Back in the shop again. - JeepForum.com
post #1 of 17 Old 01-23-2008, 07:46 PM Thread Starter
ajadams
2007 MK Compass
Leaking sunroof again
My Compass is back in the shop for a leaking sunroof. It keeps leaking around the front two corners when parked.
The dealer is waiting on some relacement drain tubes. Does anyone have the drawing of the sunroof assembly so I can see where these tubes are? I'm wondering if there is some sort of drip rail for the sunroof under the headliner, and where it drains to.
ajadams is offline
post #2 of 17 Old 01-24-2008, 05:12 AM
Gramps
The Necessary Evil
Gramps's Avatar
2007 MK Compass
See if this helps. It's actually on the Patriot but similar.
http://www.telusplanet.net/~homac/Je...0Detection.pdf
Bob
posts 68 & 69
Also visit me at
Gramps is offline
post #3 of 17 Old 02-24-2008, 05:25 PM Thread Starter
ajadams
2007 MK Compass
My Compass is back in the shop.
Third time in for a leaking sunroof (this time the water was coming out of the domelight.)
Second time in for the rear brakes squeeling in reverse.
ajadams is offline
post #4 of 17 Old 02-24-2008, 06:14 PM
Gramps
The Necessary Evil
Gramps's Avatar
2007 MK Compass
Sure hope they get it right on both this time for you!
Bob
posts 68 & 69
Also visit me at
Gramps is offline
post #5 of 17 Old 02-24-2008, 06:40 PM Thread Starter
ajadams
2007 MK Compass
I hope so too. I'm getting pretty tired of taking it back in every couple weeks for the sunroof. If it wasn't for a free loaner car, I'd take to the small dealer closer to me.
ajadams is offline
post #6 of 17 Old 02-25-2008, 08:13 AM
KUHawkhead
2008 KK Liberty
Have them replace the seal around your sunroof. If it still leaks, have them check that rear seal where the top and rear side metal overlap. There is supposed to be a rubber sealer sprayed in there. Good luck if that's the issue.
KUHawkhead is offline
post #7 of 17 Old 02-25-2008, 07:41 PM Thread Starter
ajadams
2007 MK Compass
They have done that, adjusted the track, and replaced some drain tubes.
It leaks in the front two corners.
ajadams is offline
post #8 of 17 Old 02-25-2008, 08:12 PM
KUHawkhead
2008 KK Liberty
So it is your sunroof! That should be able to be fixed, or at least be an obvious issue. Keep track of the number of times it's been in,and document. Check your local lemon laws, and get ready to pick out your new Jeep, after about 6 weeks of badgering them.
post #9 of 17 Old 02-26-2008, 03:54 AM
Jeepster55
Originally Posted by ajadams View Post
......Second time in for the rear brakes squeeling in reverse.
mine does this about every time i back out of our garage in the AM. is there a tech or service bulletin on this? do they claim to have a 'fix' for it? it is kind of annoying, but since it's only the first thing in the AM and backing up, i can live with it......
Jeepster55 is offline
post #10 of 17 Old 02-26-2008, 05:18 AM
Gramps
The Necessary Evil
Gramps's Avatar
2007 MK Compass
Not a TSB but something similar in the SM.
http://www.jeepforum.com/forum/showp...3&postcount=11
Bob
posts 68 & 69
Also visit me at
Gramps is offline
post #11 of 17 Old 02-26-2008, 06:28 AM
merlinTec
merlinTec's Avatar
Hi
had this from the front brakes and they have modified the pads. not checked for the rear. As for the sunroof drain tubes not had any repeat faults.
Regards,
Merlin
UK Chrysler Jeep Master Tec.
merlinTec is offline
post #12 of 17 Old 02-28-2008, 11:45 AM
Stargazer79
2008 MK Compass
Is yours 2WD with the rear drums or FWD with the rear discs? (I know, dumb question, but I'm a noob here, so don't hurt me too much.)
Stargazer79 is offline
post #13 of 17 Old 02-28-2008, 12:00 PM
Gramps
The Necessary Evil
Gramps's Avatar
2007 MK Compass
Not dumb at all. Everybody! Please fill out your profiles! Just doing that would help us to better answer your questions. 007's came with all disc brakes, 2008 had rear drums on some. I AM NOT trying to spank anybody here, more like BEGGING.
Bob
posts 68 & 69
Also visit me at
Gramps is offline
post #14 of 17 Old 02-29-2008, 05:17 PM Thread Starter
ajadams
2007 MK Compass
Mine is 4wd with discs.
The dealer referenced TSB 23-043-06 on the sunroof.
On the repair for the rear brakes, they wrote." 14973 Normal noise, if vechile sits and light surface rust builds up you get this noise, we had this problem with other vechiles in this humid climate TK1092
ajadams is offline
post #15 of 17 Old 03-01-2008, 06:11 AM
Jeepster55
Mine is 4wd with discs. On the repair for the rear brakes, they wrote." 14973 Normal noise, if vechile sits and light surface rust builds up you get this noise, we had this problem with other vechiles in this humid climate TK1092
ok, i understand the 'normal' rust build up, but just sitting OVERNIGHT? IN A GARAGE? that's all it takes for MINE to do that. and yes, mine is a 4X4 with 4 wheel disc brakes.
i wonder if that's why they have opted to put DRUM brakes on some of the '08s?
MBRP Cat Back on eBay flipperCompass Jeep Compass & Patriot Forum 13 11-24-2009 09:25 PM
Back End Issues tinkerbelle506 Jeep Compass & Patriot Forum 9 04-30-2008 05:30 PM
Compass in the shop for ETC Nabis Jeep Compass & Patriot Forum 6 01-22-2008 02:05 PM
What's on the back of my MK? mdls4 Jeep Compass & Patriot Forum 16 01-16-2008 08:43 AM
