autostick conversion? - Page 3 - JeepForum.com
post #31 of 70 Old 01-30-2008, 05:52 PM
Gramps
The Necessary Evil
Gramps's Avatar
2007 MK Compass
Thanks! Your Speedo is off by 6.45% so your actual speed was 21.29.
Here's something interesting. These are my speeds in gears at 2500 rpm with the AutoStick:
1st = 13mph
2nd = 20
3rd = 28
Why is my 1st gear lower than your Low? Is it that in Low the variator still varies while mine is locked in to the set range? Maybe I've got the FD II final drive.
Bob
posts 68 & 69
Also visit me at
Gramps is offline
post #32 of 70 Old 01-30-2008, 07:36 PM
Coasty161
1st = 13mph
2nd = 20
3rd = 28
think i remember reading somewhere that it did.
Coasty161 is offline
post #33 of 70 Old 01-30-2008, 09:23 PM
Coasty161
drove again, at 2500rpm speed is just under 15mph
post #34 of 70 Old 01-31-2008, 05:01 AM
Gramps
The Necessary Evil
Gramps's Avatar
2007 MK Compass
Thanks for the update . I'm not quite as crazy as I thought I was.
Just a brief update on where we are on this. The wiring is correct but so far the FD II will not accept the DHD code. It appears that the dealer is trying to get Jeep engineering involved. It may be that the TCM doesn't want to accept my VIN number. We're still working on it.
Bob
posts 68 & 69
Also visit me at
Gramps is offline
post #35 of 70 Old 01-31-2008, 05:34 AM Thread Starter
CharBroiled
1st = 13mph
2nd = 20
3rd = 28
I think Low varies. I was on a level stretch and just had enough peddle to keep speed at 2.5k RPM. with mild acceleration the tach went up right away to 3.5k or so before my speed changed. when I floored it I got up to about 60 MPH at 5.5k RPM in Low (and still pulling) but shifted to Drive at that point.
my guess is Low has all the range of your 1-4 (guessing), you can just set your autostick within that range better.
2000 Cherokee Sport 4.0L Selec Trac - mine - for occasional wheeling
2007 Patriot 2.4L FD I 4x4 - wifes - doomed to rarely leave the street
CharBroiled is offline
post #36 of 70 Old 01-31-2008, 06:45 AM
Gramps
The Necessary Evil
Gramps's Avatar
2007 MK Compass
That's something that I was wondering. Do you feel a "shift" in low or does it feel like it just keeps "pulling". I haven't driven a CVT with out AutoStick since I test drove a Caliber SXT with the 2000cc engine and the FD II Patriot. Maybe I should take another test drive .
Just for fun I tested 2500rpm in:
4th = 35 mph
5th = 47 mph
6th = 68 mph
Bob
posts 68 & 69
Also visit me at
Gramps is offline
post #37 of 70 Old 01-31-2008, 06:17 PM Thread Starter
CharBroiled
in Low I can get steady speeds from 15-23 MPH while at 2500 rpm, it depends on whether Im going uphill or level and whether I was accelerating or decelerating to get that 2500 rpm. for instance off the line I can sit at exactly 2500 rpm the whole time and sorta creep up to 20 mph or so, so the cvt is definitely varying the ratio in Low.
so in Low it just seems to keep "pulling" with no noticeable shifting of ratios.. its very smooth in Low. but in Drive it almost seems to emulate shift points, you can feel it changing ratios. its like they programmed it to "feel" like an old school automatic (to a point, anyway) in Drive.
post #38 of 70 Old 01-31-2008, 06:40 PM
Gramps
The Necessary Evil
Gramps's Avatar
2007 MK Compass
The ratios were only programmed in because someone thought that the public would be more comfortable with something that shifted as opposed to not shifting like a snow mobile.
Just speculating here: it appears that one of the Variators is allowed to move with the Low gate but both Variators are locked with the AutoStick. It's just electrical signals that feed the CVT and tell it what to do so that's not really too hi-tech. Now I'm curious to find out which one and maybe why.
Bob
posts 68 & 69
Also visit me at
Gramps is offline
post #39 of 70 Old 02-01-2008, 07:41 AM
Gramps
The Necessary Evil
Gramps's Avatar
2007 MK Compass
Need more data:
I've found out that the FD II package is up around 20 mph in low only but at 9 - 10 mph with the 4WD also on (Off-Road mode). It looks like in Off-Road mode they have the equivalent of my 1st gear. Does the FD I CVT with Lock on also have a 1st gear or does it still vary? If so, then there is additional programming for the transmission when the Lock is activated on both. Many more features on the FD II but I'm trying to isolate the trans features and then go on to the FD II set up.
07compasssport and CharBroiled were you in 4WD or not?
Bob
posts 68 & 69
Also visit me at
Gramps is offline
post #40 of 70 Old 02-01-2008, 03:01 PM Thread Starter
CharBroiled
I was not in 4x4 lock mode when I did my tests.
we are having an ice storm tonight so I wont be able to check if Low acts differently in 4x4 lock vs normal mode till tomorrow sometime.
I wish they hadnt programmed in "shift points" as Ive found I like the smooth pull of a cvt.
post #41 of 70 Old 02-01-2008, 03:59 PM
Gramps
The Necessary Evil
Gramps's Avatar
2007 MK Compass
No big rush, when ever you get a chance.
We're finally going to be up to "only" freezing for the next 9 out of 10 days! Break out the tank tops and shorts.
Bob
posts 68 & 69
Also visit me at
Gramps is offline
post #42 of 70 Old 02-01-2008, 08:13 PM
Coasty161
wasnt in 4x4 lock mode. will try this weekend.
edit: put in lock mode esp off and in "L" got about the same speed as before, just under 15
post #43 of 70 Old 02-03-2008, 03:37 PM Thread Starter
CharBroiled
in 4x4 lock mode there was no difference in final speed at 2500 rpm: bout 22 MPH is the sweet spot.
I did notice that in "L" idle RPMs are different in 4x4 Lock vs normal mode. compasssport, try this: with 4x4 lock ON and foot on the brake and off the gas (not moving), put it in "D," engine RPM sits about 700 on mine. then put it in "L," again with your foot on the brake and off the gas. my idle RPMs goes up to just under 1000. shift back to "D" OR take off 4x4 lock and RPMs drop back to normal.
so it seems that if Im are in BOTH "L" and 4x4 Lock my idle RPM goes up to almost 1000. anyone else notice this in theirs?
post #44 of 70 Old 02-03-2008, 04:16 PM
Coasty161
noticed the same on our jeep... it also feels different when accelerating when in low.
post #45 of 70 Old 02-03-2008, 06:06 PM
Jeepster55
ok, i could see where the RPM's would up if you chose to be in '4Wheel Low' to get you out of deep snow, mud, etc....like a 'crawl' or 'granny' gear would do.
so this might be the 'crawl' gear version of the CVT's WITHOUT FDII, ya think?
Jeepster55 is offline
AutoStick - How Best To Use It ??? ChillyWillys Jeep Compass & Patriot Forum 12 05-21-2009 11:16 AM
Jeep Compass Fold Flat Conversion compass0018 Jeep Compass & Patriot Forum 3 04-22-2009 01:14 PM
2008 Compass, Autostick Trans, 4th gear Cobydick Jeep Compass & Patriot Forum 4 11-28-2008 06:09 PM
question for you autostick folks CharBroiled Jeep Compass & Patriot Forum 8 09-21-2008 01:17 AM
Front end conversion? phokur Jeep Compass & Patriot Forum 3 03-04-2008 07:56 PM
