Brake Job - Page 3 - JeepForum.com
post #31 of 42 Old 11-09-2012, 11:16 PM
dahozzman
2010 MK Compass
Additional information to know if you need to replace the discs if you can simply have them turned:
Front DiscSpecifications:
· 5 x 114.3 mm bolt pattern
· 294 mm disc diameter
· 13.15 mm bolt size
· 26 mm thickness
· 24 mm minimum thickness
Rear Disc Specifications:
· 302 mm disc diameter
· 12.6 mm bolt size
· 10 mm thickness
· 8.4 mm minimum thickness
dahozzman is offline
post #32 of 42 Old 04-15-2013, 12:13 PM
Gramps
The Necessary Evil
Gramps's Avatar
2007 MK Compass
I finally got around to doing my rear brakes and I replaced the rotors too. They were composite and the shop didn't want to turn them, they were scored and they said they couldn't guaranty the finish. I got just over 85K on the rears and they were easy as I suspected.
Bob
posts 68 & 69
Also visit me at
Gramps is offline
post #33 of 42 Old 01-03-2014, 10:35 AM
Gramps
The Necessary Evil
Gramps's Avatar
2007 MK Compass
From TigerKK, Video on front brake job:
Apologies for the lateness of reply, only just joined!
For future reference as I guess you've already resolved this, this is a decent youtube vid showing how to change the pads including the part you got snagged on,
We had the same issue, I wasn't aware of the little nipple things on the face of the brake pad!
http://www.jeepforum.com/forum/f98/0.../#post18912849
http://www.youtube.com/watch?v=XoBXeCEfKuk#t=131
Bob
posts 68 & 69
Also visit me at
Gramps is offline
post #34 of 42 Old 01-06-2014, 05:58 PM
Redpine
2014 MK Patriot
For you guys that do the rear pad slap without removing the top caliper pin, how do you clean and relube the top pin?
After 80,000 or more miles, it seems that the top pin will require lube to prevent it from seizing prematurely in your new pad installation.
Redpine is offline
post #35 of 42 Old 01-06-2014, 06:16 PM
IRSmart
2015 KL Cherokee
so our compass has 65k miles on the original brakes...I should probably look at them
IRSmart is offline
post #36 of 42 Old 01-07-2014, 02:10 PM
Gramps
The Necessary Evil
Gramps's Avatar
2007 MK Compass
Redpine - I always pull and lube the pins. Can't help you there.
IRSmart - you're about do but just take a look through your wheels.
Bob
posts 68 & 69
Also visit me at
Gramps is offline
post #37 of 42 Old 01-08-2014, 07:08 PM
Redpine
2014 MK Patriot
The reason I asked is because on another thread (s), people claimed that the brake line interfered with removal of the top caliper pin. So, many people seem to choose just leaving the top pin in, rotating the caliper up, and avoid undoing the brake line.
Redpine is offline
post #38 of 42 Old 01-09-2014, 02:39 AM
Gramps
The Necessary Evil
Gramps's Avatar
2007 MK Compass
It's been a while since I did mine but I did not remove the brake line. It's -11 degrees right now so I can't go out and look at it to tell you why.
Bob
posts 68 & 69
Also visit me at
Gramps is offline
post #39 of 42 Old 05-19-2015, 11:19 AM
TheLurker
Gramps,
is there any special way to remove the front rotors?
I need to replace my whole wheel assembly along with the rotors, eventually, however cash-flow is limited but i need to be safe at the same time so i intend to replace the rotors and brakes. most of the cars and trucks that i have worked on that use disk brakes do not require any bolts to remove the rotor, but i believe this one does. through the years the nut on the front of the assembly has become coroded and rusted into one entity.
really could use your, or someones, help with this.
Thanks,
The Lurker
2007 jeep compass FWD 2.4L I4 95,000 miles
p.s. I have almost replaced the entire suspension on this d**n car. is this an issue with anyone elses?
List of repairs in the last 3 months:
control arms
struts
ball joints (twice)
inner and outer tie rods (twice)
alternator (this one was my favorite... pain in my a$$) who the hell mounts the alternator on the underside of the motor... almost inaccessible.
what I am doing this weekend.. should be easy... maybe??
* calipers
* rotors
* pads
TheLurker is offline
post #40 of 42 Old 12-25-2016, 11:56 AM
mjcougler
2015 WK
Rear Brakes caliper slide pins
Redpine, You make an excellent point! I replaced the LR wheel bearing on my daughters 2011 compass, and in reassembling the brakes, I noticed the upper slide pin did not "feel"right, but I had to put it back together anyway. When I drove home about four miles, the LR brakes smelled terrible from overheating. I took it all apart the next morning and realized the problem was the upper slide pin was seized. It was so tight that to loosen it, I had to put a 14mm OE wrench on the bolt and I pushed back the little rubber slide pin boot and sprayed a little PB Blaster onto the pin, and I had to raise and lower the caliper and wrench at the same time. I had to continue lifting and lowering the caliper and wrench at least 40 times, replying PB Blaster about every 8-10 times. I was finally able to slide the caliper back enough to get the slide pin to come out of the slide cavity. The slide pin will not come out of the caliper because of the interference with the brake hose collar (design Flaw!). Using PB Blaster and a small brush from Harbor Freight, I was able to clean the dried caliper lube out of the slide cavity. I finally was able to use PB Blaster to get the lower slide bolt to be able to slide into the upper cavity to continue to clean out the upper slide cavity. I then wiped the PB Blaster off the slide pin and reinserted it many times to clean the PB Blaster out of the slide pin cavity. I then used the lower slide pin to lubricate the inside of the upper slide cavity by spinning the pin and lube in the cavity. I then cleaned the lower slide cavity using basically the same procedure. Once lubed and all back together, the caliper was able to slide back and forth correctly.
In all of this, I also realized the little rubber tip was not on the slide pin. I had to put it back without it. What does that rubber tip do anyway? What happens without it?
I hope this helps others to thoroughly clean and lubricate the slide pins to solve this problem.
And in an interesting afterthought, my daughter bought this car used, about 10 weeks ago, and the Jeep salesman said they had installed new brakes all around. So... it was a Jeep tech that did not clean and lube the slide pins correctly 12 weeks ago.
Mike Cougler
15 Jeep GCL; 11 Jeep CL; 67 Jeep M725 Ambulance;
04 Ram 2500 CTD; 46 Willys CJ2A
mjcougler is offline
post #41 of 42 Old 12-30-2016, 03:21 AM
DEF1ANT
2014 MK Compass
Definitely need that rubber tip installed. It keeps the silicon lube in and prevents moisture and dirt from getting inside, which could rust/seize the pin in place.
DEF1ANT is offline
post #42 of 42 Old 12-30-2016, 06:27 PM
mjcougler
2015 WK
DEF1ANT,
It sounds like you are describing the accordion-like rubber boots that surrounds the smooth lubricated slide pins to keep out dirt and moisture and they keep the slide pins clean and prevent rust. The rubber TIP I noticed that was missing when I pulled the slide pin out of the slide cavity was the small rubber tip that fits around the machined area at the end of the upper slide pin. In use, the rubber tip is on the end of the slide pin, deep inside the cavity; and, as the brake pad wears, the caliper slides + and - 1/2-inch. And, my assumption is the rubber tip keeps lube around itself as the rubber tip wipes the cavity walls as the caliper slides in and out every time you apply the brakes. For example, why does the lower caliper slide pin not have the rubber tip, if it is needed on the upper slide pin? I did read the post about rear brake noises during braking if the slide pins are reversed. I'm trying to understand the physics of, and the purpose of the rubber tip.
I went to the Advance Auto Parts website and searched for slide pin hardware for a 2011 Compass Latitude, and it pulled up a photo of the Wearever Disc Brake Caliper Guide Pin Boot Kit, Part No. 16109A In the photo are four slide pin boots for both L & R rear, upper and lower slide pins, and the photo shows the two upper slide pin rubber tips.
And, the last person to do a brake job on this car was the technician at the Jeep dealership that was selling this car. This makes me wonder what kind of work they do on their other Jeep brake jobs. Why would he/she remove the rubber tip and reinstall the caliper and slide pin. The slide pin, and brake hose "end" preventing the pin from being removed, had enough rust on it that it looks to be the factory original, not a new slide pin installed when he/she did the brake job, less than 6-monts ago in prepping the car before putting it on the sales lot. Again, what is the purpose of the rubber tip?
Thanks again.
Mike Cougler
brakes , compass , patriot , replacement
Brake squeak when reversing Trek620 Jeep Compass & Patriot Forum 15 08-03-2010 11:24 PM
Compass Brake Job lastid123 Jeep Compass & Patriot Forum 2 09-10-2009 04:26 PM
SRT Brake upgrade? Argent33 Jeep Compass & Patriot Forum 0 12-17-2008 09:17 PM
Brake Disc rust MSUman04 Jeep Compass & Patriot Forum 3 05-04-2008 07:28 AM
No brake lights on Patriot tb7063 Jeep Compass & Patriot Forum 13 02-12-2008 07:04 AM
