Bad Throttle response - JeepForum.com
post #1 of 5 Old 01-09-2010, 06:24 AM Thread Starter
lidhead
2009 MK Compass
Has anyone had issues with their throttle response? Once or twice a week i have issues with the throttle. When i let out on the clutch and press on the gas i get nothing, no revs or anything. I let up on the gas and repress and usually it works, sometimes i have to repeat.
Yesterday, however, I did this twice still nothing, then i downshifted, and it began jerking violently (like if you dumped the clutch) and the ESP light came on. It did the same thing at the next soplight. The ESP light is currently off. I was in 4WD, does this make a difference?
It only does this from a dead stop. It has done this randomly since I bought this Jeep new in July of '09.
Any suggestions?
Thanks,
Lidhead
2009 Compass Rallye
"Free lovin' don't cost a dime"
lidhead is offline
post #2 of 5 Old 01-09-2010, 07:17 AM
cactus_jack
I have the same issue with throttle response sometimes. It will act like it's not getting enough air or something. I think it has something to do with the electronic throttle control not working right. I sometimes turn my ESP partial off and it helps. I think it's just a safety precaution to keep your tires from breaking loose.
CACTUS_JACK
98 XJ Sport Budget Build
cactus_jack is offline
post #3 of 5 Old 01-09-2010, 08:12 AM
Gramps
The Necessary Evil
Gramps's Avatar
2007 MK Compass
It may have to do with this code but you'll need to have someone pull the codes, if any.
P0125-INSUFFICIENT COOLANT TEMP FOR CLOSED-LOOP FUEL CONTROL
When Monitored:
  • With the ignition on, battery voltage greater than 10.4 volts, and no ECT sensor circuit DTCs present.
  • Set Condition: The PCM detects that the engine coolant temperature is below the calibrated pass value when the engine run time is greater than the calibrated value based on start up coolant temperature. Two trip fault. Three good trips to turn off the MIL.
Possible Causes
ENGINE COOLANT TEMPERATURE SENSOR WIRING OR CONNECTORS
ENGINE COOLANT LEVEL AND CONDITION
THERMOSTAT
Bob
posts 68 & 69
Also visit me at
Gramps is offline
post #4 of 5 Old 01-09-2010, 09:19 AM
cactus_jack
will there be codes if there is no check engine light? because I've always wondered about this problem as well, but just been ignoring it
CACTUS_JACK
post #5 of 5 Old 01-09-2010, 09:39 AM
Gramps
The Necessary Evil
Gramps's Avatar
2007 MK Compass
There may be but I don't know for ceratin. I know that the ESP, BAS lights will throw a code without having the MIL light but they are a different part of the system.
Someone else had a similar problem way back when. It was mostly when they were turning and pulling on to another road and it turned out to be the Steering Angle Sensor. Go figure!
Bob
posts 68 & 69
Also visit me at
Gramps is offline
P2100 code - Electronic Throttle Control and ESP Lights ninjaneer83 Jeep Compass & Patriot Forum 52 11-18-2016 12:46 PM
Electronic Throttle Control (ETC) the mad hatter Jeep Compass & Patriot Forum 7 04-19-2011 03:56 PM
Part-Throttle Whistling, Beep? b1llyw Jeep Compass & Patriot Forum 3 09-21-2009 04:45 PM
Improve CVT Response CoriolisSTORM Jeep Compass & Patriot Forum 0 05-29-2008 07:25 PM
Carbon Build-up Throttle Body Mistyfate Jeep Compass & Patriot Forum 13 02-03-2008 05:13 PM
