Bent Hood - JeepForum.com
post #1 of 7 Old 07-01-2012, 06:11 PM Thread Starter
bigkat91
2011 MK Compass
Bent Hood
As a result of Iowa allowing heavier and longer grain trailers and living in rural Iowa, I got a bent hood. The newer trailers and trucks make such of an air wake that every time one passes in the opposite lane it makes my hood flare up. I don't know if it just by design of the new hood and it's front lip angle or what. I'll post photos when I get my camera back. The bent portion is right above the drivers side headlight.
2011 Compass 120K miles
RRO Lift
bigkat91 is offline
post #2 of 7 Old 07-07-2012, 05:15 AM Thread Starter
bigkat91
2011 MK Compass
Its's not bad but it is slightly annoying. Looks like I'll be getting a bug deflector soon.
RRO Lift
bigkat91 is offline
post #3 of 7 Old 07-07-2012, 08:26 AM
Gramps
The Necessary Evil
Gramps's Avatar
2007 MK Compass
I wanted to say "THAT SUCKS" earlier but that doesn't add much to the thread. The earlier Patriots had a problem with the rear of the hood lifting up and replacing the hinges helped that problem. Do you see an easy way to stiffen the hood so this won't happen to someone else or is the bug deflector an after the fact fix?
Bob
posts 68 & 69
Also visit me at
Gramps is offline
post #4 of 7 Old 07-07-2012, 08:45 AM Thread Starter
bigkat91
2011 MK Compass
I'm hoping the bug deflector helps by putting more down force on the lip of the hood. When the trucks and trailers pass by it lifts up the hood all the way back to the hinges. As for stiffening the hood it my be plausible to weld some square tubing to the under side. Notch it like this \____/ in short pieces to help hold the form of the hood angles. Ill have to talk with my body repair guy as to what his thoughts are. Im no good at welding. I need him to repaint the corner to as its chipped bad right above the head lamp. I've tried to use touch up and it doesn't want to stick even after sanding primer etc.
RRO Lift
bigkat91 is offline
post #5 of 7 Old 07-08-2012, 07:36 AM
Gramps
The Necessary Evil
Gramps's Avatar
2007 MK Compass
Any pictures or is your camera still 'on loan'?
Bob
posts 68 & 69
Also visit me at
Gramps is offline
post #6 of 7 Old 07-08-2012, 11:28 AM Thread Starter
bigkat91
2011 MK Compass
Got it back an posted two.
RRO Lift
bigkat91 is offline
post #7 of 7 Old 07-11-2012, 02:11 AM Thread Starter
bigkat91
2011 MK Compass
RRO Lift
bigkat91 is offline
Compass Hood scarbs Jeep Compass & Patriot Forum 2 08-09-2011 01:45 PM
07 Compass with rattling noise under the hood. earlage Jeep Compass & Patriot Forum 13 03-21-2010 01:39 PM
SEMA hood Argent33 Jeep Compass & Patriot Forum 0 07-10-2009 04:35 AM
Patriot Hood Issue Silkk19 Jeep Compass & Patriot Forum 6 03-01-2008 07:04 AM
