2009 07:00 AM
5 speed vs. CVT or FDI vs. FDII satanshollow Jeep Compass & Patriot Forum 1 08-15-2007 11:36 AM
5-Speed vs. CVT mthackerson Jeep Compass & Patriot Forum 1 08-05-2007 02:31 PM
Pics of 5 Speed Shifter dinger81 Jeep Compass & Patriot Forum 2 10-29-2006 10:58 AM
