Axle info please - JeepForum.com
post #1 of 4 Old 12-22-2006, 05:30 PM Thread Starter
RickyN29
RickyN29's Avatar
Axle info please
What axles do these have front and rear? I went by the dealership, but they were too low to the ground to get a peak underneath. Same as usual 35 rear, 30 front?
Thanks
1990 XJ Laredo 4x4 Auto
*Rusty's ~6" Lift
*Dana30/Dana44 3.55's
*Pacer Wheels/High-Tec Retreads 31" MT
*KargoMaster Safari Rack
*CSF Open Cooling System Conversion
*Hayden Tranny Cooler
*Flowmaster 40 Delta & High-Flo Cat
*PORC SYE / FRT DS Combo
*The Doors are off again for summer!
RickyN29 is offline
post #2 of 4 Old 12-22-2006, 05:43 PM
Gramps
The Necessary Evil
Gramps's Avatar
2007 MK Compass
No, no, no. Sorry, these are primarily FWD with electronic couplings to the optional rear end that make it a 4WD. I truly believe that you won't find any similarities in axles that your looking for. We'll hopefully know more when we get the Service Manuals, but thanks for you interest!
This link gives an expansion of the Freedom Drive I used in the Compass/Patriot as well as the other Jeep 4WD systems.
http://www.jeep.com/4x4/index.html?dvar=1
Bob
posts 68 & 69
Also visit me at
Gramps is offline
post #3 of 4 Old 12-22-2006, 05:52 PM Thread Starter
RickyN29
RickyN29's Avatar
Opps!
Thanks for the reply.
I think I can picture it, I have a car that was essentially FWD, but using a viscous coupling unit, splits the torque to a rear axle.
So a compass would be AWD right? (On the models with the optional rear end) Are they full time AWD or selectable?
Thanks again,
-Ricky
*Rusty's ~6" Lift
RickyN29 is offline
post #4 of 4 Old 12-22-2006, 05:57 PM
Gramps
The Necessary Evil
Gramps's Avatar
2007 MK Compass
Originally Posted by RickyN29
Opps!
Thanks again,
-Ricky
The 4WD version is AWD all of the time with a locking lever to split the torque 50-50 in off road or bad road conditions. You can also turn off the Electronic Stability Program to enhance it's capabilities but you'd never be able to turn it in to a Rubicon , etc. with out changing the whole works out. The Freedom drive I also only has a high range 4WD. The Freedom Drive II due out on the Patriot has a Low range more suited for heavier 4WD work.
Bob
posts 68 & 69
Also visit me at
Gramps is offline
need info on the 2.4 engine for patriot roland365 Jeep Compass & Patriot Forum 27 07-31-2008 08:58 PM
Headrest question - Need info rob_rector Jeep Compass & Patriot Forum 1 04-21-2008 04:20 PM
info on instament cluster dropt_98_dakota Jeep Compass & Patriot Forum 1 10-22-2007 02:25 PM
MK lift kits? OLD INFO casm Jeep Compass & Patriot Forum 22 08-10-2007 04:30 PM
Need some info, thinking about a Patriot DucTrip9s Jeep Compass & Patriot Forum 5 07-01-2007 02:35 PM
