Brake Job - JeepForum.com
Go Back JeepForum.com > Models > Compass & Patriot Forum > Brake Job
Introducing MONSTALINER™ UV Permanent DIY Roll On Bed LineRaceline/Allied Wheels on Sale NOW !Bead Lock Wheels! Raceline, Trail Ready, & Trail-Gear
Unread 04-21-2008, 03:52 PM   #1
mrspike118
Brake Job
Hi all! New to the forum, my fiance has a 2007 Jeep Compass and loves it. I had a grand cherokee and that is what got her hooked on jeeps, but I had to sell it because of the price of gas. But my main question is she is going to need pads soon (35k on this guy already) and I was wondering if there are any pointers or tips and tricks that anyone knows of to change the pads and rotors (I am not changing the rotors, just for future use). Any special tools or such that is needed? Thanks in advance!
Brandon N.
mrspike118 is offline   Reply With Quote
Unread 04-23-2008, 07:57 PM   #2
Gramps
The Necessary Evil
Gramps's Avatar
2007 MK Compass
This is a work in progress! No really special tools, pretty straight forward. Lots of editing and pics to clean up. Patients, OK? 29K on mine, not too far behind you.
Bob
MK Skid Plate fasteners for sale posts 68 & 69
Also visit me at Photobucket
Gramps is offline   Reply With Quote
Unread 04-23-2008, 11:54 PM   #3
jeepheller98
i would just do rotors with it.. they are cheap enough, and if they warp half way through the life of the new pads, then you need new pads again. make sure you have a C clamp to compress the caliper, take the cap off the resivor, grease all the caliper pins too.. while you have the wheels off this is a great time to hit any grease fittings
98 ZJ 3" lift homemade snorkel. JKS quicker disco 5.2L 150,000, 31x10.5 pro comp muds
jeepheller98 is offline   Reply With Quote
Unread 04-29-2008, 04:27 AM   #4
Gramps
The Necessary Evil
Gramps's Avatar
2007 MK Compass
SOP, Cautions and Warnings
WARNING: Dust and dirt accumulating on brake parts during normal use may contain asbestos fibers from production or aftermarket brake linings. Breathing excessive concentrations of asbestos fibers can cause serious bodily harm. Exercise care when servicing brake parts. Do not sand or grind brake lining unless equipment used is designed to contain the dust residue. Do not clean brake parts with compressed air or by dry brushing. Cleaning should be done by dampening the brake components with a fine mist of water, then wiping the brake components clean with a dampened cloth. Dispose of cloth and all residue containing asbestos fibers in an impermeable container with the appropriate label. Follow practices prescribed by the Occupational Safety And Health Administration (OSHA) and the Environmental Protection Agency (EPA) for the handling, processing, and disposing of dust or debris that may contain asbestos fibers.
CLEANING
To clean or flush the internal passages of the brake caliper, use fresh brake fluid or Mopar® Non-Chlorinated Brake Parts Cleaner. Never use gasoline, kerosene, alcohol, oil, transmission fluid or any fluid containing mineral oil to clean the caliper. These fluids will damage rubber cups and seals.
INSPECTION
Visually inspect brake pads for uneven lining wear. Also inspect for excessive lining deterioration. Check the clearance between the tips of the wear indicators (if equipped) on the pads and the brake rotors.
If a visual inspection does not adequately determine the condition of the lining, a physical check will be necessary. To check the amount of lining wear, remove the disc brake pads from the vehicle.
Measure brake pad minimum thickness. Brake pads must be replaced when usable material on a brake pad lining measured at its thinnest point measures one millimeter (0.04 inches) or less.
NOTE: It is important to inspect both front and rear brake pads during the same inspection. Typically, front and rear brake pads wear out at the same time.
Replace both disc brake pads (inboard and outboard) at each caliper. It is also necessary to replace the pads on the opposite side of the vehicle as well as the pads failing inspection to maintain proper braking characteristics.
If the brake pad assemblies do not require replacement, be sure to reinstall the brake pads in the original position they were removed from.
CAUTION: Do not use petroleum-based fluid because seal damage in the brake system will result. The brake fluid used in this vehicle must conform to DOT 3 specifications and SAE J1703 standards. No other type of brake fluid is recommended or approved for usage in the vehicle brake system. Use only Mopar® Brake Fluid DOT 3 Motor Vehicle or equivalent from a tightly sealed container.
CAUTION: Brake fluid will damage painted surfaces. If brake fluid is spilled on any painted surfaces, wash it off immediately with water.
CAUTION: Never use gasoline, kerosene, alcohol, motor oil, transmission fluid, or any fluid containing mineral oil to clean system components. These fluids damage rubber cups and seals.
CAUTION: During service procedures, grease or any other foreign material must be kept off the caliper assembly, brake linings, brake rotor and external surfaces of the hub.
CAUTION: When handling the brake rotor and caliper, be careful to avoid damaging the brake rotor and caliper, and scratching or nicking the brake shoe lining.
CAUTION: Never use reclaimed brake fluid or fluid from a container which has been left open. An open container will absorb moisture from the air and contaminate the fluid.
ABS Service
CAUTION
The antilock brake system uses an electronic control module known as the Antilock Brake Module (ABM). This module is designed to withstand normal current draws associated with vehicle operation. Care must be taken to avoid overloading the circuits.
CAUTION: In testing for open or short circuits, do not ground or apply voltage to any of the circuits unless instructed to do so for a diagnostic procedure.
CAUTION: These circuits should only be tested using a high impedance multi-meter or the designated scan tool as described in this section. Power should never be removed or applied to any control module with the ignition in the ON position. Before removing or connecting battery cables, fuses, or connectors, always turn the ignition to the OFF position.
CAUTION: The ABM 47-way connector should never be connected or disconnected with the ignition switch in the ON position.
CAUTION: This vehicle utilizes active wheel speed sensors. Do not apply voltage to wheel speed sensors at any time.
CAUTION: Use only factory wiring harnesses. Do not cut or splice wiring to the brake circuits. The addition of aftermarket electrical equipment (car phone, radar detector, citizen band radio, trailer lighting, trailer brakes, etc.) on a vehicle equipped with antilock brakes may affect the function of the antilock brake system.
CAUTION: When performing any service procedure on a vehicle equipped with ABS, do not apply a 12-volt power source to the ground circuit of the pump motor in the HCU. Doing this will damage the pump motor and will require replacement of the entire HCU.
CAUTION: An attempt to remove or disconnect certain system components may result in improper system operation. Only those components with approved removal and installation procedures in this manual should be serviced.
CAUTION: If welding work is to be performed on the vehicle using an electric arc welder, the ABM connector should be disconnected during the welding operation.
CAUTION: Many components of the ABS are not serviceable and must be replaced as an assembly. Do not disassemble any component which is not designed to be serviced.
CAUTION: Only the recommended jacking or hoisting positions for this vehicle are to be used whenever it is necessary to lift a vehicle.
1. Raise and support the vehicle.
2. Remove the wheel mounting nuts (3), then the tire and wheel assembly (1).
Bob
Unread 04-29-2008, 04:28 AM   #5
Gramps
The Necessary Evil
Gramps's Avatar
2007 MK Compass
Front Brakes
NOTE: Perform STEP 1 through STEP 3 on each side of the vehicle to complete pad set removal.
NOTE: When removing the caliper guide pin bolts (2, 3) note that one (upper) has a special sleeve on the end. It important that his bolt be installed in the upper mounting hole when the caliper is installed.
Fig A
1. Remove the two brake caliper guide pin bolts (2, 3). 2. Remove the disc brake caliper (4) from the disc brake adapter bracket (1) and hang it out of the way using wire or a bungee cord. Use care not to overextend the brake hose when doing this.
Fig B
3. Remove the brake pads (4, 5) from the caliper adapter bracket (2).
INSTALLATION
NOTE: Perform STEP 1 through STEP 5 on each side of the vehicle to complete pad set installation, then proceed to STEP 6.
NOTE: Make sure that the audible wear indicators (if equipped) are placed toward the top when the inboard brake pads are installed on each side of the vehicle.
Fig B
1. Place the brake pads (4, 5) in the abutment shims (3) clipped into the disc brake caliper adapter bracket (2) as shown. Place the pad with the wear indicator attached on the inboard side (2).
2. Completely retract the caliper piston back into the bore of the caliper.
CAUTION: Use care when installing the caliper (4) onto the adapter bracket (1) to avoid damaging the boots.
Fig A
3. Install the disc brake caliper over the brake pads on the brake caliper adapter bracket.
NOTE: When installing the caliper guide pin bolts (2, 3) make sure that the one that has a special sleeve on the end is installed in the upper mounting hole.
4. Align the caliper guide pin bolt holes with the adapter bracket. Install the upper (with special sleeve) (2) and lower (3) caliper guide pin bolts. Tighten the guide pin bolts to 43 N•m (32 ft. lbs.).
5. Install the tire and wheel assembly (1). Install and tighten the wheel mounting nuts (3) to 135 N•m (100 ft. lbs.).
6. Lower the vehicle.
7. Pump the brake pedal several times before moving the vehicle to set the pads to the brake rotor.
8. Check and adjust the brake fluid level in the reservoir as necessary.
9. Road test the vehicle and make several stops to wear off any foreign material on the brakes and to seat the brake pads.
Bob
Unread 04-29-2008, 04:31 AM   #6
Gramps
The Necessary Evil
Gramps's Avatar
2007 MK Compass
Front Caliper Removal
REMOVAL
Fig 1A
1. Using a brake pedal holding tool as shown, depress the brake pedal past its first 25 mm (1 inch) of travel and hold it in this position. This will isolate the master cylinder from the brake hydraulic system and will not allow the brake fluid to drain out of the master cylinder reservoir when the lines are opened.
2. Raise and support the vehicle.
Fig 1B
4. Remove the banjo bolt (4) connecting the brake flex hose (2) to the brake caliper (5). There are two washers (3) that will come off with the banjo bolt. Discard the washers.
Fig 1C
5. Remove the two brake caliper guide pin bolts (2, 3).
6. Slide the disc brake caliper (4) from the disc brake adapter bracket (1) and brake pads and remove.
Bob
Unread 04-29-2008, 04:33 AM   #7
Gramps
The Necessary Evil
Gramps's Avatar
2007 MK Compass
Disassemble and Assemble
Disassembly
Fig 2A
1. Mount the caliper in a vise equipped with protective jaws.
WARNING: Do not place face or hands near caliper and piston if using compressed air pressure to remove piston. Do not use high pressure.
2. Place a wooden block (1) in the caliper as shown.
3. If necessary, apply low pressure compressed air to the caliper fluid inlet in short spurts to force the piston out.
4. Remove the piston from the caliper.
5. Remove the dust boot from the piston and discard it.
Fig 2B
CAUTION: Do not use a screw driver or other metal tool for seal removal. Using such tools can scratch the bore or leave burrs on the seal groove edges.
6. Using a soft tool such as a plastic trim stick (1), work the piston seal (2) out of its groove in caliper piston bore. Discard the used seal.
7. Clean the piston bore and drilled passage ways with alcohol or a suitable solvent. Wipe it dry using only a lint-free cloth.
8. Inspect both the piston and bore for scoring or pitting. Bores that show light scratches or corrosion can usually be cleared of the light scratches or corrosion using crocus cloth.
ASSEMBLY
Fig 2B
NOTE: Always have clean hands when assembling a brake caliper.
NOTE: Always use fresh, clean brake fluid when assembling a brake caliper.
NOTE: Never use an old piston seal.
1. Dip the NEW piston seal in clean brake fluid and install it in the groove (2) of the caliper bore. The seal (1) should be started at one area of the groove and gently worked around into the groove using only your clean fingers to seat it.
Fig 2C
2. Coat the NEW piston with clean brake fluid.
3. Coat the NEW piston boot with clean brake fluid leaving a generous amount inside the boot.
4. Position the dust boot over the lower section of the piston.
5. Extend the dust boot below the bottom of the piston and guide the lip seal into the groove in the caliper piston bore.
Fig 2D
CAUTION: Force applied to the piston (1) to seat it in the bore must be applied uniformly to avoid cocking and binding of the piston.
6. Install the piston (1) into the bore, carefully pushing it past the piston seal using hand pressure. Push the piston in until it bottoms in the caliper bore and the dust boot lip seal falls into the groove near the top of the piston.
7. Install the caliper on the vehicle and bleed the brakes as necessary.
INSTALLATION
Fig 1C
1. Completely retract the caliper piston back into the bore of the caliper. Use a C-clamp to retract the piston. Place a wood block over the piston before installing the C-clamp to avoid damaging the piston.
CAUTION: Use care when installing the caliper (4) onto the adapter bracket (1) to avoid damaging the guide pin boots.
2. Install the disc brake caliper over the brake pads on the brake caliper adapter bracket.
3. Align the caliper guide pin bolt holes with the adapter bracket. Install the upper (with special sleeve) (2) and lower (3) caliper guide pin bolts. Tighten the guide pin bolts to 43 N•m (32 ft. lbs.).
Fig 1B
4. Install the banjo bolt (4) connecting the brake flex hose (2) to the brake caliper (5). Install NEW washers (3) on each side of the hose fitting as the banjo bolt is guided through the fitting. Thread the banjo bolt into the caliper and tighten it to 24 N•m (18 ft. lbs.).
5. Install the tire and wheel assembly. Install and tighten the wheel mounting nuts (3) to 135 N•m (100 ft. lbs.).
7. Remove the brake pedal holding tool.
Fig 3A
8. Bleed the caliper as necessary.
9. Road test the vehicle and make several stops to wear off any foreign material on the brakes and to seat the brake shoes.
front-caliper2a.jpg   front-caliper-2b.jpg   front-caliper-2c.jpg   front-caliper-2d.jpg   front-caliper3a.jpg
Bob
Unread 04-29-2008, 04:35 AM   #8
Gramps
The Necessary Evil
Gramps's Avatar
2007 MK Compass
Rear Brakes
NOTE: If the rear brake pads are being replaced due to a howl or moan while driving in reverse, proper diagnosis and correction is essential.
BRAKE MOAN OR HOWL WHILE BRAKING IN REVERSE
Rear disc brake caliper guide pin bolts installed in incorrect locations.
Remove lower guide pin bolt and inspect for special sleeve on tip. If sleeve is present, remove upper and lower guide pin bolts and install special sleeved bolt in upper location and standard guide pin bolt in lower location
Perform on both sides of vehicle. Replace rear brake pads.
REMOVAL
NOTE: In some cases, it may be necessary to retract the caliper piston in its bore a small amount in order to provide sufficient clearance between the pads and the rotor to easily remove the caliper from the knuckle. This can usually be accomplished before the guide pin bolts are removed, by grasping the rear of the caliper and pulling outward working with the guide pins, thus retracting the piston. Never push on the piston directly as it may get damaged.
Fig A
1. Remove the disc brake caliper (2) lower guide pin bolt (1).
Fig B
CAUTION: When moving rear brake caliper upward, use extreme care not to damage or overextend the flex hose. Damage may occur.
2. Rotate the caliper (1) upward hinging off the upper guide pin bolt. Rotate the caliper upward just enough to allow brake pad removal. Hang the caliper assembly in this position using wire or a bungee cord.
Fig C
3. Remove the inboard brake pad (5) from the caliper adapter bracket (3).
4. Remove the outboard brake pad (2) from the caliper (1) by prying the brake pad retaining clip over the raised area on the caliper. Slide the brake pad off of the brake caliper.
INSTALLATION
NOTE: Perform STEP 1 through STEP 6 on each side of the vehicle to complete pad set installation, then proceed to STEP 7.
1. Completely retract the caliper piston back into the piston bore of the caliper. This is required to gain the necessary pad-to-rotor clearance for the caliper installation onto the steering knuckle.
NOTE: Place the brake pad with the audible wear indicator attached on the inboard side. The audible wear indicator should be positioned at the bottom when installed.
2. Slide the outboard brake pad (2) onto the caliper (1). Be sure the retaining clip is squarely seated in the depressed areas on the caliper beyond the raised retaining bead.
3. Place the inboard brake pad (5) in the abutment shims (4) clipped into the disc brake caliper adapter bracket (3) as shown (see preceding note).
CAUTION: Use care when installing the caliper onto the adapter bracket to avoid damaging the guide pin boot.
4. Rotate the disc brake caliper downward over the brake rotor and lower part of caliper adapter.
5. Install the disc brake caliper (2) lower guide pin bolt (1). Tighten the guide pin bolt to 43 N•m (32 ft. lbs.).
NOTE: Once the caliper is installed, inspect the outboard brake pad to make sure it is correctly positioned. The retaining clip (2) must be squarely seated in the depressed areas (1) on the caliper fingers. Also, the nubs on the pad's steel backing plate must be fully seated in the depressions formed into the inside of the caliper fingers. There should be no gap between the pad backing plate and the caliper fingers.
6. Install the tire and wheel assembly Install and tighten the wheel mounting nuts (3) to 135 N•m (100 ft. lbs.).
7. Lower the vehicle.
8. Pump the brake pedal several times to ensure the vehicle has a firm brake pedal before moving the vehicle.
Bob
Unread 04-29-2008, 04:38 AM   #9
Gramps
The Necessary Evil
Gramps's Avatar
2007 MK Compass
Rear caliper Removal and Disassemble
REMOVAL
1. Using a brake pedal holding tool as shown, depress the brake pedal past its first one inch of travel and hold it in this position. This will isolate the master cylinder from the brake hydraulic system and will not allow the brake fluid to drain out of the master cylinder reservoir while the lines are disconnected.
3. Remove the wheel mounting nuts (3), then the rear tire and wheel assembly.
Fig 1A
4. Unthread the brake tube nut (2) at the rear flex hose.
5. Remove the clip (3) securing the rear flex hose to the trailing link mounted bracket. Remove the flex hose from the bracket.
6. Unthread and remove the brake flex hose (4) from the brake caliper (1).
Fig 1B
NOTE: When removing the caliper guide pin bolts (2, 3), note that one bolt has a special sleeve on the tip and the other does not. Depending on the build date, this special sleeve bolt (3) can be located in either the top or bottom location. When installing, make sure the bolts are put back in the same locations as when removed to avoid NVH issues.
7. Remove the two brake caliper guide pin bolts (2, 3).
8. Slide and remove the disc brake caliper (1) with outboard brake pad attached from the disc brake adapter bracket, inboard brake pad and rotor.
9. Remove the outboard brake pad from the caliper by prying the brake pad retaining clip over the raised area on the caliper. Slide the brake pad off of the brake caliper.
Fig 2A
DISASSEMBLY
NOTE: Before disassembling the brake caliper, remove it from the vehicle. (Refer to 5 - BRAKES/HYDRAULIC/MECHANICAL/DISC BRAKE CALIPER - REMOVAL)
NOTE: Before disassembling the brake caliper, clean and inspect it. (Refer to 5 - BRAKES/HYDRAULIC/MECHANICAL/DISC BRAKE CALIPER - CLEANING) (Refer to 5 - BRAKES/HYDRAULIC/MECHANICAL/DISC BRAKE CALIPER - INSPECTION)
1. With finger tip, trace around the outside perimeter of the piston dust boot to find the ends of the boot snap-ring.
2. Using a small screwdriver (2) or like tool, carefully remove the boot snap-ring (1) making sure not to damage the dust boot, piston or piston bore.
3. Carefully pull the piston dust boot away from the caliper boot groove.
WARNING: Under no condition should high pressure air ever be used to remove a piston from a caliper bore. Personal injury could result from such a practice.
Fig 2B
CAUTION: Do not use excessive force when clamping caliper in vise. Excessive vise pressure will cause bore distortion.
4. Mount the caliper in a vise equipped with protective jaws.
5. Place a wooden block (2) in the caliper as shown.
6. As necessary, apply low pressure compressed air to the caliper fluid inlet in short spurts to force the piston (1) out.
7. Remove the piston (with dust boot) from the caliper.
8. Remove the dust boot from the piston and discard it.
Fig 2C
9. Using a soft tool such as a plastic trim stick (2), work the piston seal (1) out of its groove (3) in the caliper piston bore. Discard the used seal.
10. Clean the piston bore and drilled passage ways with alcohol or a suitable solvent. Wipe it dry using only a lint-free cloth.
11. Inspect both the piston and bore for scoring or pitting. Bores that show light scratches or corrosion can usually be cleared of the light scratches or corrosion using crocus cloth.
rear-caliper-1a.jpg   rear-caliper-1b.jpg   rear-caliper2a.jpg   rear-caliper-2b.jpg   rear-caliper-2c.jpg
Bob
Unread 04-29-2008, 04:41 AM   #10
Gramps
The Necessary Evil
Gramps's Avatar
2007 MK Compass
Rear Caliper Assemble and Instalation
ASSEMBLY
Fig 3A
1. Dip the NEW piston seal in clean brake fluid and install it in the groove (2) of the caliper piston bore. The seal (1) should be started at one area of the groove and gently worked around into the groove using only clean finger tips to seat it.
Fig 3B
2. Coat the NEW piston dust boot (1) with clean brake fluid leaving a generous amount inside the boot.
3. Position the dust boot over the top of the piston (2) and into the piston groove. Make sure the side of the dust boot with the outer lip (3) for the boot snap-ring is positioned upward as shown.
4. Coat the piston with clean brake fluid.
Fig 3C
CAUTION: Force applied to the piston to seat it in the bore must be applied uniformly to avoid cocking and binding of the piston.
5. Insert the piston into the caliper bore, carefully pushing it past the piston seal using hand pressure. Push the piston in until it bottoms in the caliper bore.
Fig 3D
6. With finger tips, seat the dust boot lip (1) into the boot groove in the caliper bore. Trace around the outside perimeter of the dust boot with a finger tip making sure the lip is properly seated in the groove and not much air is trapped behind the boot.
Fig 3E
7. Position one end of the boot snap-ring (1) inside the boot outer lip (2), then making a circular motion, walk the snap-ring around the boot lip, completely installing and seating it.
8. Inspect whether the two ends of the boot snap-ring are not overlapping one another. If they are, push the snap ring and dust boot further into groove removing any overlap of the snap-ring.
9. Install the caliper on the vehicle and bleed the brakes as necessary.
INSTALLATION
1. If not already performed, completely retract the caliper piston back into the piston bore of the caliper. Use a C-clamp to retract the piston. Place a wood block over the piston before installing the C-clamp to avoid damaging the piston.
2. Slide the outboard brake pad onto the caliper. Be sure the retaining clip is squarely seated in the depressed areas on the caliper beyond the raised retaining bead.
Fig 1B
CAUTION: Use care when installing the caliper onto the disc brake adapter to avoid damaging the guide pin boots.
3. Install the disc brake caliper with outboard brake pad attached over the inboard brake pad and rotor, onto the brake caliper adapter bracket.
NOTE: When installing the caliper guide pin bolts (2, 3), make sure the bolts are put back in the same locations as when removed to avoid NVH issues. Depending on the build date and services performed, the location of the bolt with the special sleeve on the tip (3) can vary.
4. Align the caliper guide pin bolt holes with the adapter bracket. Install the lower (with special sleeve) (2) and upper (3) caliper guide pin bolts. Tighten the guide pin bolts to 43 N•m (32 ft. lbs.).
rear-caliper-3a.jpg   rear-caliper-3b.jpg   rear-caliper-3c.jpg   rear-caliper-3d.jpg   rear-caliper-3e.jpg
Bob
Unread 04-29-2008, 04:42 AM   #11
Gramps
The Necessary Evil
Gramps's Avatar
2007 MK Compass
Rear Caliper Installation (cont.)
Fig 4A
Fig 1A
5. Thread the rear brake flex hose (4) into the brake caliper (1). Tighten the flex hose fitting at the caliper to 15 N•m (133 in. lbs.).
6. Route and install the brake flex hose into the trailing link mounted bracket. Install the clip (3) securing the flex hose to the bracket.
7. Thread the brake tube nut (2) into brake flex hose. Tighten the brake tube nut to 17 N•m (150 in. lbs.).
8. Install the tire and wheel assembly. Install and tighten the wheel mounting nuts (3) to 135 N•m (100 ft. lbs.).
9. Lower the vehicle.
10. Remove the brake pedal holding tool.
11. Bleed the caliper as necessary.
12. Road test the vehicle and make several stops to wear off any foreign material on the brakes and to seat the brake shoes.
Bob
Unread 04-29-2008, 04:45 AM   #12
Gramps
The Necessary Evil
Gramps's Avatar
2007 MK Compass
Parking Brake Removal
REMOVAL
NOTE: If removing parking brake shoes on both sides of vehicle, perform remaining steps on each side of the vehicle.
Fig 1A
2. Access and remove the rear brake rotor (3).
3. Turn the brake shoe adjuster wheel until the adjuster is at shortest length.
Fig 1B
4. Remove the upper return spring (1) from the anchor pin (3) and the rear brake shoe.
5. Remove the upper return spring (2) from the anchor pin (3) and the front brake shoe.
Fig 1C
6. Remove the brake shoe hold-down springs and pins (1, 2). Rotate the pins 90° to disengage.
Fig 1D
7. Remove the parking brake cable from the lever on the rear parking brake shoe.
Fig 1E
8. Remove the brake shoes (2, 6), adjuster (5) and lower return spring (3) as an assembly from the support plate.
9. If necessary, remove the strut (1).
10. Remove the lower return spring (3) and adjuster (5) from the shoes (2, 6).
Bob
Unread 04-29-2008, 04:47 AM   #13
Gramps
The Necessary Evil
Gramps's Avatar
2007 MK Compass
Parking Brake Installation
INSTALLATION
NOTE: If replacing parking brake shoes on both sides of vehicle, perform STEP 1 through STEP 15 on each side of the vehicle to complete shoe set installation, then proceed to STEP 16.
NOTE: Left side shoes are shown in the figure. Right side shoes are a mirror image of the left except for the adjuster. The threaded portion of the adjuster should always be positioned to the left side in order to maintain consistent side-to-side rotational direction for adjustment purposes.
Fig 1E
1. Install the lower return spring (3) and adjuster (5) between the parking brake shoes (2, 6). The rear shoe will have the lever mounted on the inside. Make sure the threaded portion of the adjuster is mounted to the left on both right and left side parking brake assemblies (see preceding note).
2. If necessary, place the strut (1) above the hub and bearing on the vehicle. Note the curved end of the strut (1) is positioned to the rear.
3. Install the assembled brake shoes (2, 6), adjuster (5) and lower return spring (3) over the hub and bearing and onto the support plate and anchor. Be sure to install the strut between the front shoe and the lever on the rear shoe.
Fig 1D
4. Install the parking brake cable onto the lever on the parking brake shoe.
Fig 1C
5. Install the brake shoe hold-down springs and pins (1, 2). Rotate the pins 90° to engage.
Fig 1B
6. Install the front upper return spring (2) holding the front brake shoe and anchor pin (3).
7. Install the rear upper return spring (2) holding the rear brake shoe and anchor pin (3).
Fig 2A
8. Using Brake Shoe Gauge, Special Tool C-3919, or equivalent, measure the inside diameter of parking brake drum portion of rotor. Set the Gauge.
Fig 2B
9. Place Gauge (2) over the parking brake shoes (1) at their widest point.
10. Using the adjuster wheel, adjust the parking brake shoes until the linings on both parking brake shoes just touch the jaws on the Gauge.
Fig 1A
11. Install the rear brake rotor (3) and install a couple wheel mounting nuts to hold it in place while a final adjustment is made.
Fig 2C
NOTE: To find the adjuster wheel with the drum on position the hole (1) in the front of the rotor drum as follows:
Left side – 7 o'clock.
Right side – 5 o'clock.
NOTE: When adjusting the parking brake shoes with the drum-in hat rotor installed, rotating the adjuster wheel (2) upward will loosen the adjustment. Rotating the adjuster wheel (2) downward will tighten the adjustment.
12. Remove the rubber plug from the hole (1) in the front of the rotor.
13. Utilizing the hole (1) in the front of the rotor, make a final adjustment of the shoes if necessary.
14. Reinstall the rubber plug.
Fig 1A
15. Remove the wheel mounting nuts and finish installing the brake rotor (3) as well as all components removed to access it.
16. Lower the vehicle.
17. Cycle the parking brake lever once, verifying proper operation of the parking brake.
PARKING BRAKE SHOE ADJUSTMENT ONLY
NOTE: The parking brake shoes used in the drum-in-hat park brake system do not automatically adjust to compensate for brake shoe lining wear. Therefore, it is necessary to manually adjust the parking brake shoes.
1. Verify the parking brake lever is in the released (down) position.
Fig 1A
3. Remove the wheel mounting nuts (3), then the tire and wheel assembly (1).
4. Install a couple wheel mounting nuts to hold the brake rotor in place while adjustment of the brake shoes is made.
Fig 2C
5. Remove the rubber plug from the hole (1) in the front of the rotor.
6. Utilizing the hole (1) in the front of the rotor, make a fine adjustment of the shoes.
7. Reinstall the rubber plug.
8. Lower the vehicle far enough to access the interior of the vehicle.
9. Reach inside the vehicle and cycle (fully apply and release) the park brakes.
10. With the parking brake lever in the fully applied (up) position, attempt to hand rotate each rear brake rotor to ensure that the parking brake shoes are working properly.
11. With the parking brake lever in the released (down) position, hand rotate each rear brake rotor to ensure that the parking brake shoes are not dragging.
12. Raise and support the vehicle.
Fig 1A
13. Remove the wheel mounting nuts and install the tire and wheel assembly (1) Install and tighten the wheel mounting nuts (3) to 135 N•m (100 ft. lbs.).
14. Lower the vehicle.
Bob
Unread 05-14-2008, 01:56 AM   #14
jeepheller98
WOW..... that was intense
Unread 05-14-2008, 04:24 AM   #15
Gramps
The Necessary Evil
Gramps's Avatar
2007 MK Compass
Sorry if I made it sound that way! I'm not trying to scare anybody off in trying to do their own brake job. If you've done brakes before you'll find it pretty straight forward. LOTS of newbies to twisting wrenches read this stuff too and I just couldn't skip over anything assuming that it was common knowledge. It's a safety issue.
This also only covers the mechanics of it. If you're having electronics problems with the ESP, TCS, anti-lock or other issues I highly recommend taking to to the dealer or someone who is qualified in those areas. There are several charts and pages on trouble shooting the electronics that I didn't cover and if you feel qualified and need that info you'll need to get a Service Manual and a scan tool to make sure that you don't miss anything.
Bob
brakes , compass , patriot , replacement
