Broken antenna 2008 Compass - JeepForum.com
post #1 of 2 Old 07-23-2013, 12:02 PM Thread Starter
GLFNDLFN
2008 MK Compass
Greetings fellow Jeep owners,
My girlfriend has a 2008 Jeep Compass. The antenna has snapped off at the post and I am curious how much effort it takes to replace the bracket, guessing depending on where it broke I am going to have to replace the bracket under the fender because it is likely I am not going to be able to get the broken post piece out. From my understanding I need to take the front wheel off and undo the wheel well cover in order to even access it, is this correct? If so, is it easy to access and replace? I have fairly large hands and not sure how much space I am going to have. Also, is there any special tools one might need to accomplish this task?
Thank you for your time.
GLFNDLFN is offline
post #2 of 2 Old 07-23-2013, 02:23 PM
JeepCares
FCA Customer Care
JeepCares's Avatar
REMOVAL (from the service manual)
see First Picture
1. Disconnect and isolate the battery negative cable.
2. Remove antenna mast by unscrewing mast from antenna body. On vehicles equipped with manual retractable antenna, lower antenna fully.
3. Remove shroud (1), if equipped.
4. Remove antenna nut (2) and adapter (3)
see Second picture
5. Disconnect antenna body cable from instrument panel antenna cable.
6. Remove inner fender shield as necessary to gain access to mounting fasteners.
7. Remove antenna body and cable (2) assembly from fender (1)
JeepCares is online now
