Brake squeak when reversing - JeepForum.com
post #1 of 16 Old 11-17-2008, 03:03 PM Thread Starter
Trek620
2008 MK Patriot
Now that is colder and damp out, my 08 Patriot experiences a "squeak squeak" sound from the rear (I think it's the brakes) and sometimes a groaning sound that can be quite loud. It only seems to happen when rolling in reverse and goes away after driving for a short time. Anyone experienced this or seen any information about it?
Thanks
Trek620 is offline
post #2 of 16 Old 11-17-2008, 04:18 PM
jbjeepguy
2007 MK Compass
It is normal- just a light coating of rust on the rotors that goes away after a few stops.
I bike therefore I work.
07 Compass, FDI, CVT
jbjeepguy is offline
post #3 of 16 Old 11-17-2008, 05:19 PM
Coasty161
there was a TSB a while back regarding the rear break noise in reverse. but i think it was for earlier models.. gramps might know where its located.
Coasty161 is offline
post #4 of 16 Old 11-17-2008, 05:31 PM
patrick3319
2008 MK Compass
actually mine did it before getting cold and has been doing it for a little bit now...my mechanic friends said its probably normal...but it gets annoyin as it does it all the time!
patrick3319 is offline
post #5 of 16 Old 11-17-2008, 07:42 PM
Coasty161
cant locate the TSB. however if i recall correctly its caused by a pin (?) or something that was installed backwards.
post #6 of 16 Old 11-17-2008, 07:56 PM
Coasty161
found this
Originally Posted by Gramps View Post
Doba,
Sorry that I didn't look here earlier. I didn't expect to see this in the SM, it's very lean on any trouble shooting info!
Found this in the Service Manual:
DISC BRAKE MOAN OR HOWL WHILE BRAKING IN REVERSE
Rear disc brake caliper guide pin bolts installed in incorrect locations.
Remove lower guide pin bolt and inspect for special sleeve on tip. If sleeve is present, remove upper and lower guide pin bolts and install special sleeved bolt in upper location and standard guide pin bolt in lower location. Perform on both sides of vehicle. Replace rear brake pads.
taken from here http://www.jeepforum.com/forum/showt...03#post3732703
post #7 of 16 Old 11-18-2008, 12:58 PM Thread Starter
Trek620
2008 MK Patriot
Good info
Thanks all, I'll hit up the dealer with my new found knowledge
Trek620 is offline
post #8 of 16 Old 11-18-2008, 06:27 PM
jeepin1995
jeepin1995's Avatar
anybody been to the dealer with this yet? also, it hasn't ever done it before, but started the past few days, i heard mention of moisuter buildup/slight rust, that would make sense in my case BUT it does it after driving, like when i back out of a space somewhere (no time for moisture to build up) plus it's pretty dry here right now.....
"IF YOU CAN'T DAZZLE THEM WITH FACTS, BAFFLE THEM WITH BS"
jeepin1995 is offline
post #9 of 16 Old 11-20-2008, 09:49 AM Thread Starter
Trek620
2008 MK Patriot
Not yet
I haven't gone to the dealer yet but it does seem to be getting worse in my case. I also experience it after it has been driven and sits for only a short time so it's a mystery. Could be the reversed pin thing.
Trek620 is offline
post #10 of 16 Old 11-20-2008, 10:14 AM
jeepin1995
jeepin1995's Avatar
that bulletin says for the rear..... my noise is coming from the front drivers side. in reverse only.
post #11 of 16 Old 12-15-2008, 01:46 PM Thread Starter
Trek620
2008 MK Patriot
Dealer visit
So... took it to the dealer, let it sit overnght, duplicatated the issue. Diagnosis-- "It's a characteristic of the vehicle due to film/rust on the brakes". Nothing they can do. (sigh)
Trek620 is offline
post #12 of 16 Old 12-25-2008, 10:05 PM
burrell9
2008 MK Patriot
mines has started moaing when i come to a complete stop from a short roll only time it will do it and it just started doing it... im taking the car to the dealership for a oil change and tire rotation soon they'll have to look at it then...
burrell9 is offline
post #13 of 16 Old 07-24-2010, 10:34 PM
jdaddy42
2008 MK Patriot
brake squeal
I took mine to the dealer twice on this subject. Mine had 49K miles on it. They said it was normal for it to squeal or make a noise. I find this hard to believe since brakes are brakes and they all have the same characteristics.
They replaced the brake shoes on the rear and it stopped for a couple of days. Then it started back again with a vengence sqeaking as loud as it ever did. I haven't had a chance yet but I am going to try what I do on all my brakes and put some (disc brake quiet) on the metal surfaces where it meets the pins so it won't squeal any more. I will let you know if it works or not
jdaddy42 is offline
post #14 of 16 Old 08-01-2010, 03:33 AM
jdaddy42
2008 MK Patriot
my brakes squeak also. They do it right before I start to stop. It is annoying. I took it to the dealer twice and they say it is normal. I have never heard of any brakes squeaking as being normal. they said they replaced the brake shoes on the rear. But it still makes the same noise. Going to try some (brake quiet) as soon as I get the motivation up to take off the rear wheels.
jdaddy42 is offline
post #15 of 16 Old 08-01-2010, 03:36 AM
jdaddy42
2008 MK Patriot
does anyone have a copy of that TSB about the reversed pin so I can take it to the dealer and show them idiots what the cause may be ? Since it seems they don't want to try and do anything about it since it is still under warranty.
jdaddy42 is offline
brake squeal , brakes , compass , mk , patriot
Brake Job mrspike118 Jeep Compass & Patriot Forum 41 12-30-2016 06:27 PM
Compass Brake Job lastid123 Jeep Compass & Patriot Forum 2 09-10-2009 04:26 PM
SRT Brake upgrade? Argent33 Jeep Compass & Patriot Forum 0 12-17-2008 09:17 PM
Brake Disc rust MSUman04 Jeep Compass & Patriot Forum 3 05-04-2008 07:28 AM
Strange honking noise from brakes while reversing Doba Jeep Compass & Patriot Forum 17 12-19-2007 02:49 PM
