Blocked Wheels...Rear Differential - JeepForum.com
post #1 of 2 Old 05-04-2012, 06:16 AM Thread Starter
ajfiel
Dear Friends,
Sorry for my English...
My Patriot 2.0 diesel/6 gears from 2007 is in the Garage since the first days of April and my mechanic is no longer a big friend of it.
When I turn left (slow speed)…the right rear wheel start blocking. When I turn right…the same will problem in the rear left wheel. I have this problem since the day I took the two sensors in the rear wheels.
The front and rear differential are almost new. Mechanically, the car is perfect. The problem is in a small box (pic below) connected with the rear differential. I really don’t know the name of it. If we take that part from the car, the noise and wheels block disappear. Is this an Electronic Coupling Unit problem? We had to install 4 new wheels sensors. And, as far as we understand, there’s a relation between that box and the wheel sensors (the mechanics were talking about electromagnetic…) I don’t know how to explain. Is there a way to reset the Electronic Unit? Any other ideas? Brake Lock Differential? Lunchbox Locker???
ajfiel is offline
post #2 of 2 Old 05-07-2012, 08:27 AM
Gramps
The Necessary Evil
Gramps's Avatar
2007 MK Compass
The All Wheel Drive (AWD) Control Module (located in the left kick panel area) gets signals over the vehicle bus from the Electronically Controlled Coupling (ECC) mounted on the rear axle. The ECC sensor is what your picture was indicating (it no longer was showing so I removed it). I would check for a frayed wire or the AWD Control Module itself in the left front fender well.
Bob
posts 68 & 69
Also visit me at
Gramps is offline
Problem with 2007 Compass rear differential TonyBG Jeep Compass & Patriot Forum 12 02-18-2012 09:27 AM
adding rear power port to rear seat area? BobKnake Jeep Compass & Patriot Forum 4 05-04-2011 09:12 AM
Blocked Catalytic converter problem Sk8ter Jeep Compass & Patriot Forum 5 07-09-2010 08:08 AM
Rear ended - rear bumper question handyman98 Jeep Compass & Patriot Forum 4 05-12-2009 10:19 AM
New wheels compared to 20" bling'd wheels ... I like the Sport 17's better :) rob_rector Jeep Compass & Patriot Forum 11 03-27-2008 03:13 PM
