Bad Tie Rods Already? - JeepForum.com
post #1 of 87 Old 07-31-2008, 09:00 AM Thread Starter
snood
snood's Avatar
2007 MK Compass
So yesterday I went to get my yearly NYS inspection done and it failed for having bad outer tie rods. Has anyone else had problems like this?
'07 Compass -> I apologize to the next owner.
snood is offline
post #2 of 87 Old 07-31-2008, 11:04 AM
snikr
Yes I have. Both outer ends were bad with only 1350 miles on them. At least they were covered.
Tom
2010 Subaru Forester
2004 Dodge Dakota 4 X 4
So many roads.......So little vacation time
snikr is offline
post #3 of 87 Old 07-31-2008, 09:38 PM Thread Starter
snood
snood's Avatar
2007 MK Compass
This just shows the poor engineering by Chrysler.
snood is offline
post #4 of 87 Old 08-01-2008, 03:44 AM
Gramps
The Necessary Evil
Gramps's Avatar
2007 MK Compass
More like poor vendor quality unfortunatly. I haven't seen anybodies factory steering components that meet my standards yet but these, as many factory units , don't even have grease fitting. I'll be replacing mine with Moog somewhere down the road.
Bob
posts 68 & 69
Also visit me at
Gramps is offline
post #5 of 87 Old 09-21-2008, 08:24 AM
BeechBlogger
2007 MK Compass
Just yesterday, I took mine into a tire dealer to see why I was getting shudder at 55-60 mph. (Girl here - don't know these things like you guys and gals) He was very kind and told me he got movement when he checked it with his hands and I have bad outer tie rods. Also said since I have less than 30K miles on the car it should be covered under warranty. I called the dealership while there and made arrangements for them to get them ordered so I can get it fixed. They, at first, said I would have to bring it in to make sure that was what it was. I told them I'm not driving 45 min. (closest dealer) to "see" and they needed to order the parts, then I'll bring it in one time. I'd love to hear about others that have had this problem in the Compass because the mechanic I spoke with said he had never heard of it on one of them.
BeechBlogger is offline
post #6 of 87 Old 10-24-2008, 08:07 AM
zxjockey
2007 MK Patriot
I just took my Pat in yesterday because of the infamous clunk and shudder. 2 Bad Tie Rod Ends, as well as a disintigrating Ball Joint on the right side. About 32K miles.
zxjockey is offline
post #7 of 87 Old 10-26-2008, 07:55 AM
calibastard
2009 MK Compass
I have an AWD Caliber R/T, aka, Compass drivetrain, same assembly line.
There is currently a recall on early 2008, and 2007 Calibers that most likely also affect the Compass and possibly even Patriot. The lower control arm TSB (I dont have the number, sorry) is discussed here on the CaiberForumZ.
Apparently, they had used wrong sized bolts in the assembly line wich cause the entire front end assembly to loosen with time. As a result, I had my tie rods, lower control arms and bushings replaced just two weeks ago, with only 18 months usage for 32,000km (25-some thousand miles).
Dodge/Chrysler is supposedly sending recall letters to affected vehicles but I wouldn't be surprised if they narrowed the target audience a bit.
If you feel a loosening of the steering wheel, shudders on bumpy roads or creaking sounds on acceleration/stops & speed bumps (aka, suspension travel under pressure conditions), then it would be a GOOD idea to have the car checked.
Warranty covers the charges but my dealer con-ed me into paying for realignment. You should argue more than I did. (And yes, I'm reclaiming those charges.)
calibastard is offline
post #8 of 87 Old 10-26-2008, 01:15 PM
Coasty161
always thought a TSB was not the same as a recall.
Coasty161 is offline
post #9 of 87 Old 10-26-2008, 05:00 PM
calibastard
2009 MK Compass
Yeah, it sounds odd as I wrote it but I believe there was a TSB that resulted in a recall.
post #10 of 87 Old 10-27-2008, 01:04 PM
JeepMB
2007 MK Compass
Yes I have. Both outer ends were bad with only 18.000 km on them
Compass 2007 4x4 Sport
JeepMB is offline
post #11 of 87 Old 10-27-2008, 02:29 PM
Coasty161
as of 10/1/08 these r the only recalls posted COMPASS RECALLS Top
2007 JEEP COMPASS
Manufactured between: 09/07/2006 and 12/13/2006
Defect: on certain vehicles, the antilock brake system (abs) control module software may cause the rear brakes to lock up during certain braking conditions.
Consequence: this could result in a loss of vehicle control and cause a crash without warning.
Action: dealers will reprogram the abs electronic control unit. the recall began on february 19, 2007. owners may contact daimlerchrysler at 1-800-853-1403.
Recall Date: 12/29/2006
2007 JEEP COMPASS
Manufactured between: 03/29/2006 and 10/20/2006
Defect: on certain sport utility vehicles, the owner's manual does not contain the required higher rollover risk warning information.
Consequence: without the rollover warning information in the owner's manual, drivers may not be aware of the significantly higher rollover rate on this type vehicle, which could result in a crash.
Action: daimlerchrysler will mail an addendum to the owner's manual to all affected vehicle owners. the recall began on november 14, 2006. owners may contact daimlerchrysler at 1-800-853-1403.
Recall Date: 11/15/2006
COMPASS 4X4 RECALLS Top
2007 JEEP COMPASS 4X4
Manufactured between: 11/29/2006 and 03/15/2007
Defect: certain passenger vehicles equipped with rear disc brakes fail to conform to the requirements of federal motor vehicle safety standard (fmvss) no. 135, "light vehicle brake systems." the length of the rear wheel hub mounting bolts may prevent actuation of the park brake.
Consequence: this could allow unintended movement of the vehicle under certain conditions and cause a crash without warning.
Action: dealers will replace the rear wheel hub mounting bolts and repair the park brake free of charge. the recall began on may 8, 2007. owners may contact daimlerchrysler at 1-800-853-1403.
Recall Date: 05/07/2007
PATRIOT 4X4 RECALLS Top
2007 JEEP PATRIOT 4X4
Manufactured between: 11/29/2007 and 03/15/2007
post #12 of 87 Old 12-22-2008, 06:06 PM
z05m
I thought it was just me. This summer I changed my Drivers side Tie Rod and then last week brought my Jeep in for an inspection (24k km) and complain about stuttering. The Dealer told me this time that both my Tie Rods were affected. I'm not paying a 2nd alignment on my Compass limited. To say, I'm pissed is an understatement. This is a major Issue.
Chrysler, move on it. You have major issues with the Tie rods on the Compasses. Apart from that the Vehicle is fantastic.
z05m is offline
post #13 of 87 Old 12-26-2008, 08:36 PM
howdy246
2008 MK Compass
Its a common problem on some Compass's. The problem was the bolts weren't tighten properly and became loose causing premature wear.
howdy246 is offline
post #14 of 87 Old 03-27-2009, 09:11 AM
Knightfallzx2
2008 MK Compass
(Bumping old thread)
Just had our outer tie rod ends done under warranty as well. I heard a lot of noise coming from up front while going over large bumps in the road (ice and snow). They said the driver's side was nearly popped out!
Glad I didn't have to pay anything at least.
2008 Jeep Compass North 4x4
Black Crystal Pearlcoat, 5-speed
Knightfallzx2 is offline
post #15 of 87 Old 03-27-2009, 05:01 PM
Gramps
The Necessary Evil
Gramps's Avatar
2007 MK Compass
Thanks for the bump. I was just thinking about this today. NAPA Chassis now lists Tie Rod ends for the MK's, made by TRW. NAPA number 2693277. I don't know if they have a grease fitting or not. This may help some to cross reference them.
Bob
posts 68 & 69
Also visit me at
Gramps is offline
